Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
TV Picture problems
My TV Turns of fine, but within about 5 to 10 minutes the screen goes black. when you turn the TV off and start it again, you have good picture, then within minutes it goes black again. I have tried unplugging and plugging back in but the same thing happens. Any Suggestions?
My samsung did the same thing right before my color wheel went out. Can't be sure but that is what was wrong with mine. hope this helps.
Posted on Jan 27, 2009
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
Picture goes out right after turning on, have to
My 3 year old Sharp LC-40C32U would start up fine but within a minute would go dark (audio continued fine). For a while I could turn the set off and on again and it would be fine, but over time this became less effective. My solution, which has worked for a week now, was to a) unplug the set's power cord; b) after 3 minutes plug it back in and turn the set on; c) on the remote hit MENU and slide over to SETUP (3 clicks to the right if the screen is dark) and one up to RESET; d) hit ENTER and follow the prompts. This puts the set in it's factory configuration so you will have to rescan for channels. Worked for me.
Sep 24, 2009 | Sharp AQUOS LC-40C32U 32 in. LCD TV
Sony KDS50A2020 Blackout
Replace the lamp, clean the fans, seen it a hundred times, I know "the lamp light isn`t blinking" replace your lamp and you`ll be back up & running, gl, video-tek
May 29, 2009 | Sony KDS-50A2020 Television
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
caypianan@yahoo.com
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
Screen Goes Black After About an Hour
Check the power board inside the TV, possible bad capacitors. I just had them replaced on mine.
Sep 21, 2008 | ViewSonic N3251w 32 in. LCD HDTV
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Sony KP-51HW40 51 in. Rear Projection turns blue
Hello......
First reduse the G2 voltage for the blue c.r.t,and watch if the unit works for longer period (offcource blue colour will be not present).After reducing G2 voltage to blue c.r.t still behaves the same than c.r.t is faulty and you have to replace.
Pls count the red led blinking when it goes off,incase it goes to std by mode.
Gopali
Dec 14, 2007 | Sony KP-51HW40 51" Rear Projection...
Red screen
sounds like a picture tube problem its a problem that probably cant be fixed only by a professional
Nov 30, 2007 | Sony KP-51HW40 51" Rear Projection...
Screen goes black after a few minutes, switching off and on and picture returns then goes black again
I have problem with my monitor, it is automatically switching off and switching on for 2 to 3 minutes for every 15 minutes why ?
Please mail me the solution to craju1@yahoo.com
Oct 21, 2007 | Relisys RLT1720 17" LCD Monitor
LG LCD Tv picture goes black but the sound still works
Next time it goes dark do a flash light test to see if your inverter board is fubar.
May 03, 2017 | LG M4200C 42 in. HDTV-Ready LCD Television
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
149 people viewed this question
Henry  Thomas
Henry Thomas
