Question about Onkyo TX-8511 Receiver
Onkyo tx-8511 protect mode - Onkyo TX-8511 Receiver
SOURCE: Onkyo tx-sr800 PROTECT mode
Hold video1 and press speakers A button, it will say "clear" If the message protect appears again, then its service time.
Posted on Sep 05, 2007
SOURCE: Protection mode
I banged my head against the wall on this same issue and finally realized that my rear surround speakers were mixed. My rear right was wired to rear left because I was turning around to see L and R. It would shut off at about volume level 40, which was loud but not rumbling. It now ROCKS and is in no way a problem with heat. I have always run it with the cabinet open to allow air to circulate.
Posted on May 30, 2008
SOURCE: Onkyo Tx-v940 Receiver/Amplifier Protection Mode
Audio amplifier IC's damaged you need to change it.Good luck
Posted on Jun 11, 2008
SOURCE: stuck in protect mode
i believe protect mode is because you have the wrong impedence speakers, they are too low (4 ohm? 6 ohm?) it chols work with 8 ohm speakers
Posted on Dec 11, 2008
lynchms
  • 93 Answers
SOURCE: Powered Or Unpowered Subwoofers For Onkyo TX-8511
Greg- Powered subs are better than non-powered subs (also known as passive subs), anyway I see the TX-8511 has no sub pre-out on the back panel, so you need to decide what sub you will use and run from the receivers left and right speakers output into a subwoofers speaker in from speakers then back out to speakers, look at the back of a subwoofer and you will see like 4 sets of speaker hookups 2 in and 2 out, what this does is takes the low end or bass and drops the signal to the subwoofer then takes the mids and highs out to your left and right speakers, unless your regular left and right stereo speakers have large woofers a sub is the way to go.
Posted on Jan 28, 2009
My ONKYO tx 8511 is protect mode How to reset
Hi Vinoth, if this has not been resolved I would advise you to disconnect the unit from the AC Outlet for at least an hour and then see if it is out of Protect Mode, Thanks, JT
Nov 19, 2015 | Onkyo Audio Players & Recorders
How to connect Sony dvd player to onkyo TX-8511 receiver
The TX-8511 is an older AV receiver with only composite video inputs. Your DVD player may not provide this type of output as it's not capable of HD video. If your dvd player has a composite output with a Red, White & Yellow set of outputs, that will connect into the Video 2 inputs on the receiver. Your TV will need to connect up to the Video2 or Monitor output. You'll need a set of composite video cables with the red-white & yellow RCA type plugs.
Here is a link to the manual for this receiver:
Receivers Receiver Stereo Receiver AVR TX 8511 Onkyo USA
Mar 13, 2015 | Onkyo TX-8511 Receiver
My receiver is in protect mode..what does that mean
See reasons for protect mode on onkyo site.
Most likely the speaker wires are shorting or are reverse polarity. see connection diagram.
Jan 19, 2011 | Onkyo TX-8511 Receiver
How do I connect my Samsung Model un46b8000xf led to onkyo receiv
Use the TOSLINK - the optical/digital connector on both devices.
Jul 07, 2010 | Onkyo TX-8511 Receiver
My onkyo tx8211 stay on a stand by mode. I can
If it's anything like my Onkyo surround receiver, pressing any input selection will turn on unit.
May 16, 2010 | Onkyo TX-8511 Receiver
I was playing this one song I liked really loud
More then likely you damaged the amp and it will
need to be serviced!
Mar 16, 2010 | Onkyo TX-8511 Receiver
I just hooked up my old Onkyo TX-8511 receiver to my bose speakers, which is also hooked up to a subwolfer. When I turn the volume up the system goes into protect mode. Any solutions.
Just check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Rewire if necessary..
Are you using banana plugs for connecting speaker or just directly. Some times even a little tiny wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
Otherwise, do your bose speakers play out load on other systems?
Mar 08, 2009 | Onkyo TX-8511 Receiver
Jan 28, 2009 | Onkyo TX-8511 Receiver
Aug 28, 2007 | Onkyo TX-8511 Receiver
Onkyo TX-8511 Receiver Logo
42 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
