Question about Refrigerators
The fridge is a GE Profile PFSS9PKYASS, the fridge stays at 68 degrees and the freezer only works at - 4. Was told may be a sealed system issue? A ny thoughts or suggestions?
5 Suggested Answers
SOURCE: GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Posted on Sep 21, 2008
  • 1122 Answers
SOURCE: fridge was in storage 4months fan work but not freezing.
is there ice building up in back of freezer?mike
Posted on Nov 11, 2008
  • 15 Answers
SOURCE: My ge profile fridge won't stay cold. the fridge is at 45 deg.
First things first - pull the fridge/freezer out from the wall, and look at the bottom.  You should see a metal coil somewhere - it probably needs to be cleaned.  Next, somewhere around the compressor (the big bulky thing in the bottom of the freezer) should be a fan blowing on the coil - make sure it is running.  That MIGHT have been the buzzing noise you describe - dirt on the fan blades or the fan hitting something.  Additionally, you can check the fan on the inside of the freezer - if it is stuck and/or not working, the air won't circulate properly, and you'll get pockets of different temperatures in your freezer.
Best of luck!
Posted on May 26, 2009
aasc
  • 1606 Answers
SOURCE: Ge Profile fridge
Pull the refrig out from the wall , and remove the rear panel . Touch the compressor and feel if its hot or running . If the compressor is cool , then the main control board is bad ( since the compressor isn't running ) . If you can solder , you can repair the board (another paragraph ) . If the compressor is warm , then you could have a thermistor or 2 bad . This would have to be checked by a technician , unless you know how to get into the diagnostics procedure . Also , see if the compressor cooling fan is working and the black squirl cage is clean of dust .
Posted on Sep 06, 2009
Testimonial: "Quick, professional response."
What temperature should my GE profile fridge be set at so that my food does not freeze
depends on what type control you have . what is it set on now 6 then turn down to 3 or 4 .
Feb 27, 2015 | GE Profile Spacemaker Stainless Steel...
I have a PFSS5PJXCSS French door with bottom freezer GE Profile refrigerator. Was making an awful noise and both fridge and freezer were warm. I opened back panel of freezer to find ice everywhere,...
Had similar problem, freezer was working fine, but fridge was warm, (68 degrees) It wasnt my damper, the mother board was fried, and so was the inverter board that told the compressor what to do, after having the inverter and two mother boards replaced.......I threw it out, biggest piece of ****, only three years old, and Sears would not stand behind it, even though I used their repairmen. I will never buy another GE product, or enter a Sears store again
Jun 03, 2011 | GE Profile PDS20SFS Bottom Freezer...
My GE profile side by side refrigerator's temperature is not staying where I put it. It keeps popping to 31 degrees when I set it for 37 degrees. My food is freezing !!
It may need to defrost. Shut it off for 4-5 hours to let any accumulated ice to defrost and see what happens.
There also is a control that directs more cooling to the refridgerator or the freezer compartment. It may need to be readjusted. It will take 24 hours to stabilize.
Oct 20, 2009 | Refrigerators
Water was frozen all inside the freezer and fridge temp was high
Self defrost mechanism may have an issue. If it stays on too long you will have excessive temps build up in refrig as well as freezer. There is also a defrost thermostat that is supposed to turn compressor back on when temps get too high - check that out also.
Apr 14, 2017 | GE Profile PSW26P Stainless Steel Side by...
Refrigerator is not cooling, but freezer is working properly
Usually it's because it's not defrosting. If there is frost buildup on the back wall of the freezer, it's a defrost issue. Most of the time these fridge have a defrost issue, it's because the defrost heater is bad. If this is the case you can get by for a while by manually defrosting the fridge. Take everything out, turn it off, leave the freezer door open and let it sit for 24-36 hours.
Jul 21, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
106 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
