Question about Escort Vehicle Parts & Accessories
Power reset code 9500ix - Escort Vehicle Parts & Accessories
How do I turn on HWy mode? ode
PDF]9500ix Owners Manual-Red&Blue*.indd - Escort
https://www.escortradar.com/pdf/9500ixOwnersManual.pdf
Here is how you would turn PASSPORT's. AutoMute feature off: ... based on vehicle speed, plus Highway and Auto No X settings. ..... Highway mode provides
Sep 20, 2015 | Cars & Trucks
Error code c4801 For C284e
You may have main board issues. Maybe Try error code reset.
Open front door and locate main power switch on the bottom left and turn off.
Press and hold the reset button , button on control panel.
Turn main power switch back on whilst pressing reset.
after 1 - 2 min a white screen with 1 button saying"error code reset will appear , let goo of reset button.
Press error code reset and then turn main power switch of for 20 seconds. turn main power switch.
If code returns contact me on my phone to discuss
Sep 02, 2014 | Konica Minolta bizhub Office Equipment &...
Ir 3300 000001-0002 error
Title : E001 Error Code That is Not Resetable Error : paper jam
When the machine powers up the E001 error code is displayed but cannot be reset. (Note: The reset procedure for an E001 code is COPIER>FUNCTION>CLEAR>ERR)
Workaround :
In this case, the Main Power Supply PCB Assembly was replaced. The machine was powered up and the E001 code was able to be reset. The part number for the Main Power Supply Assembly is FM2-0260-000.
Remember, if the fixing unit circuitry has an open or a short, the code may not reset. Be sure to confirm the fixing unit wiring and try resetting the code before replacing the Main Power Supply Assembly. Canon USA, Inc. Systems & Technical Support Division1-800-528-2830
Aug 13, 2013 | Canon Office Equipment & Supplies
Does the passport 9500ix unit have a fuse in the detector or the plug. I was unable to locate the typical fuse that's usually in the plug.
  • There is no traditional fuse inside your radar. The only one that is protecting the wire is in the plug that goes into your cigarette lighter / ACC outlet. If your fuse blew and you replaced it with another 2 Amp or 3 Amp fuse and are getting no response I would start with the fuse that provides the power fuse to the outlet you were using when it blew. But no quick blow style fuse inside your radar.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards,Tony
Oct 10, 2011 | Passport 9500i Radar/Laser Detector
Constant RPM engine static during alert on 9500IX on Gold Wing Motorcycle. Only accessory to ever give engine static. Use multiple Apple music accessories, GPS, bluetooth, 80 watt amplifier, CB and...
Most likely you will need to get a group loop isolator for it. I think escort sells one on their site. Or a good quality car stereo shop can get you one from Escort or PAC.
Dec 30, 2010 | 9500IX Radar Detector
Vehicle Parts & Accessories Logo
Top Escort Vehicle Parts & Accessories Experts
Jason
Steve
Are you an Escort Vehicle Part and Accessory Expert? Answer questions, earn points and help others
