Question about Vivitar ViviCam 3305 Digital Camera
My Vivitar 3305 no longer powers on.Replaced batteries and still nothing.What is the problem?
The power on button is a small yellow silicon button that no longer works. The batteries have been changed but still wont power up.
    Genius:
  • 1,019 Answers
Sounds like the switch has gone bad, this is not a user fix and needs to be replaced.
Posted on Jan 26, 2013
5 Suggested Answers
SOURCE: wont turn on
I had the exact same problem. The battery contacts are mildly oxidized. The problem is made worse beacause the outer contact does not put much pressure on the side (+) furthest from the hinge.
SOLUTION: Go to Radio Shack and buy a Deoxit Power Booster Pen. Wipe some on the battery ends that touch the inner contacts and insert while still wet. Rotate the batteries slighly to help coat the contacts. Wipe some deoxit on the outer contacts and close the door while pulling gently away from the hinge so you will get a good "wipe" when you slide the door latched.
I hope this works as well for you as it did for me. Scott L.
Posted on Mar 13, 2008
  • 4 Answers
SOURCE: Vivitar 3815
It's because the batteries aren't strong enough. You are probably using alkaline batteries, which are not recommended for digital cameras because they drain easily and quickly. Use nimH batteries.
Posted on Aug 21, 2008
richard191
  • 691 Answers
SOURCE: Wont repower
Hello
Thank you for using
FixYa for your problem
Your camera is faulty. It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Posted on Nov 30, 2009
SAFFOTO
  • 77 Answers
SOURCE: I have a Vivitar 8025 and I can't get it to work
MSDC stands for mass storage device. Is it possible that there is no memory card inserted? Or maybe the internal memory is full? Try connecting it to your computer via USB and see what it does... Good luck!
Posted on Jan 29, 2010
I have the Vivitar ViviCam T324N does it get charged by being hoooked up to computer or is it only powered by batteries?
The T324N is powered only by batteries. Hooking it up to a computer simply drains the batteries faster since the camera has to expend juice communicating with the computer (even if only to say it has nothing to say).
Jan 03, 2013 | Vivitar Vivicam T324N Digital Camera...
When I hit the power on button on my compaq nc6220 the yellow battery light flashes and nothing happens
Please try removing the battery, and then connect the power adaptor and try switching the laptop on see it if works if it works then the battery needs to be replaced. I would also recommend if you can check your power adaptor / swap your power adaptor with a know good adaptor (if you have one). The remaining steps will depend on the outcome of the steps above.
Oct 02, 2012 | HP Compaq nc6220 Notebook
I pluged in the power supply and nothing is happening. The small yellow batery icon came on near the screen and nothing else is happening
Remove the mains power lead and then take out the battery. Hold down the on/off button for 30 seconds to dispel any residual power.
Plug in just the mains lead (AC adapter) and see if the machine will boot on mains power only. If it does let it boot up and then shut it down again. Remove AC and reinsert the battery, plug in AC power again and see if it will boot with the battery in.
If it boots up the problem is sorted, if not then there is a problem with battery so you would have to use it on AC only until you find a replacement battery.
Please post back if need anymore help.
Good luck and regards.
Jan 11, 2010 | Dell Latitude D505 Notebook
I have a vivitar 8690 and I just put in batteries and now it says its drained. Do I need certain kinds?
use energizer itis powerful and last longer prefer to be energizer chargable batteries,will make ur camera work right away and stays on longer for more pictures and videos
Dec 29, 2009 | Vivitar ViviCam 8600s Digital Camera
Battery status light remains orange
chance are its not the battery!
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (upto ten seconds) until it starts..if that fails
the following magellan 800,860,2000,2200t,2500,3000,3050,3100,3140,4000,4040,4050 and the 6000t are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...i sell these power ports and will repair them for anyone thats not able to do it themselves.
you can get it repaired here
or buy the port here
if you need further help, just let me know
Aug 22, 2009 | Magellan RoadMate 800 GPS Receiver
SGI F180 Flat Panel Display no longer turns on.
If the power button does not stay on, the monitor might be burned out.
Aug 20, 2009 | SGI Silicon Graphics Silicon Graphics F180...
Toshiba satellite a105-s4004 power problem
It sint the power jack, but rather the Power control circuit. This circuit isnt repaired but replaced. I recommend taking this to an authorised service center or a certified technician of the latter is not easily avilable. If you choose to repair this at your own risk please remember doing so without the necessary knowledge will result in major damages.
Jul 11, 2008 | Toshiba Satellite A105 Notebook
Timex Expedition Indiglo light no longer works?
Replace the back cover with the arrow pointing directly at the stem. Everything should work correctly with the cover in that position.
Jun 22, 2008 | Timex Expedition 40141 Wristwatch
Sansa m230 stuck in locked mode
Slide hold button to correct (usually center) position and hold in power button for 3 seconds or longer.
May 23, 2008 | SanDisk Sansa m230 MP3 Player
Vivitar ViviCam 3305 Digital Camera Logo
Top Vivitar Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
