Question about Nintendo GameCube Console
Problem with gamecube
When I press the power butten my gamecube wont turn on
  • ashton ellynom Jul 12, 2007
    me to
  • Anonymous Mar 22, 2008
    My Game-cube makes the sound that it is turned on but nothing comes up on the screen of my tv and the red light wont turn on but it blinks for a second.
  • 85 Answers
Sounds like you are going to have to get it replaced. If it was stuck I would say it was something different, but since when you can press it, it is usually the circuit board. connie
Posted on Jul 13, 2007
SOURCE:
The power cord was pulled out while the nintendo gamecube was loading up. now it says" an error has occurred turn the power off and check the nintendo gamecube instruction booklet for further...
I think that the ac adapter when it was pulled might of damaged the gamecube to some excent
so now it has a hardware issue that needs to be fixed then.
Feb 19, 2011 | Nintendo GameCube Console
My Nintendo Gamecube received a big powersurge and now it won't turn on. Is there any hope for it or is it fried ?
  • No Power
    1. Make sure that the words "Nintendo GameCube" are molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
    2. Make sure the Nintendo GameCube has good ventilation. For best results, make sure that the system rests on an open, flat surface. Avoid operating the Nintendo GameCube while it's on carpeting or inside an enclosed space.
    3. Check the vents on the sides of the Nintendo GameCube for a build-up of dust. The system will shut down if it cannot vent properly to prevent overheating. If there is a build-up, remove it using a vaccum cleaner with a soft brush attachment.
    4. Avoid the use of unlicensed products such as memory cards, controllers, and cheat devices. Some of these products are poorly manufactured and may result in damage to your system. If one of these products is attached to your system, remove it and try resetting the AC adaptor (see below).
    5. Make sure that your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on the verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch. If you do, make sure the wall switch is in the ON position.
    6. Make sure the AC adapter is attached properly. Firmly plug your AC adapter into the back of the Nintendo GameCube (the port is labeled DC 12V IN) and into a working wall outlet.
    7. Press the power button on the Nintendo GameCube and check to see that the red power light on the top of the Nintendo GameCube illuminates.
      If this fails, try resetting the AC adapter.
      1. Unplug/remove all accessories from the system (including game discs, memory cards, and all controllers), hookup cables, and the AC adapter from the outlet and Nintendo GameCube.
      2. Let the system rest for about 45 seconds. While you're waiting, check to see that the cords on the controllers, AC adaptor, and Stereo AV cables/Component Video cables (or RF Switch) are not frayed or have exposed wires (this can cause the system to shut off); if so, you should replace those parts.
      3. After the 45 seconds, Plug the AC Adapter into the system and wall outlet. Press the power button to see if the system works.
        • If the system works, turn the power off and plug ONE accessory into your system, then turn the system on to see if it still works. Repeat this process with ONE accessory at a time. If your system doesn't work once you put a particular accessory in (GameDisc, controller, Memory Card), there may be something defective with that accessory.
        • If the power does not come on, a repair will be necessary. Because it is not possible to determine which item (Control Deck or A/C Adapter) needs repair, please call our Consumer Service Department at 1-800-255-3700 to discuss available options.
    8. If the power is continually shutting off after aprox. 30 minutes, listen to hear if the fan is working while the system is powered on. If the fan is not running, the problem will continue (Nintendo GameCube is avoiding overheating) and the system will need repair.
  • Power Light Flashes
    If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair.
  • Jan 01, 2011 | Nintendo GameCube Console
    No power The light does not come on. The game does not turn. The fan does not blow.
    • No Power
    • Power Light Shuts Off
      If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
    Dec 21, 2009 | Nintendo GameCube Console
    Why is my screen turning black right when I Press send?
    i had the same problem do the ##program9700 thing mention above follow it all then after you press proximity cal you have to hold the phone next to your ear and then press ok.........this does so the screan wont go black when you make a phone call up until the point u put it up to ur ear.......if you bring it back down then the keypad will reapear.........
    Mar 24, 2009 | LG Dare VX9700 Cell Phone
    Gamcube games wont work on wii
    Sometimes modded Wii's don't like playing Gamecube games.
    Sorry man.
    -Captain Jake
    Feb 12, 2009 | Nintendo Wii Console
    Sylvania mp3 model smpk8854
    when you turn it on, press the the butten in the bottem right corner. and then press the butten with the little computer monitor and the rench in front of it. press the first butten and then press english.
    for any other problem email at [email protected].
    Dec 16, 2008 | Audio Players & Recorders
    CAN'T PROGRAMORIN TV TOA RCA UNIVERSAL REMOTE
    u must press and hold the botton titled as code search until the red light is lit. Once you do so, you program in one of the 3-4 digit codes. I am actually dealing with the same delema. I have an Orion tv except i have no clue what the code for it is. If you could help me out with the code that would be great
    Nov 09, 2008 | RCA RCU300WBL Remote Control
    Gamecube - blank screen, disc wont spin, power light and fan work.
    Troubleshooting - Power
    No Power
    Power Light Flashes
    Dec 07, 2007 | Nintendo GameCube Console
    Gamecube wont turn on
    if it wont turn on try to to check the the outlet the other cables probably thats the problem
    Nov 10, 2007 | Nintendo GameCube Console
    Nintendo GameCube Console Logo
    53 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Julian Wainwright
    Ekse
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
