Question about Viking DFSB483D
Viking pro refrigerator DFSB483D can i change the wood panel to stainless?
    New Friend:
    Problem Solver:
  • 7 Answers
Yes you can, carefully pull off the wood and replace.
Posted on Jan 17, 2013
Where is the drain hole located in the Freezer side of Viking DFSB483D? How can it be cleared?
you need to remove all freezer shelves and remove rear panel in freezer. under the coils is drain pan and drain hole.
May 25, 2017 | Viking Refrigerators
I have a Viking refrigerator/freezer model DFSB483D. The door to the fridge will not close by itself and must be pushed shut each time (seal is tight when it is closed). Is there a spring or other p
A simple test for the problem is : Remove everything from the shelves on the DOOR and test the closure. more than likely you have something colliding with inside shelf
Dec 02, 2014 | Viking Designer DFSB483D
Is there a fuse on the Viking Pro freestanding gas model? Can't find anything in the manuel. Thanks
Hm, there is a hi limit switch between the range top and oven cavity. Ck your door to see if its sealing . If heat is escaping have a servicer look at your hinge receivers so the door will seal.
Mar 12, 2014 | Viking 30 " Pro-Style Stainless Steel...
Ice maker not making ice
Call a tech. Complicated stuff. Check the fill solenoid.
Nov 14, 2013 | Viking Pro Vcsb483dss 48" Built-in Side By...
Anyone know what causes condensation on the bottom of the freezer door? seems to beed up on the gasket, but the gasket seems to seal fine. A service guy actually came out and said the gasket is not the...
There often is a heating strip that runs inside there that keeps a bit of warmth there so that condensation does not form....
The heat strip is bad ans as far as I know it is not replaceable...
heatman101
Aug 31, 2010 | Viking Designer DFSB483D
Viking DSB483D: freezer at +10F for 4 hours or more
check the evaporator coil for leakage.
Nov 13, 2009 | Viking DFSB483D
Viking all refrigerator
I just started having the same problem with my 48" frig/ freezer Viking Designer series 2 years old- this has been a hot summer, we were not home much and the AC in the house was set higher 78 degrees so the frig I guess had to work a bit more - when I open the door to the frig water droplets acually run down the interior of the door and the box insde is always damp - I also have stress cracks in the interior shell of the frig - repairman is trying to get Viking to fix it- it has been a year now and it still is not fixed- the stress cracks were caused by improper insulation application to the inside of the frig according to the repair people- Also my handles have pealed - like the stainless steel is not really stainless steel - Any ways could the temp in the house changed - does not mean the frig should not work well - For what it costs, I expected better
Sep 11, 2008 | Viking 42 in Built In Professional...
Viking DFSB483D Logo
73 people viewed this question
Top Viking Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
