KLH 12'' Subwoofer S200ETH blowes out fuse after replacing it.
I have a KLH Subwoofer model S200ETH everytime I replace the fuse it blows out. I took it apart and checked it nothing looks or smells burnt. I even tested the woofer to see if it was blown out but it is still working. Also the On led indicator does not turn on. Please help!?
SOURCE: Subwoofer just stopped working. There's power but no sound.
I have the same problem. My guess is that the subwoofer coil is messed up. You MIGHT have to get it recoiled. But before you do any of that get someone with a sub to play their sub in your car, if it works.... then your sub is messed up, if not.....then your amp is messed up ( trial and error ). Today i noticed my subs rubber surrounding is crooked, that may be the problem for me. Also when I press down on the sub it makes a sticking sound, like something came loose. So once i get everything opened and out ill let you all know the solution. Good Luck!
Posted on Apr 10, 2008
  • 3 Answers
SOURCE: AR1 Subwoofer Keeps Blowing the 5 Amp Fuse
Well, so far so good. I reinstalled the newly repaired amp and fired it up and so far, so good. Ran it through about an hour of fairly intense break-in tracks and then ran it through about 2 dozen power up and down cycles to try to get it to fail (better now than a month from now and have to fight them on backing it up).
Posted on Nov 13, 2008
  • 5 Answers
SOURCE: loud humming buzzing sound coming from subwoofer
make sure you have the speaker connection right if you do then it is a ground problem try plugging it in a different outlet
Posted on Dec 16, 2008
SOURCE: KLH ASW10-120 Subwoofer My KLH ASW10-120
Did you ever find a solution for this problem? I have the exact same thing happening with my KLH subwoofer and I'd love to know how to fix it!
Posted on Jan 26, 2010
SOURCE: Polk Audio PSW202 subwoofer.
Fuse probably went bad because either the large filer capacitors at the edge of the PCB went bad and or the final output IC mounted on the heatsink(15 pin) fried. Check the capacitors and all the semiconductor components on the board for burn marks or corrosion. You have to remove the heat sink clamp from in front of the output IC to adequately visualize its condition. In fact you might have to remove the large aluminum heatsink attached to the chassis to get a good view of the IC. If it or the heat sink clamp show signs of thermal burns you need to replace it. The IC is a TS TDA7294 mono audio amp available at Mouser Electronics. Replace the 35V 4700mF caps with 50V 4700mF caps. You will only have enough space on the top of the PCB for one of the larger caps. I mounted the other on the circuit side of the board. Note the polarity of the original caps and respect it in their replacements. The fuse is a 5 X 20 medium speed slow blow 250V 2.0A glass fuse.
Posted on Dec 02, 2011
Klh subwoofer keeps blowing it's fuse.
Most likely the amp in the sub has blown. It will need repair or replacement. I'd take it to an expert in repairing amps, it's not a job for you unless you're experienced in troubleshooting these things.
Dec 31, 2014 | KLH Audio Players & Recorders
I replaced the fuse in my subwoofer and it blowing them. If i switch it to a 3amp will that sovle the problem.
Check out this thread
http://www.fixya.com/support/t2753393-klh_subwoofer_about_6_yrs_old_keeps
Nov 30, 2010 | KLH ASW10-120 Subwoofer
My model 765S KLH powered subwoofer keeps blowing fuses (2 amp). Is it fixable and is it worth fixing?
I saw this post. I have the same problem with my 10-100.
Nov 13, 2010 | KLH ASW10-120 Subwoofer
Subwoofer keeps blowing fuses.
THE AMPLIFIER "IC" MAY BE SHORTED!
IC MAY NEED REPLACED.
Apr 10, 2010 | KLH ASW10-120 Subwoofer
KLH subwoofer Model BASSBite V. Has a bad 60Hz buzz
Before you go throwing money at this problem, try to eliminate any external influences like track lighting. I myself am trying to figure out why mine makes a buzz throughout my system when the lights are on. I already replaced the variable light control with no improvement.
Bad cable ground can let airborne electronic noise into the Sub's amp.
Jan 31, 2010 | KLH ASW10-120 Subwoofer
Have the KLH ASW10-120 Powered Subwoofer and it is blowing fuses
If it stays on for 3 seconds then it probally is not the transformer. However it may very well be the power amp no way to tell untill we operate. Call Pro Line Music 215-736-8055
Dec 11, 2009 | KLH ASW10-120 Subwoofer
How do I fix a blown amp
big red
check usually the fuse just blows up just change it
Oct 22, 2009 | KLH ASW10-120 Subwoofer
It keeps blowing fuses - two 12 inch cls subs 1
sounds like the audio stage riving the channel has a short circuit on it.need to go through the amp stage
Jul 16, 2009 | Cerwin Vega CLSC-12S Subwoofer
Klh powered subwoofer keeps blowing fuses?
then the circuits took a hit and the fuse didn't do it's job in the 1st place. best is too get new circuit thats inside the sub woofer.
sorry to be the bearer of bad news
Apr 26, 2009 | KLH BB-II Subwoofer
Fuse blows when powered on . KLH E-10DAW
Hi, you can get the fuse at Polk Audio. 800-377-7655. You can talk to technical, too.
Jan 20, 2009 | KLH Audio Players & Recorders
548 people viewed this question
 Grubhead
Grubhead
