Question about Refrigerators
Lg gr 389sqf fridge not getting cold - Refrigerators
watugot
  • 290 Answers
SOURCE: hot areas around doors on LG fridge
This is usually caused by a dirty condenser coil or a stalled condenser fan.
Remove the cover from the rear of the fridge and see if the fan is running. If not, make sure nothing is stuck in the blades keeping it from turning. If it turns freely you probably need a new fan motor but you would need to check the voltage to be sure.
Post back if you have any questions.
Posted on Nov 18, 2007
yeroc
  • 397 Answers
SOURCE: lg fridge
heating element seems bad,,sometimes a easy fix
Posted on Jan 20, 2008
  • 400 Answers
SOURCE: lg multi air flow gr-349sqf
It sounds like the defrost element is faulty and is causing a leakage to earth when the unit comes onto defrost cycle. Check the defrost element in the freezer compartment behind a panel cover.
Posted on Mar 10, 2009
SOURCE: LG GR-292R freezer works/fridge does not.
well i have the exact same refrigerator but opposite problem.... the freezer works but the entire refridgerator is a freezer....why is the fridge part freezing everything. This appeared to happen after the power went out and the entire fridge is a freezer now.
Posted on Dec 18, 2009
kel1guy2002
  • 3740 Answers
SOURCE: LG refrigerator GR-B258jvc - replacing light bulb
There are usually 3 or 4 locking tabs on the cover that just need to be pressed INDIVIDUALLY toward the bulb to release them and then carefully remove the cover. The ones with 3 tabs usually have and upper and lower tab then the thrid tab is on the side. Removed the upper and lower tabs by pressing inward to the bulb and then the cover will pivot out on the 3rd SIDE tab.
Thanks for using FixYa.
Kelly
Posted on Apr 09, 2010
Lg gr 389sqf ice
What's the problem? Not making ice? Making too much ice and won't cut off? Freezes too much??? Need a little more info.
Mar 04, 2014 | LG Refrigerators
LG GR-389sqf, trips main switch
where is the fuse for this fridge as there is no power to motor.
Jan 18, 2011 | LG Refrigerators
I HAVE AN LG FRIDGE FREEZER GR-349SNQF. THE FRIDGE IS NOT GETTING COLD
Shut off fridge for about few hours so as to defrost off totally. then switch on. If the cooling returns perfectly then you must check on the auto timer, the thermostat, the heater.
However if there is no cooling then the gas is down or the compressor pumping pressure is low ... the compressor is faulty in its mechanics.
Now you need to deccide before moving further. the cost of a heavy repair to an exchange for an new fridge with warranty/new technology/power saving features.
Decide on this advice. Find this helpful?
Aug 20, 2010 | LG Refrigerators
Fridge Not Working
Your problem could be one of the following:
* compressor
* attachments to compressor (e.g.: relay, capacitor (if applicable) or overload protector)
* refrigerant (e.g.: restriction or leak)
* temperature control assembly
Contact an appliance service company.
Feb 19, 2010 | LG LRTBC1825T Top Freezer Refrigerator
Lg multi air flow gr-349sqf
Mar 10, 2009 | Refrigerators
Refrigerators Logo
107 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
