Question about Epson 4880 Stylus Pro InkJet Printer
Service req 100035
How can i fix this error ?
5 Suggested Answers
leroyal
  • 2120 Answers
SOURCE: I have a service req E527 error on my Epson printer. how to fix?
To fix the E527 error, close the front panel (cover A) and open the top cover (cover B). With the photoconductor unit removed, the toner carousel will rotate. It only rotates if cover A is closed all the way. You can easily rotate the carousel to a position where you can remove/reinstall the stuck toner cartrdige. report_dis_text_13954 = 'We\'re sorry but you must be signed in to report inappropriate material. Click the button below to sign in or register.
  • Sign In / Register »
  • Cancel »
Posted on Jan 17, 2009
hdsportyem
  • 11 Answers
SOURCE: Epson Acculaser CX11NF Error 'Service Req E527'
Hi.. To fix the E527 error, close the front panel (cover A) and open the top cover (cover B). With the photoconductor unit removed, the toner carousel will rotate. It only rotates if cover A is closed all the way. You can easily rotate the carousel to a position where you can remove/reinstall the toner cartridge if stuck.
Thanks
jim report_dis_text_13954 = 'We\'re sorry but you must be signed in to report inappropriate material. Click the button below to sign in or register.
  • Cancel »
Posted on Feb 18, 2009
asabur
  • 102 Answers
SOURCE: error service req E511, all lights flashing
Possible parts that caused the error
1 Photoconductor Unit 2 SENSOR TR-0
3 HARNESS-ASSY XERO 4 MOTOR ASSY P/R
5 HARNESS ASSY MAIN 6 PWBA MCU
7 LV/HVPS
Posted on Jan 03, 2010
SOURCE: I have an epson 4880
Service Request errors in the range 00010004 - 000101D are related to a carriage movement problem. In some instances like paper jams, the carriage locking tab may be partially pushed in, causing the carriage locking mechanism to put a drag on the carriage or lock the carriage completely. This will cause a carriage error. Make sure the carriage locking tab is pulled to the left. Then turn the printer's power off and release the carriage by pushing down on the cutter blade. Slide the carriage to the left and look for any paper that also may be restricting the carriage from moving freely.
00010004 CR Motor encoder check error 00010005 CR Motor out of step 00010006 CR Motor over current 00010007 CR Motor in-position time-out 0001000A CR axis detection error 0001000F CR Motor PWM output faulty 0001001D CR servo parameter error
The T-Fence may also be dirty or out of the carriage encoder. Check to make sure it is clean and in the center of the encoder. Contact Epson for additional assistance.
Posted on Jun 20, 2011
Service req 0001001C
SERVICE REQ - 0001001C - FS origin (Suction fan shutter home position) error
Jan 18, 2013 | Epson Stylus Pro 10600 InkJet Printer
PRINTER SHOWING 'SERVICE REQ E300'
Sadly this is a serious error requiring a replacement Laser Unit - if you are lucky. It may also be a system board error that is falsely reporting the error.
This printer is likely to be beyond economical repair.
Aug 22, 2012 | Epson Aculaser C3800 Transfer Unit
EPSON AcuLaser C1900 with Error "Service Req E020"
ERROR CODE: E020
“SECONDARY TRANSFER VOLTAGE CONTACT/RELEASE PROBLEM”
Solution
�� Electric parts which can cause the trouble:
• Transfer Roller Pressure Solenoid (SL2)
• Transfer Roller Pressure Position Detection Sensor (PC7)
• Engine Board (PWB-A)
May 18, 2009 | Epson AcuLaser C1900 Printer
Epson stylus pro10000 problem service reg
SERVICE REQ. 00020000:NVRAM ERROR
SERVICE REQ. 00020001:NVRAM COMPARISON ERROR
SERVICE REQ. 00020002:SDRAM ERROR
SERVICE REQ. 00020003:FLASH MEMORY ERROR
Problem
Abnormal detection in a corresponding element
Solution
1. Once save parameter to Flash memory card and install it to the printer again.
2. C362DRV board. replacement
Feb 18, 2009 | Epson Stylus Pro 10000 InkJet Printer
Thanks
  • Cancel »
Feb 18, 2009 | Epson ACULASER CX11NF All-In-One Printer
Error in printer
" Service Req E 0003" means that your printer needs to be serviced. Pls contact your service provider.
Jan 27, 2009 | Epson EPL N1200 Laser Printer
  • Cancel »
Jan 17, 2009 | Epson Aculaser C1100 Printer
Error c0998
That what service manual says:
Service Req xyyyy
A Controller error or print engine error detected. Turn off the printer. Wait at least 5 seconds and then turn it back on. If the error message still appears, write down the error number listed on the LCD panel (xyyyy) and turn off the printer, unplug the power cord, and contact a qualified service representative
Apr 29, 2008 | Epson Aculaser C1100 Printer
Epson 4880 Stylus Pro InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
