Question about NetGear USB 2.0 108MBPS Adapter 802.11 (DHWG111T)
Netgear 108 wireless usb adaptor
I have an error code in device manager NDIS.VXD AND NTKERN.VXD. ON THE USB WIRELESS ADAPTOR I AM RUNNING WINDOW ME AND MY INTERNET IS RUNNING FINE THROUGH THE ROUTER WHEN HARD WIRED TO THE NETWORK CARD ANY IDEA IF IT IS CONFLITING WITH THE NETWORK CARD. wHEN i RUN THE SOFTWARE IT DOES NOT SEE THE ROUTER AND THE NETGEAR SCREEN FLASHES UP FOR A SECOND AND WON'T STAY UP. HELP
    President:
  • 2,961 Answers
This is a driver problem, it may be windows generic driver that has installed; so if you have already installed the software, uninstall it and remove the adapter. Restart the pc, then insert the cd driver, but don't let it autorun, then re connect adapter and this time when it asks for the driver point windows to look on the cdrom for it instead of allowing the cd to run the installation.
Posted on Jul 14, 2007
SOURCE:
My netgear 81 is on on my phone. It was on my laptop now it says not connected cant find netgear but yet wen I try to add it says already on this laptop. Troubleshooting says cant find any netgear helppp
Assuming you are using Windows 7 or later.
Right Click on the Network Icon in the Status Bar
Go to Network and Sharing center
Go to Network and Sharing Center then look upper left side and choose "manage wireless connections" you can rename or adjust the SSID for each wireless connection there.
You can get rid of the extra wireless adaptors by going into Control Panel>Device Manager, go to "view" then choose "show hidden devices" after that go to network adaptors and you should be able to delate any extra network adaptor entries.
Mar 25, 2015 | NetGear Computers & Internet
MY PC WON'T DETECT THE ROUTER
does you computer have wireless adaptor? if you have right click on the usb port in device manager and note the error and try to solve the error accordingly...u need to tell more in details
OFDM transmitter
Nov 03, 2012 | NetGear WN111 (DHWN111100NAS) Pre-802.11n...
Hi i am using ubuntu linux i need install netgear usb adapter wg111v3 how can i install in ubuntu please help me
NETGEAR does not offer any offcial drivers for the adapter to work on Ubuntu as they dont support Linux OS. However, you may try third party drivers to install the adapter on Ubuntu. Try the below link:
https://help.ubuntu.com/community/WifiDocs/Device/NetgearWG111
Hope this helps.
Regards
Anand
Apr 12, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Netgear WG111 USB adaptor does not work
-- check the device manager of your computer
-- for win xp - go to right click on my computer - manage - computer management - device manager - on the right hand side that the netgear adapter is listed under network adapters or other devices
-- check the status that its working properly
-- then upgrade the latest drivers ...
-- follow the link ::
http://kb.netgear.com/app/products/model/a_id/2556
and try to connect ..
Mar 26, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Netgear wireless adapter wg111t will not work work
It's impossible that the wireless router cannot detect your wireless adapter wg111t.
You try to test another one if still have a problem connecting with your wireless router.
If that router can see another wireless network available then maybe your Netgear wireless adapter have a problem incomplete installation or the wireless device is defective.
I have encounter like this before so maybe it's the same with.
Hope my tip will help you a lot.
Please rate me.
Thank you.
Sep 14, 2009 | NetGear WG111T 108 Mbps 802.11g Wireless...
Wirless adaptor only sporadically working
Do you know for sure that the usb port is working properly? Plug in a flash drive or a mouse and see if it's detected. If not, it's the usb port. Try another port. If no usb ports work, post a comment and I'll give you some things to check.
If the usb port works:
Unplug the nic, go to device manager and expand network adapters. Plug in the usb nic. If it doesn't show up in device manager, or if no new hardware is detected, then it's probably dead. Plug it into another pc to confirm.
Hope this helps!
Aug 26, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Windows enviroment I cannot get internet nor wireless or conectec give me errors
Go to device manager and make sure the wireless network adaptor is properly install. Also got to services and make sure the Wireless Zero configuration service is running. Go to network connection and setup the wireless connection again after deleting the old one. You may have to contact the wireless router manufacturer like Linksys, Netgear in case you are not sure of the settings
Oct 11, 2008 | Everex Computers & Internet
Netgear 108 Mbps wireless usb 2.0 adapter wg111t
i had the same problem. i tryed downloading the sofware from other computer and install it on the wireless computer. finally i just connected it directly to a lan line and update drivers with windows
Apr 08, 2008 | NetGear WG111T 108 Mbps 802.11g Wireless...
MIL-W1897L cannot install device
Not much of a solution, but keep uninstalling and re installing the driver cos win98 not very good for driver issues, i remember having to fiddle around with it with win98se also. Perhaps the device is recognised but not being installed because of a faulty slot or mobo fault. But personally I wouldn't go on-line with win98, would advise upgrading to xp sp2, much better with security and easier to sort out driver issues. Trying to forget Win98/SE, not very pleasant!
Oct 12, 2006 | Milan Technologies ShAir Access MIL-W1897L...
Open Questions:
See all NetGear USB 2.0 108MBPS Adapter 802.11 (DHWG111T) Questions
NetGear USB 2.0 108MBPS Adapter 802.11 (DHWG111T) Logo
85 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
