Question about Brother Multi-Function Center® MFC-215C All-In-One InkJet Printer
Sdhc memory card
My camera tells me that my 4gb pny sdhc card is "unusable." i'm assuming that this means either hc cards can't be used or 4gb cards have too much storage space, or both. if any or all of these are true, please let me know what card is usuable, and what is the size limit, if any. thanks,
ed So there is no use they will just not work even in a computer?
    Genius:
  • 2,120 Answers
Any SD card up to 2gb. Devices are just now coming out that can use High Capacity SD but no printers yet.
Posted on Jan 25, 2009
Is a PNY SDHC 4 GB Memory Card compatible with a Canon PowerShot A530 camera? The card currently in the camera is not a HC card.
I think the maximum size card you can use in the power shot is a 1Gb card unless nes firmware has been istalled to allow 2Gb card.
Using large capacity cards also delays the write recovery time. So if you are trying to capture moving objects , often you get one shot and then it takes almost 20 seconds to recover for the next pic. Too late for most things that move
hope this was of some help
V
May 09, 2010 | PNY 4GB microSD High Capacity Mobile Media...
New digital memory card inserted and camara reads memory card error
1. Try to format your memory card using a PC/Laptop.
2. Now, insert it in camera and check whether its working!
please rate this advice if it helps....tc! :)
Jan 02, 2010 | Canon PowerShot A530 Digital Camera
PNY optima SD HC 4GB card will not read
Try putting a tiny piece of scotch tape over the lock slider. See if that works.
Dec 29, 2009 | PNY 4GB Secure Digital High Capacity...
Loaded new memory card, and screen reads memory card error-memory card locked. Removed new card from camera, nnlocked card, inserted card again, but received same message. Please advise.
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. If your camera is more than a few couple years old, it's likely it was designed before the SDHC format came out. Sorry, but a SDHC card will not work with older cameras.
For older cameras, you'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Dec 25, 2009 | Canon Cameras
Just put in new san disk 4gb memory card and receiving error message - memory card error. I unlocked memory on card itself (that little gray sliver that goes up and down) What gives
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Dec 21, 2009 | Canon PowerShot A610 Digital Camera
My Kodak Z760 Camera will not format your 4gb SDHC card. Kodak says the Z760 can use anSDHC card.
Be shure that the tiny "Lock" switch on the side of the card is not in the locked position.
I bought an SD card on sale to find that it was manufactured poorly and the lock switch would push into the locked position when I inserted it.
Manufacturing defects are not uncommon.
Also be shure you have sufficient battery power.
That's all I know about that.
Cheers,
Richard.
Dec 04, 2009 | PNY 4GB Secure Digital High Capacity...
Inserted new memory card error message:memory card error unable to access format under menu
I'm guessing that you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
Nov 07, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
My canon sd600 is not reading PNY sdhc memory card. msg says card is locked. it's clearly not locked
HC or High Capacity is not compatible with this camera. You have to buy a memory card which says only "SD" and NOT "SDHC". Cards of 2Gb and less are usually "SD". Cards of 8Gb and more are always "SDHC" for technical reasons. Cards of 4Gb can be either, but the SDHC kind are much more common, because they're cheaper and newer.
Jun 22, 2009 | Canon PowerShot SD600 Digital Camera
PURCHASE THE PNY 4GB MEMORY CARD
I have the same problem with the card, my cannon camera, and my gateway laptop. From what I've learned in the past ten minutes, the card is SDHC and my devices are not. The card is not able to dumb down and I am returning it to Best Buy. The HC in SDHC is the issue from my best guess. Similar to you cannot play PS3 games on PS2. I hope this helps anyone else.
Dec 07, 2008 | PNY 4GB Secure Digital High Capacity...
Sdhc memory card
The new SDHC cards must be used on newer devices that support the HC technology... I almost bought the 4 GB SDHC card becasue it was a great price... the asked a few questions and found out my camera less than a year old would not support it.
Jun 16, 2008 | Kodak EasyShare C340 Digital Camera
Brother Multi-Function Center® MFC-215C All-In-One InkJet Printer Logo
129 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
