Question about Braun Thermoscan Pro 4000 Ear Thermometer
How do I change from centigrade - Braun Thermoscan Pro 4000 Ear Thermometer
22-7080419 WS. How do I change it from Centigrade to Fahrenheit, and to set the temperature?
I can not find that number on the Williams-Sonoma website . the only one that shows with dual temps has a button on the front to change the settings from centigrade to fahrenheit
Nov 26, 2015 | Williams-Sonoma OXO Digital Leave-In...
Change remote to centigrade,accidentally knocked to Fahrenheit
Press both up and down buttons for few seconds it will change to centigrade mode.
Sep 02, 2015 | Heating & Cooling
Lg gr 282mvf shematics
You will need a tech to check everything properly.
Jul 13, 2014 | Refrigerators
Write a computer program to change fahrenheit to centigrade
'Convert fahrenheit to centigrade
dim cent as int
cent = Val(Text1.Text) // Text1.text as your input
cent = cent - 32
cent = cent * 0.5556
Text1.Text = cent // Converted and changed the same textbox
Feb 21, 2014 | Microsoft Visual Basic 6.0 for PC
How do you change from Fahrenheit to centigrade
degrees centigrade; C = ( F - 32 ) x 0.56 F = degree fahrenheit
Jan 15, 2013 | Cars & Trucks
How to change outside temperature guage from F to C
You can switch the temperature mode
between Fahrenheit to Centigrade as follows:
While pressing the OFF button, press the
AUTO button for 3 seconds or more.
The display will change from Fahrenheit
to Centigrade, or from Centigrade to
Fahrenheit.
Feb 04, 2011 | 2011 Hyundai Elantra Touring
Changing temp readout on Midea Air Con Controller from F to C
  1. Make sure the unit is NOT on lock mode
  2. Press reset button for 2 second or until the Flashinf "F" appear on the temperature display or panel.
  3. Press Add button to change from Fahrenheit"F" to celius "C".
  4. Then press confirm and then cancel button to finish.
Jul 09, 2010 | Heating & Cooling
Temperature in centigrade in my car
Their is a button on dash on insterment cluster that says "metric" press button and cluster should change back to standard , depends on year of vehicle , some can be changed using drivers information center on dash. ( got an owners manual? )
Apr 23, 2009 | Buick LeSabre Cars & Trucks
Braun Thermoscan Pro 4000 Ear Thermometer Logo
Top Braun Home Experts
Donni Steen
Tom Chichester
Are you a Braun Home Expert? Answer questions, earn points and help others
