Question about Panasonic DMR-EH65 DVD Recorder/HDD Recorder
Panasonic EH65 HDD/DVD
Whilst playing a DVD, the player froze and was switched off using the remote control. The unit will not power-on now!. Any help would be appreciated. Thanks
    Genius:
  • 2,985 Answers
Dis connect from the mains- wait a while then re connect what happens?
Posted on Jul 12, 2007
SOURCE:
Hi, I recently purchased a Panasonic DVD S48 dvd player. I was assuming when I bought it that it was a multiregion product. This seems not to be the case as it will not play region 1 dvd's that I...
hi Pjkgbr.
this is all i could find out, now if you do try this do so at your own risk.
This hack requires the S48 remote plus a universal remote configured for the S48 with a separate 'Pause' button (or another Panasonic DVD remote with a separate 'Pause' button may work).
I used a cheap universal remote.
1. Select DVD device on remote.
2. Hold magic button until the DVD button blinks twice.
3. Enter device code 0490 (DVD button blinks twice)
Neither the 'Play/Pause' nor 'Frame' buttons on the S48 remote work for this hack.
1. Power on.
2. Open tray.
3. Using the S48 remote press Audio, 1, 9, 8, 2, Subtitle
4. Using the other remote (URC 7562) press Pause.
5. Using the S48 remote press 0.
The DVD front panel should now show the text "on".
The DVD should now be region-free. Region code hack posted by spook65, December 12 2012:
DVD-S48EG-K (Region 2)
This is the process for unlocking, the Panasonic DVD-S48 for
multi-zone.
Please note, you will need a universal remote control which
has a PAUSE button in order to unlock this player.
1. Turn the power ON
2. Open the disc tray
3. Using the remotes, press AUDIO 1 9 8 2 SUBTITLE PAUSE 0
4. Switch the player to STANDBY and then switch ON again.
The display should read ON after you enter PAUSE 0.
If this doesn't happen, switch the player off and start the
sequence again.
The remote supplied with Panasonic player has a PLAY/PAUSE
button rather than a separate PAUSE button. If you use the
PLAY/PAUSE button, the tray will close and the unlock
sequence will be aborted.
To get round this, you need a universal remote set-up to use
with the DVD player. After pressing SUBTITLE on the
Panasonic remote, quickly press the PAUSE button on the
universal remote, then press 0 on the Panasonic remote to
complete to unlock code entry.
or this one.
What is the process for Multizoning a DVD-S38 / DVD-S48 / DVD-S58 / DVD-S68 / DVD-S500 / DVD-S700 DVD Player? Providing your DVD Player is one of the below models, you can multizone the unit yourself using the remote supplied with the product and another Panasonic product remote thas a Pause button on it
Applicable Models:
Multizoning Process:
1. Power on the unit and open the disc tray
2. Using the remote that came with the player, press the following buttons in sequence
3. AUDIO 1 9 8 2
4. SUBTITLE
5. Using the other Panasonic Remote (not the one that came with the player), press the PAUSE button
6. On the remote that came with the DVD player, press the 0 (zero) button
7. If you have followed the above process correctly, the word ON should be shown on the front panel display of the player*1
*1 Please note: The models DVD-S500 and DVD-S700 do not have a front panel display,
so the only way of confirming that the multizoning process has been done correctly, is to
try playing a DVD disc from another region code other than region 4
Dec 05, 2017 | Televison & Video
Hello, I have a Panasonic DMR-EH65 DVD with HDD, when pressing any button on the remote control the display says DVD3, machine will not operate, took it apart to check for any bad connections, reassembled...
You could try Changing the Remote Control code for your DVD recorder. If you have more than one Panasonic device, there's an option to give each device its own Remote Control code. The Default is DVD1. So for FixMick, it sounds like someone may have changed the Remote Control code on your machine to DVD3. For Dador, someone may have changed the Code to DVD1. So you'll need to change the Code on either the device or the Remote to make them match up (see page 19 of the DMR-EH65 Users Manual ... you can download it from the Panasonic website)
Sorry FixMick. I don't know why your display isn't working.
Mar 15, 2009 | Panasonic DMR-EH65 DVD Recorder/HDD...
The remote want do anything all the player says set 1
Try leaving the batteries out of the Remote overnight and un-plug the plyer from the wall for 10mins (this "hard re-sets" both items)
Dec 17, 2008 | Panasonic DMR-EH65 DVD Recorder/HDD...
"NO READ" on Panasonic DMR-EZ27 DVD Recorder
good day 2 you,, ,, i have some little advice on you,,
just open the top cover of your player and check the RIBBON WIRE of the LENS/EYE part then clean theGOLD FINGER/LINES
and get some clean cotton buds and a lighter fluid 2 clean the lens,,,,,ok,,
PS. dont use cd cleaner fluids,,, that wont clean, , , , , ,just lighter fluid ok!!!
GODBLESS U
Sep 22, 2008 | Panasonic DMR-EH65 DVD Recorder/HDD...
Panasonic HDD 40 Gb videocamera
its just your usb cable or the software reader you use,,,,,
Sep 03, 2008 | Panasonic DMR-EH65 DVD Recorder/HDD...
DMR-EH65 DVD
just bring it to service man near you coz that is IC problem
Apr 23, 2008 | Panasonic DMR-EH65 DVD Recorder/HDD...
Replacing the HDD
hellow
before you replace your hdd ,,
step1. format the new hdd on the pc FAT system
step 2 . set the player 2 default set then replace the hdd..
reply this post when not work
Apr 20, 2008 | Panasonic DMR-EH65 DVD Recorder/HDD...
Dvd player
Where can I find a battery and power cord for dvd player model pdv288
Oct 15, 2007 | Panasonic DMR-EH65 DVD Recorder/HDD...
Panasonic DMR-EH65 DVD Recorder/HDD Recorder Logo
186 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
