Question about JVC AV-48WP30 48" Rear Projection Television
Bowed flickering green screen, black on bottom
I have a JVC AV-48WP30 48 in projection television, about 8 months ago the upper left and lower right hand corners were separating. The upper left corner was more red and the lower corner was more green. There were some shadowy lines running through the screen at the top as well. I ignored it and today when I turned it on, the screen was a flickering mess, it was bright green on the top and black on the bottom. The green looks like part of a circle. I am not sure if this is something I can repair myself, or if it is worth it. If I can repair it myself (I am very handy with solding and other stuff) what parts should I replace and what part numbers are they?
  • JVC Master
  • 3,459 Answers
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
7859Bowed flickering green screen, black on bottom - e87380c.jpgass=
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If itBowed flickering green screen, black on bottom - 69189a5.pngix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Posted on Jun 06, 2010
Purchased this 56" projection TV
You can get it repaired. Its maybe a resistor/s thats losing its value and needs to be replaced.
You can locate this on the mother board close to the or near to the Fly-back transformer section.
Good luck.
G.
Aug 03, 2011 | JVC AV-56WP74 56" Rear Projection...
Have a JVC AV-48WP30 rear projection tv set and the green seems to be out of place. the green image is lower than the others and is in a wave shape on top of screen and bottom.When I adjust the convergence...
Your convergence IC's are bad. If your not doing the work it will probably cost in the neighbor hood of $250.00 for a service company to do. Not a major repair.
Nov 03, 2009 | JVC AV-48WP30 48" Rear Projection...
Laptop screen has been invaded by green and red/purple germlins
haveyou tried shutting it down and restarting it? it may just be the screen going bad
Jan 26, 2009 | JVC AV-48WP30 48" Rear Projection...
Cheap Fix?
I will strongly advise you to replace the two STK392-120 as a pair. and this will cure your bowing picture problem. You may need to re-converge your set. best of luck.
Nov 05, 2008 | JVC AV-48WP30 48" Rear Projection...
Me again
With the bow in it it's likely the convergence has failed... Where did you purchase the amps that you put in it? Did you use a good heat sink grease to mount them?? Did you really scrutinize the resistors in the feed and return circuits???
Bill
Mar 31, 2008 | JVC AV-56WP74 56" Rear Projection...
Screen is bowed (top and bottom) Color has a green and purple tint?
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Here is an example video
utube.png You-Tube video "9oI1Nzq7CR8" placeholder (do not delete) utube.png
Jan 15, 2008 | JVC AV-56WP74 56" Rear Projection...
JVC 48WP74 HDTC rear projection
While it is true JVC tubes rarely fail, they can give trouble.
Another possible solution is bad screen / focus block......
Remove lower front grill panel and access board...Check for
smooth adjustment of RGB screen and focus.....let me know....T..
Sep 28, 2007 | JVC AV-48WP74 48" Rear Projection...
Weird problem not convergence
Mine is doing the exact same thing! have you found a fix yet?
Apr 23, 2007 | JVC AV-48WP74 48" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
149 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
