Question about Casio Exilim EX-Z500 Digital Camera
White screen with ghost images
Since the last 2 -3 times while using the ez-z500, some shots after clicking appear totally white on screen with ghost images. But now all shots are white after clicking. Is this a problems with the SD mem card? Should i get another card? Or is it a camera problem?
  • 4 more comments
  • kekel Nov 07, 2007
    my ex-z500 has exactly the same problem only that when i shoot indoors with no intense light like outdoors, images look pretty much normal. i can hardly recognize the images i shoot outdoors. also, i can't set the camera on higher than vga resolution because if i do, horizontal lines appear. pictures look like pad paper.
  • Anonymous Apr 18, 2008
    Whenever i take image it produce white images, especially in day light. Even i have reset all the settings still the problem exist. Though i have sought of virus in the memory card. i even formatted the card but all in vain.
  • Anonymous Aug 25, 2008
    My camera has the same problem, ok indoors without daylight but outdoors ghost like images on all shots. Tried resetting camera to no avail.
    All other functions on the camera appear to work.
  • limleeseng Nov 02, 2008
    white picture see when taking outdoor with sunlight expose but it seems ok when taking indoor. Sometime the picture will show white line bare as well.
  • Anonymous Dec 17, 2008
    Same problem. Seems common to this camera
  • LAURAAHMETI Jan 19, 2009
    If the photo shoot out show white , the obscure (quality variation), and even horizontal line ( white lines), and so on over-exposure cases
    Please help me!!!
  • 33 Answers
If the photo shoot out show white , the obscure (quality variation), and even horizontal line ( white lines), and so on over-exposure cases, even if the use of anti-tremor, set to default values are invalid, because the camera shutter fault.
It's need repair camera machine shutter.
more detail casio ex-z500 overexpourse
Posted on Mar 22, 2008
  • If the photo shoot out show white , the obscure (quality variation), and even horizontal line ( white lines), and so on over-exposure cases
Please if you can help me.
[email protected]
Posted on Jan 19, 2009
WHITE PITURE SHOT
Posted on Sep 06, 2008
    Genius:
  • 2,985 Answers
Camera problem - possibly a connector adrift or worse a firmware failure Casio Website for Tech support in the first instance.If it is a young camera a free replacement or one at a reasonable price is possible,or be prepared for a price that makes you wish to buy the next camera.
Posted on Jul 12, 2007
SOURCE:
How do I fix vertical lines and no picture.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 20, 2015 | Vizio E320VP 32" LCD TV
Ghost / Overlapping Image
ok you have defective convergence crrection circuit! or maybe the RF Box is defective! can you describe the color of the ghost?
Oct 12, 2007 | Samsung HCN4226W 42" Rear Projection...
Scanner does not appear to work
If you put something in and click "acquire", do you get the same white image?
Jun 08, 2015 | Office Equipment & Supplies
Philips 47PFL5609D/30 White screen displays on 3/4 of screen
It sounds that the connection between t'Con board to panel have some problems; loose contact etc. Check it. Re-seat them once, and check. If you wish to get more details about faults to Philips PFL series flat panel TVs, check this link.
Feb 05, 2013 | Philips 47 in. LCD HDTV
Blue Ghost
you will need to replace 2 stk ic [ parts ] after that the technician will have to realign the picture, sometime also some resistors get bad along with one or 2 fuses
Dec 15, 2008 | Sony KP-51HW40 51" Rear Projection...
Shadowing
GOOD DAY ND GOOD LUCK;
TRY THIS, IT WILL CORRECT CONCERN:
50V500 ONLY
GHOST: May be described as "Out of Convergence" but ghost is still attached to main image.
CONDITION:
A "ghost image" appearing to the left or right of images in the picture. Can be varying shades of a primary color (red, green, or blue) as well as gray. Can easily be seen in the 4 x 3 mode, at the edges of the picture.
CORRECTION:
To correct the problem, please do as follows:
  1. Access I2C Menu. (See page 57 of the Service Manual).
  1. To enter the I2C Service Menu, with power off, (on the front control panel) press and hold the INPUT button. Then press the POWER button for two seconds. The following Service Menu will appear.
03b_ghost_image01.gif Figure 1
  1. BEFORE CONTINUING: CONFIRM THAT THE R, G and B DRIVE ARE SET AT 40.
  • Be sure to press SELECT after each change to SAVE the new Data.
  1. Using the Remote Control joy stick, scroll down to next page (see Figure 2) until LCD ADJUST is highlighted.
03b_ghost_image02.gif Figure 2
  1. Move the joy stick to the right to cursor right once. The next page will appear with the word GHOST highlighted.
  2. Cursor right again, and a white screen will appear with a BLACK SQUARE in the center, as in Figure 3. You will see LCD ADJUST, followed by “SHP” and a number (value).
Figure 3
  1. If the unit is out of adjustment, you will see a gray ghost on either side of the black square. Move the joystick to the right or to the left until the ghost disappears. The number values will change up or down.
    • If the ghost adjustment is off with a lower value, there will be a ghost to the left of the square.
    • If the ghost adjustment is off with a higher value, there will be a ghost to the right of the square.
  2. Once you get the square to look good without ghosts, press "SELECT" to save any data values that have been changed.
  3. Press the "EXIT" button three times to return to normal picture.
  4. Adjustment is completed
  5. I HOPE THIS WAS HELPFUL, big IRISH.
Jul 26, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Epson C1900 "ghost " images
Sounds like the transfer roller or the fuser unit may be faulty. Look at the fuser to see if the roller surfaces are dirty. If so, replace the fuser.
Jul 20, 2008 | Epson AcuLaser C1900 Printer
DSC-S40 images in open and close area
Sound to me like the shutter assenbly is worn, this cause ventian blinds to appear in you shots and incorrect exposure times. sorry their is no cure
Aug 30, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Camera's LCD dosen't work
Hitting the Cyber Shot logo on the front really works - ye legends!!!
Apr 15, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Casio Exilim EX-Z500 Digital Camera Logo
884 people viewed this question
Top Casio Cameras Experts
Ekse
atollminsk
Level 1 Expert
Parshiv Luthra
Are you a Casio Camera Expert? Answer questions, earn points and help others
