Hello! My rheem natural gas-powered pool heater isn't working and yet we have lit the pilot light. Any sugesstions, please? Thanks.....
  • mopar440man May 11, 2010
    does the pilot stay on.
  • 30 Answers
Make sure the pilot light stays on. look for a reset button which could be an overheat stat tripped. check to see if the thermostat is set up above the pool temperature.
Posted on Mar 26, 2009
Pool heater sparks but does not light up
coud be several things, Do you have Gas and is gas toruned on. Is valve on. The Pilot could be dirty and need cleaned. $350+ sounds reallly pricy for a pilot assembly. Call your Gas Company and get an Estimate and a Qualifed Service tech. You may try turning Off the Power to the Heater Unit and turning it back on , and then trying to turn on heater again, So times after several atemps the valve will lock out and the power needs reset on Propane units.
Jun 28, 2010 | Rheem 266K to 399K BTU Swimming Pool...
I have a natural gas pool heater. When I release
Replace the pilot generator. For a quote on the part, send us your heater make and model using the contact form at www.arrowpools.net
Jul 16, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
We had a power outage. now the spk keeps buzzing but furnace wont start. There is flame at the pilot, I can see it. But it won't start the main heater. eventually the PLT message comes on.
The 'thermocouple' might not be working. Is the pilot light staying lit? The therm. sends a millivolt signal to the control insuring a pilot is lit.
Jul 09, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Rheem Pool Heater Clicks
see if gas is on if ok check to see if cobwebs if ok see if voltage to gas valve when cycling
May 24, 2009 | Solar Rheem Gas Fired Pool & Spa Heater...
Millivolt pool heater will not ignite
Most heaters do not require power for the pilot to remain lit. Is there power at he unit? If it worked yesterday and not today has anyone turned it off at the circuit breaker? If you have power turn the gas valve off for 10 minuets and then relight to see if it needed a reset.
May 23, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot light wont lit up
Change The Thermostat Cause If Your Getting Gas But The Water Heater Doesn't Detect The Heat It Will Close The Valve. When Lighting You Hold The Button Down For About 30 seconds so the thermostat will detect flame and stay lit. Check To Make Sure The Thermostat Is Where It Should Be. Heres A Picture Of What It Will Look Like.
You Can Replace Them If Need Be Will Be Available At Sears Or Home Depot. Also They May Sell Them At other Local Hard Ware Stores.
Happy Fixing And Thanks For Using Fixya.com
Sincerely,
Michael Scott
Jan 19, 2009 | Vanguard International Vanguard BY Rheem...
Heating & Cooling Logo
60 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
