Question about 2wire 2700HG-B Router (2700HGB)
I have a 2Wire 2700HG-B router that has been working fine between my desktop, printer and laptop. But recently I have lost the inability to print from the laptop and I have no idea what to do. Can you help?
  • castle554 Feb 15, 2009
    I have an SMC router with a print server behind my 2Wire modem. They both use 192.168.2.1 and the 2Wire won't recognize the SMC router or the print server.
  • 689 Answers
You may perform reset and re-configure the settings and crendentials. If issue persists you may post again by indicated symptoms. Like blinking lights etc
Posted on Aug 24, 2009
Can't access modem from desktop
If your DSL works on PPPOE then you need to setup PPPOE on the 2wire router with the Complete Username and the PAssword for the PPPOW connection, if your DSL works on a Local IP address like 192.168.1.254 or 192.168.1.1 then first check the gateway address of the 2wire Router, if it's in the same IP address range like the DSL Modem like 192.168.1.x the you need to change the Local IP address of the router from 192.168.1.x to 192.168.2.x that should get you up and running with the DSL Modem.
Mar 25, 2010 | 2wire 2700HG-B Router (2700HGB)
Hot to make my gateway 2700hg-d modem/router
you just need to things for ATT your user name and password that you registered to them. Then you need to get inside the 2wire by using the IE or Mozilla. On the address bar, type in 192.168.1.254. Inside you will see there setup then just follow the prompt but if you got lost on the process just call att dsl
Mar 07, 2010 | 2wire 2700HG-B Router (2700HGB)
I have lost my wireless connection on my laptop
Delete the Existing wireless connections in the laptop and create another one
This should fix the issue
Jan 03, 2010 | 2wire 2700HG-B Router (2700HGB)
I have a 2wire 2700hg-b modem/wireless router, my problem is i get lag while playing xbox 360 online, i get red bar to none , while my friend have all green bar,in the tv screen,also my laptop lose signal...
yeah a better modem would be the easiest thing to do because it's clear that the one you've got is either not transmtting properly or is just the unit you'vee got has a fault in it
Oct 15, 2009 | 2wire 2700HG-B Router (2700HGB)
How do I get the WEP key for my 2wire 2700hg-b router?
Take a look under your 2wire modem, wep key is located on the bar code.
Apr 09, 2009 | 2wire 2700HG-B Router (2700HGB)
Security key issue
Hi whitecapz,
Usually the security key on a 2wire router can be found at the bottom of the router itself. try to find a 10 digit code on the router.
Oct 11, 2008 | 2wire 2700HG-B Router (2700HGB)
HP wire less printer
try to synchronize the connection by doing a power cycle. turn off everything. then turn them on one by one starting with the modem, the router, the computer then the printer
Aug 21, 2008 | 2wire 2700HG-B Router (2700HGB)
Wireless hookup
192.168.0.1 in your browser will take you to the router set up, you may have to enable printer sharing as well, but you can assign a key there or have it assign one.
Jan 28, 2008 | 2wire 2700HG-B Router (2700HGB)
2wire 2700HG - B
Log on to the routers interface and look for MTU size. Once you get there, reduce it to 1492. This will help.
- Ranjit
ranjit@supportminds.com
Nov 02, 2007 | 2wire 2700HG-B Router (2700HGB)
2wire 2700HG-B Router (2700HGB) Logo
49 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
