Question about Desa International Wall/Window Air Conditioner
We have propane fire place an recently when we use it it is getting a black suit all over the fire place. my step dad thinks it is not burning hot enough but we dont know what the problem is.
Vacuum up all the ash and clean up around the burner specially where the holes are at from the wall. it needs fresh air for the gas to burn properly. your step just had to take another step cuz he was on the right path LOL
Posted on Jan 25, 2009
    Novelist:
  • 88 Answers
Thanks for your Question,
Black soot is the by product of incomplete combustion, with Propane you will get alot more soot than with Natural gas, you need to look at how the flame are hitting your log set, if you have alot of soot on them you will need to reposition them as to not let the flame impinge on them causing the sooting affect, you will also need to check the burner for any type of blockage on them, clear off any thing that is on them, also you will need to check your venting for any blockage, I would also recommened you use a product called (rutland white off) it is a fantastic cleaner for fireplace glass, please do not use windex or cleaners of that type as they will cause a rainbow affect on the glass after heating to a certian point, hope this was helpful to ya, please rate this and let us know how we did, thanks again,
mr.grzz
Perfecta by winrich
remove battery cable step on brakes ,,place cable back on done
Dec 09, 2013 | Heating & Cooling
Electrolux gas range broiler burns food
Hello Chris Collins - Sounds like the range may be experiencing an issue with a communication error with the EOC, wiring failure or the cycling thermostat. Contact a professional to move forward accurately.
Jan 04, 2013 | Electrolux EW30GS65GS 30" Slide-in Gas...
I have a King Pellet Stove 5510, I think the ignitor is out. It's going to be cold tonight and until I can get a new ignitor, can I start the pellets with something else.
If you have a hand held bottled type, propane torch, you could carefully try that. However, never ever use any type of liquid starter, like charcoal lighter fluid, kerosene, etc. All you want to do, is get a cup or so of pellets started burning hotly and let the auger take over feeding the fire from there.
Be extremely careful doing this.
Hope this helps you stay warm tonight.
Apr 16, 2011 | Heating & Cooling
Grill doesnt get hot it burns on low it starving for gas
blocked gas line / reg not working/blocked burner orfice needs cleaning , try these
May 22, 2010 | Char-Broil Advantage 463453306
I have a napoleon wood fireplace, I just installed it in a fireplace. It seems like I can't get any heat out of it. I installed a cheminee liner up the cheminee. I think that the heatloss is going up the...
an open fireplace is not going to heat your house only 5 feet in front of the fire place. 75% of the heat goes out your chimney and burns the wood very fast. sorry to say but if you are looking for heat you installed the wrong unit!
Dec 14, 2009 | Napoleon 36" Zero Clearance Top/Rear Vent...
I would like to buy one but I want to make sure it works for ice--the only reason I need the dual turbo propane torch kit
Ice doesn't argue much with any heat. Get one of those propane torches they use for roofinfing and heating tar,or burning weeds. I think I paid 29.00 and it puts out a wall of fire an iceburg would run from. Pardon the pun "run"
Oct 28, 2009 | Northern Tool Dual Turbo Propane Torch Kit
Black soot on Coleman propane burner
Had same problem. Coleman tech support said, " clean with pipe cleaners". No directions....I would think they would provide a step by step protocol. So, I chose to take the knobs off and use the pipe cleaner where I could. I was able to take one of the two burner control knobs apart. After sticking the clean in every nook I could find, I put back together, and the flame on that burner is back to normal,
Good Luck--Daryl in Burnsville, MN
Sep 11, 2009 | Coleman Grilling
Desa International Wall/Window Air Conditioner Logo
557 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
