Question about Toshiba Satellite A105 Notebook
Toshiba A105 keeps Restarting ---
Toshiba A105 with WinXP will not boot. Press the ON button and nothing happens(suspect button not making good contact with ON Switch. After pressing ON button several times in different places the ON LED will light, the splash screen will appear for a moment then the sreen goes black. The power, battery, and ON indicator LEDs stay lit. The ON button LED stays lit while the system continually starts and turns off every 3-1/2 seconds without another splash screen.
Holding down the F8, F10, or F2 key gives no results. Depressing the ON button for 4+ seconds will not turn the system off. I Can not boot from the HD or DVDROM. The only way to stop the "restarting" is remove the battery. I have tried removing the HD in case it was causing an overload that might contribute to the restarting; no difference.
Do you know of anything that might help short of removing or replacing the motherboard? Your input is appreciated.
Walter
  • walter_yrle Feb 04, 2009
    Finally resolved the problem. The daughter-board micro switches all worked so I checked the buttons above the switches. The ON button was damaged and stays depressed causing the reboots. Filed the rough edge off the ON button and put a spot of airplane glue under the button directly above the micro switch. Problem solved
  • 70 Answers
Maybe the power input is error
the uncorrect power input will result bad
or, it's your mobo broken
Posted on Jan 25, 2009
I have a Toshiba A75-S2112 laptop. I hit the debug button when it was booting up and now it will not boot-up to anything. It just sits there with a black screen and the fan turned off. I am trying to...
The computer starts but, when you press a key, nothing happens.
You are probably in Standby mode and have a software or
resource conflict. When this happens, turning the power on
returns you to the problem instead of restarting the system.
To clear the condition, press Ctrl, Alt, and Del simultaneously
then select Shutdown, then Restart to restart the computer.
Mar 24, 2011 | Toshiba Satellite A75-S2112 Notebook
Toshiba A105 starts goes to winxp then blue screen comes on and computer keeps trying to reboot
this is quite a common problem usually down to dirty or loose memory module remove the power supply and battery from the laptop and then remove and re insert the ram and see if that helps ok
Jan 31, 2010 | Toshiba Satellite A105 Notebook
My laptop(Toshiba Satellite A105 - S2051) wont turn on with or without battery on a/c adapter. Adapter seems to have a charge but when i plug it in and try hitting the power button nothing happens. I do...
hi, this is tricky, as the machine does seem to freeze even before booting. the fan may have become stuck, use some compressed air with the fan inlet (bicycle pump may do) to clean out some dust.
wait some time and switch on again.
observe if the green lamps for harddrive and cd-drive light up.
if no, the computer does not boot up, it may be then that :
the fan is broke and laptop prevents overheat damage by not booting up(buy a new fan and replace it)
or the machine itself is broke
in either way, if the solution i provided did not help, i would recommend to see a technician!
good luck then
Aug 08, 2009 | Toshiba Satellite A105 Notebook
Problem with installing new windows OS on toshiba A105
You should put the drive back in the external caddy, delete the format, partition the drive for NTFS. format the drive and set as active.
Mar 24, 2009 | Toshiba Satellite A105-S2712 Laptop
Toshiba A105 will not boot up even with cd and f12
its not a booting issue if you hear the music, it loaded windows. you might have a display issue, shine a light on it to see if you can see any faint images, if you can the backlights out if not it might be the display adapter on the MOBO, in either situation calling toshiba would be required for a repair, or otherwise take it into a shop, but first try a power reset,
unplug it and remove the battery, then hold the power button down for one minute, replace the battery and power cord and try to boot again. if this fails call toshiba, its definately a hardware issue.
Jan 23, 2009 | Toshiba Satellite A105 Notebook
Computer will not boot up
if it doesn't do anything you either have a dead battery or a fried hard drive or your screen is broken, does it make any noise when you power on? try recharging it, that happen to me one time on my field (****) laptop i pulled the battery out waited 10 secs then put it back in hope that works
Jul 14, 2008 | Toshiba Satellite A105 Notebook
Problem restarting, "press r"
  1. Start the laptop
  2. when the logo screen turns black start pressing F8 a few times.
  3. A Windows Boot Options screen should show on the screen
  4. If you see the Windows Logo (the normal thing when Windows loads, then press reset and try again
  5. At the Windows Boot Options screen select "Last known good configuration" and press Enter twice
It "should" now load normally, if not then..
  1. Replace step 5 above with "Safe Mode" and see if that loads all the way through. If so, then restart and see if its OK now.
If not, then post back with any error messages and we can look at something else.
Apr 13, 2008 | Toshiba Satellite A105 Notebook
Toshiba a100 laptop
Definitely try without the battery. These models are known to have a "short" problem, usually with the palm rest, which causes this failure, although it usually is more sporatic, and doesn't happen 100% of the time.
Also, can you remove all but 1 piece of memory.
Good luck, and let us know what happens.
Mar 19, 2008 | Toshiba Satellite A105 Notebook
Ac led blue battery led amber will not power on
When The Light Is Blue You are getting Power To The Unit. Have You Tried removing the battery Leave The Power Cord Pluged Into The Side Of The Unit. Then Try To Power The Unit Up Again. If Nothing Happens. Chck The manual I Think There Is A Reset Button Somewhere On The Machine Most Toshibas Have Them Somewhere. Hope This Works
sosec
Boot failure
does it beep at all?
take it into a dark room, can you see anything on the screen, even if it's very faint?
take battery off and plug in same thing?
Jan 04, 2008 | Toshiba Satellite A105-S4004 Notebook
Toshiba Satellite A105 Notebook Logo
251 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
