Question about Philips 60P8341 60" Rear Projection Television
Changed crt coolant, better picture. red squiggily line starting at top center of screen, runs about a third of the way down. thought i saw scratch or small crack in green crt "c" lens. would this cau
Going to change coolant in red crt hoping it will get rid of squiggly line. cleaned all three screens and reflector or whatever it is called. didn't get rid of line. suspect green crt "c" lense.
  • Philips Master
  • 3,459 Answers
Sounds like you may have just left one of the wires loose from the red tube. Not likely an issue from the gren tube but you can always cover the top of the lens and let just green shine up. That may help narrow it down also.
Here is more detailed info for you also.....
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Posted on Jan 31, 2013
salt56
  • 373 Answers
SOURCE: phillips magnavox 52" big screen rear projection t.v
I will say that you probably still have the clear liquid (Glycol) still on the board. I recommend cleaning with a degreaser spray and brush it off with a clean 1inch paint brush. You can get the spray at Radio Shack The glycol is hard to remove and is conductive to electricity.
Posted on Jan 01, 2008
  • 2315 Answers
SOURCE: 60" Philips Projection... Erratic red color.
I will try to help on this one.
Stay tune.
Posted on Mar 20, 2008
Ecollier2012
  • 3459 Answers
SOURCE: Warped Picture, Separated colors
You have a convergence problem.  Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors.  Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors,  etc. Everything you need to fix it yourself.
Posted on Nov 28, 2008
johnnydiode
  • 647 Answers
SOURCE: green hazy lines across my projection tv screen
The coolant in between the CRT face and the focus lens has probably become discolored and would need to be drained, cleaned and refilled. The green CRT is the center one and it would have to be romoved in order to refill it.
Posted on Sep 21, 2009
Testimonial: "This info was very helpful and saved me a lot of money"
  • 1348 Answers
SOURCE: Philips Magnavox 9P6040CI ? Alignment ?
you have to set up the convergence using the on screen pattern generator.
Posted on Jan 13, 2010
My mitsubishi vs 6047 has been in unheated storage for about 4 years. now picture is very blury. when words are on screen large letters are legible with small white horizontal lines dancing side to side....
Does the picture look like this?
If so I believe your CRT liquid coolant has gone bad and needs replaced.
How to diagnose bad CRT Coolant:
Note: This problem will only affect the GREEN and BLUE picture tubes. The RED CRT is never affected, because the wavelength of the red light does not promote this algae growth
General Symptoms: Washed out, blurry picture, red portions mostly OK, GREEN images have halos, BLUE portions of images may have halos or be missing entirely.Turn the color level control all of the way down and remove the screen and/or the cabinet that contains the mirror. (different for different models) Do not turn the set off or the color level control will reset to preset levels. Look directly into the picture tube lens while the set is on. First look at the RED CRT. Observe the scan lines in the picture. These same lines should also be present in the green and blue picture tubes.
After looking at the RED CRT for comparison, look into the GREEN or BLUE CRTs. If it is contaminated, it will look like there is a layer of film that you have to look thru to see the picture. There may also be swirls and other various contaminates forming. If it is not as clear and sharp as the RED CRT, it is contaminated, and you should change the coolant fluid. IF you wish to tackle this I will supply more information and instructions. This task is medium to hard for non trained people.
Let me know if you wish to get the instructions on changing the fluid.
Jun 09, 2011 | Mitsubishi VS-6047 60" Rear Projection...
AFTER CLEANING BOTH THE MIRROR AND THE THREE LIGHTS MY PICTURE IS MUCH BETTER. HOWEVER STILL NOT AS CLEAR AS WHEN NEW. WHILE I HAVE THE BACK COVER OFF & THE TV ON , THE BLUE AND RED LIGHTS ARE CLEAR...
Picture are blurry and have a hollow effect?But Convergence pictures R,G,B colors lines are all alignments up?Need CRT coolant replacement for the green CRT TUBE gun.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a CRT coolant kit for the replacement.
Dec 08, 2010 | Hitachi 53FDX20B 53" Rear Projection...
BAD PICTURE, DISTORED, MOSTLY ON THE EDGES, BUT THE BLACK LINE ON TOP IN HIGH DEF CHANNELS IS NOT STRIGHT ACROSS, IT BOUGHS DOWN LIKE A "U" SHAPE
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 15, 2009 | Sony KP-51WS520 51" Rear Projection...
Picture arches down at the top and arhes up at the bottom
  • Screen looks 3D
Apr 08, 2009 | Philips Magnavox 9P6034C 60" Rear...
Picture bowing from top and bottom to the center
  • Screen looks 3D
Mar 29, 2009 | Zenith Televison & Video
My hitachi 60SBX72B having picture convergence problem, how to fi
  • Screen looks 3D
Jan 01, 2009 | Philips 60P8342 60" Rear Projection...
Big screen on bad red lineand blury
Good DAy, mitas;
It sounds that the TV is having a Convergence Circuit problem or you may CRT Coolant (fluid) on the PCB's. Good Luck, big IRISH........ PS Call for help, by calling a Factory Service Center....get an estimate!!
Aug 31, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Sony 65 inch screen tv
The lines you saw, i;m sure they are the ones called retrace lines but know the failure could be located on the red CRT board. Most likely the video amplifier is defective and not necessarily the CRT.
What is the model number of your TV?
Jun 17, 2008 | Televison & Video
Thin Red Lines on Top of Screen
Sorry, that is common for generic replacement xformers for
your make / model . There are some adjustments to minimize
the effect in servicer menu...............you can try turning down the
screen control a bit....................T.
Dec 21, 2007 | RCA F36650 36" TV
Philips 60P8341 60" Rear Projection Television Logo
79 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
