Question about Intermatic EH40 Energy Controls - Electronic Time Switches - Water Heater
Heater controls don't work
My buttons on the heater control for changing the heat from defrost to vent to the floor do not work, it basically blows out all three areas at the same time. What is the problem.
    Problem Solver:
  • 12 Answers
The aperage at start up when you turn on the heater are to great. The load at start up is greater than when it is actually running which in my opinion means the load is greater than the EH40 amperage rating is. In short term, the EH40 contacts are not able to handle the load. You need a higher rated control, it wasn't sized up correctly by your vendor,
Posted on Jan 25, 2009
A/c and heat dash vents won't work but all others are fine
check the actuator motor on the heater sounds like the motor is not directing the air as it should. The motor is in the center of the truck inside attached to the heater and has arms on it to move the heater and ac doors.
Jul 05, 2014 | 1999 Chevrolet Silverado 1500
1996 Montero Heater Blower not working
I assume your heater setting is electric control, if so either your defrost and floor heat switch failed or wire problem. For the air not hot, check the heat control valve on the top of the hose it should be in front of the firewall. I don't know your car is using mechanic valve or electric control valve. Anyway check there first. Good luck.
Nov 24, 2013 | 1996 Mitsubishi Montero
My heater does not blow in floor in a dodgeram 1500
the heater vacuum motor and lines needs to be checked.Also get the blend door checked.
NO HEAT ON FLOOR VENTS
As per your problem mentioned. There are few solved help links to troubleshoot these problems. Go through the list and Click the link below:----
2000 Toyota Avalon: No heat on Passenger Side?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-avalon-no-heat-on-passenger.html
No heat on Oldsmobile Silhouette?
http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows cold?
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
Hot air on the driver's side vents only?
http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
Temperature gauge does not move and no heat when heater is ON?
http://technoanswers.blogspot.com/2012/01/temperature-gauge-does-not-move-and-no.html
1992 Toyota Camry: A/C Control light Flashing and A/C not Blowing Cold?
http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
No heat, blower blows only cold?
http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
Ford F150 Ac only blows through defrost vents?
http://technoanswers.blogspot.com/2012/01/forf-f150-ac-only-blows-through-defrost.html
Dodge A/C come out of defrost vents only?
http://technoanswers.blogspot.com/2012/01/dodge-ac-come-out-of-defrost-vents-only.html
Ac vacuum line on dodge cummins?
http://technoanswers.blogspot.com/2012/01/ac-vacuum-line-on-dodge-cummins.html
Ford ranger AC blows cold through defrost vents instead on cabin vents?
http://technoanswers.blogspot.com/2012/01/ford-ranger-ac-blows-cold-through.html
2005 Chrysler PT Cruiser: A/C Blows Warm?
http://whoisbyme.blogspot.in/2012/06/2005-chrysler-p8t-cruiser-ac-blows-warm.html
2009 Mercury Grand Marquis: A/C blows Cold From Defrost Vent Only?
http://whoisbyme.blogspot.in/2012/06/2009-mercury-grand-marquis-ac-blows.html
AC not blowing through Vents on 2007 Chevy Trailblazer?
http://schematicsdiagram.blogspot.in/2012/04/ac-not-blowing-through-vents-on-2007.html
Passenger side temperature is warm air out of dash vents?
http://schematicsdiagram.blogspot.in/2012/04/passenger-side-temperature-is-warm-air.html
These will help.
Thanks.
Nov 28, 2012 | Cars & Trucks
04 Buick Regal Heater blows cold And will not cycle on defrost,floor or vent
if it doesnt switch you may have a vaccum leak, but i work for a junk yard and we seel alot of heater controls for this car you may want to get a new or used one from a junk yard
Mar 26, 2012 | 2004 Buick Regal
Heat wont blow through heater or defroster vents
common problem, check under dash by the gas pedal if control arms are muving went selecting from ac to heat cuz this it is the control for the vents to go from ac to heat and to defrost.
Jan 18, 2009 | 1997 Chevrolet K1500
Heater control 98 chevy s10 blazer
These trucks have a problem where moisture builds up in the heater box then freezes. When this freezes and you change your heater settings it breaks the shaft for the blend door. If this is what happened you should be able to look under the dash above and to the right of the gas pedal and you will see two vaccuum accuators one of them you should be able to wiggle around the linkage if it is broke. To fix this you need to remove the entire dash to get the heater box out which involves discharging the AC and draining the coolant because the heater core and evaporator come out. Please rate.
Dec 13, 2008 | 1996 Chevrolet Blazer
Heater/AC only blowing out of defroster vents
vacume hose off or cracked it wont change to floor heat ooorrr field mice have made them selves a home in your heater box
Dec 12, 2008 | 2004 Jeep Wrangler
Just got heater core replaced and now have no heat from heater or defrost. Fans work, just don't blow anything beyond "cool". The heat in my car is coming and going. I want to know how to fix...
It sounds like when they replaced your heater core, that they didn't properly hook up the blend door contros at the control panel. I would take it back to the repair shop that did the work and have them go back over things again just to make sure.
Dec 04, 2008 | 1992 Mercury Cougar
Intermatic EH40 Energy Controls - Electronic Time Switches - Water Heater Logo
90 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
