Question about DuroMax Duro Max XP4400-CA 4400W 7 HP RV Generator Wheel Kit CARB
What type of oil to use for a 4400 duro max generator
Should i use a differrent oil in the winter
What is the valve clearance on a duro max XP10000e generator?
0.015 inches intake and exhaust, if not running right 0.020 inches for exhaust.
We also we sell parts if you need them :)
https://www.generatorguru.com
Apr 08, 2017 | Electrical Supplies
Oil type
If you are asking about the engine oil, generators like the 10W 30 weight oil, which is good for winter and summer use. . The brand doesn't matter to any gret extent. Just don't buy the el cheapo brand in the dollar store.
Jun 02, 2014 | Groove Tubes Power Back 5,250-Watt...
Duro max xp4400 generatol is not producing electricity
Check power going to the breaker. Check the brush conditions and the trace condition.
May 14, 2013 | DuroMax RV Grade 4400 Watt 7.0 Hp Gas...
What oil wieght oil does the powermate 5000 use
a 10-30 multi weight oil should work fine, in the winter, if it gets cold there, a 5-30, if it gets super hot in summer, a 10-40
Mar 10, 2013 | Coleman Powermate Portable Generator...
What type oil needed for 10 hp tecumseh engine on coleman powermate generator
Hi tmiangston...
You can use 10W30 during the winter, (if you have cold winters)...10W40 during the summer
Please take time to rate me
Aug 12, 2011 | Garden
What type of oil do I use 1850 pm0401850
Oil Type. Use new good quality oil such as SC, SD, and
SE grades. The oil to be used depends upon the temperature
at which the engine is operated:
Summer: (temperatures of over 40 degrees F/10 degrees
C) SAE 30 or SAE 10W-30, SAE 10W-40
Winter: (temperatures of below 40 degrees F/10 degrees
C) SAE 20 or SAE 10W-30
Manual here:
http://www.powermate.com/pdfs/2007/11/12/pm0401850-52.pdf
Sep 12, 2010 | Coleman Powermate Powermate 5000W...
Wht weight oil does a 5700 take?
allot the generators take 30 weight but thats a guss in the winter i had go with light weight.
i am on my second colman i lived woods for years with no electrci other generator 30 weight is heavy stops less wear tear on the insides. But winter time comes i had go lighter becuse oil was like malassas. And then i could not pull it to start it was so thick and heavy the oil in winter
go there web site look up ore try 1800 number for them to get
Jul 28, 2009 | Electrical Supplies
DuroMax Duro Max XP4400-CA 4400W 7 HP RV Generator Wheel Kit CARB Logo
108 people viewed this question
Top DuroMax Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a DuroMax Electrical Supply Expert? Answer questions, earn points and help others
