Question about Intertherm P3RA-048K Air Conditioner
A Good Fit and a good quality air filter
I always seem to make up something that will fit good and will filter good.Any off the shelf good filters for the Intertherm gas furnace
    Guru:
  • 462 Answers
The kit I have seen is a foam filter that coveres the inside of the furnace or air handler door and has soem wires to hold it in place when off. This can be made easily if you have a welding supply close by buy some 1/8 inch steel wires and bend to fit your door. bend the ends at 90' the the rest of the wire and put the ends behind the door and the filter between the 2. Hope this helps and please rate me accordingly. Good Luck
Posted on Mar 12, 2009
I have air in my fuel system in my 20dti Vauxhall zafira after I changed filter need to fit hand primer
hi anon,if you have just changed the filter,check you have replaced both rubber seals,the small one for the screw,and the large one for the filter housing,if both ok,a quick squirt of easy start into the air intake always works,literally less than a second ,is all you need,good luck
Feb 22, 2015 | Vauxhall Cars & Trucks
Tip
How to Change the Water Filter on a Refrigerator?
The procedure is as follows:--.
1) Locate the water/ice filter in the back of the refrigerator. Its located at the far back of the top shelf.
2) Carefully remove anything on the top shelf of the refrigerator that is in the way of the filter
3) Then remove the housing of the filter You will have to twist it and remove the housing.
4) The housing will have small arrows showing which way to turn.
5) Now remove the existing filter from the housing and throw the old filter.
6) Insert the new filter in the housing.
7) The fit all the parts you removed in reverse procedure.
This will help.good luck.
on Mar 15, 2010 | Refrigerators
Cabin changing filter
Easy, just unhook the glove box so it opens to the floor. There is lid there that has easy releases that you pinch on the ends to pull out the frame and filter. Amazon has good prices on quality filters, I get the TYC filters.
Jul 28, 2014 | 2007 Honda Fit Sport Hatchback
Air box
Because the K&N filters are much less restrictive than the original airbox and filter, the bike may run lean, and you MAY have to have the carb jets reworked/changed.
May 20, 2010 | 1995 kawasaki Zephyr 1100
Does the 52mm filters fit a Canon AV1 35mm SLR?
Filters fit lenses, not cameras. Some lenses take large filters, others take small filters. Many lenses have the filter size inscribed on them near the front, followed by something that looks like a Greek phi (a circle with a line through it). Alternatively, since the size is the diameter, you can always measure the lens with a ruler to see how big the diameter of the filter mount is.
Mar 20, 2010 | Canon AV1 35mm SLR CAMERA SPARES OR REPAIR...
I have a Kenmore Progressive 295 air purifier. I
Hi, are you sure about amazon?! I found your part there for 15$ (less than your budget of 25-30$). Take a look again here:
Amazon com kenmore charcoal filter. I hope this was helpful. Cheers
Jan 04, 2010 | Kenmore 295 Air Purifier
Can not find filters to fit and support to hold filter to prevent filter from being sucked in to unit.
what I have used to prevent the a/c filter from being sucked into unit was a section of wire shelving (found at local hardware store) use linemans pliers or side cutters to cut the shelving to size to fit in specified filter area
good luck
dave
Jul 16, 2009 | Heating & Cooling
'51' plate renault megane expression pos. fuel fault?
i had the same problem it was the mass air box its a thing that fits into the air intake after the air filter costs about £100 new from euro parts less from a car junk yard and you can fit yourself in about 1 hour or less, you have to remove air filter and engine cover and at the back you will see a pipe about 50mm dia with a plug going into it unplug this and remove circlips fit new part reconnect the plug and circlips and car should run fine refit cover and filter this is also the part problem when your car will not rev same on citroens and other french cars
Jul 05, 2009 | 2005 Renault 18I
Wrong oil filter installed
it needs to be changed NOW. you are very lucky it has not blown off yet.good luck.
Nov 24, 2008 | 2002 Chevrolet Cavalier Coupe
GOODMAN ARUF3642
These guys list the actual sizes of a good selection of goodman filters - just measure the old one or the space where it should be and match it to the right filter(should be a fairly tight fit). http://www.filters-now.com/products/dgb.html#skipmenu and this site describes what the different filter types available are http://www.oxyclean.com/goodman.html Hope this helps :)
Mar 07, 2007 | Goodman CLQ36AR49 Air Conditioner
Intertherm P3RA-048K Air Conditioner Logo
118 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
