Question about Miele G 2143 SC SS Builtin Dishwasher
How to put locking clamp back on miele dishwasher non return valve
3 Suggested Answers
  • 122 Answers
SOURCE: MIELE DISHWASHER PARTS
We would have to order one -
Mike
Posted on Jan 04, 2009
  • 122 Answers
SOURCE: Locking clamp for non-return valve
It will have to be ordered from Miele
Posted on Jan 09, 2009
I can't get the non-return valve out of my miele dishwasher model 4205
Have the manufacturer book on it around look it up but more than likely it does mean that
Jun 17, 2017 | Cars & Trucks
Miele dishwasher drainage
there will allways be some water under the filter. when you remove the non return valve, there should be a rush of water coming back into the sump from the drain hose. if not, the seals in the non return valve are bad and you need a new part. they are not that expensive. switch to an appropriate detergent such as miele or finish all in one powerball tabs and the new part will last much longer. cascade and other brands are eating the seals in dishwashers faster than i can replace them.
Apr 03, 2012 | Miele Dishwashers
Dishwasher is not working. The red 'Inlet/Outlet' light is flashing. Any advice please Thank you
There are a few things you can check. First set the washer cycle to Stop and turn off the unit. Next make sure that the stopcock on the inlet valve is fully open. Then close the stopcock/valve and disconnect the inlet hose. Remove the seal and then the filter (use pliers). Clean this inlet filter with running water. Replace the filter and seal and reconnect the hose to your inlet valve. Reopen the valve (check for leaks from threading problems). Make sure the valve is fully open when you try to restart the dishwasher. Check your incoming water pressure at this valve as well - low water pressure will also trigger the inlet error. Make sure the hose is not kinked.
If the washer did any parts of the wash cycle, then try cleaning the outlet side of the system.
Next clean the combination filter, drain pump and non-return valve. For the filter (near the lower spray arm), turn the handle counter-clockwise. Lift the filter out and remove all debris. Rinse under running water and use a nylon bristle brush to get stubborn stuff out. Pull back the yellow clip and open the filter flap. Clean the underside of the filter with running water again.
Remove the water from the cabinet with any container that works. Raise the locking clamp for the non-return valve. Lift up the valve and clean it under running water. Carefully check the drain pump (now visible with the non-return valve out) and remove any debris. Sharp objects may be present. Move the impellers and completely check the pump for foreign objects and remove them. Replace the non-return valve and secure it with the locking clamp. Replace the combination filter so that it lays flat and secure it with the handle. Make sure that the drain hose is not kinked.
If neither of these solve the problem, you need to call for service. The Waterproof safety system has been triggered and water got into the electrical system of the unit.
Many Miele appliance manuals are here: http://www.miele.co.uk/customer/OperatingInstructions.aspx . The manual for the Miele G641 is here: http://www.miele.co.uk/Resources/OperatingInstructions/G%20641%20and%20G%20841%20Plus.pdf . See this manual for pictures of the filters and drain pump area.
I hope this helps.
Sep 14, 2011 | Miele 24 in. Novotronic G641 Plus Built-In...
Miele will not drain. How do you unbock the drain?
Hi If you have a G 600 range dishwasher see instructions below. Remove filter, On left of sump you will see a non return valve with a metal clip keeping it in place push clip into the centre of sump. remove non return valve ( plastic piece with ball bearing in it) and rotate impeller. Start a program, after 60 sec stop program, (debris will have been thrown out of pump.) re-assemble and test.don't forget to find debris thown out. More in depth instructions are in user manual under problem solving which can be downloaded from miele site. If G1000/G2000 Range Non return valve on right of sump and is removed by pushing in to centre of sump no clip fitted.
Apr 05, 2010 | Miele 24 in. G646SC Plus Free-Standing...
Miele incognito not draining
at the bottom left corner their is a manual draining system maybe you need to use that with a bucket.
thats all i can think of unless it still has warranty just trade it in.
Oct 03, 2008 | Miele Novotronic Premier 500 Front Load...
Intake/Drain Error
There is water collected in the inner tray of your unit. Pull out the Miele and take off the drain hose and unplug the unit. Then tilt the dishwasher back 60* and let it drain out all the water. There will be a couple of cups on the floor, but nothing too big that a couple of towles can't handle. Then reconnect everything and start up the unit. It WILL work! It just happened to me and my Miele incognito is now working like a champ again!!
May 21, 2007 | Miele 23 in. Novotronic G841 Built-In...
Miele G 2143 SC SS Builtin Dishwasher Logo
54 people viewed this question
Top Miele Dishwashers Experts
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
