Question about Magic Chef CMV1000B Microwave Oven
Whirlpool MH1150XMB We just had one installed and the turntable does not turn, no manual came with it ( we live in an apartment) Turntable worked for quite a while. Now, all of a sudden it doesn't.
I just got a micro over the counter oven , with no manuel, I need to figure out nhow the brackets go on
Posted on Jan 28, 2009
    Sergeant:
  • 311 Answers
There is a motor under the turn table that spins that tray.now some more expensive units would allow you to turn off the turn table if user wanted to,so check that out .but if not and its under warenty call a sears or any servicer that repairs you brand under warenty
Posted on Jan 25, 2009
Manual for a whirlpool microwave oven model wmh31017aw-1
There is no turntable control. It is always on. The turntable should change direction each time the unit is used. If the turntable is not operating, it has malfunctioned. Newer microwaves for the most part all have full-time turntables to promote even heating, thus reducing customer complaints about ovens that don't heat right.
Dec 30, 2015 | Whirlpool Microwave Ovens
Turntable does not turn (work). model:JVM3660SD001
have you check if the unit has the power... & also check if all the settings was made..
Jun 13, 2008 | GE Microwave Ovens
Kitchenaid microwave turn table doesn't work I replaced motor still doesn't work
Is it set to be off via the control panel?
You can download Kitchenaid / Whirlpool owner's manuals, installation manuals, and parts lists here.
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag here.
Jan 19, 2014 | KitchenAid Microwave Ovens
Whirlpool MH1150XMB-0 runs but does not heat food
If the housing of the unit isn't too difficult to remove (normally 3-5 Phillips screws around the rear edge), with the unit unplugged of course, check for a user replaceable fuse inside. The magnetron is separately fused and fuses can fail due to metal fatigue. It will be high amperage; 10-20 amperes and many hardware stores will have them. BTW, there is no residual radiation from a magnetron that isn't operating.
Aug 18, 2009 | Whirlpool MH1150XM Convection/Microwave...
I HAVE A KENWOOD MICROWAVE GT/AL17,THE TURNTABLE HAS STOPED TURNING, ANY ADVICE MANY THANKS. TONY Nr IRRLAND
Two possibilities: either the turntable coupling is broken or the turntable motor has quit. The plastic coupling can wear or crack so it no longer fits properly on the turntable motor shaft. Then even though the motor still turns, the turntable doesn't. Or the motor itself may have stopped working. If the plastic coupling still looks normal and you can't rotate it easily by hand while it's in place, it's probably the motor.
I'm here in the US so I can't suggest where to find parts, but you should be able to locate a supplier who might have replacements available. Of course the oven will still work without the turntable running. You'll have to open the oven occasionally and turn the food yourself to insure even cooking.
Jun 03, 2009 | Whirlpool MH7140XF Microwave Oven
KHMS 147KWH-0 TURNTABLE DOESN'T WORK
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can download Kitchenaid / Maytag / Whirlpool owner's manuals and installation instructions here.
Nov 20, 2008 | KitchenAid Microwave Ovens
Whirlpool MH1150XMB
Driver turntable or turntable motor needs to be replace
Aug 24, 2008 | Whirlpool MH7135XE Microwave Oven
Turning off turntable
This model does not have that feature.
To download your owner's manual free, enter your model number here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 08, 2008 | Whirlpool MH1160XS Convection/Microwave...
I have a Whirlpool AMW545 built in microwave oven. The turntable continuosly runs with the door shut when the microwave is not in use. The turntable will stop rotating if the door is opened.
the controller for the turntable is shorted out or welded its contact if its a relay. the door has safety switches that turns off the electrical connection to the turntable and magnetron once you open the door. you can trace the switch that runs the turntable. start from the power supply, goes to the door switch then to the controller before it goes to the turntable motor. i'm sure it has an electrical diagram at the inner wall of the cover.
i hope i was able to help.
Jun 27, 2008 | Whirlpool Microwave Ovens
If your model is MH1160XS, then no.
But if yours is a different model, you can download the owner's manual from the Owner Center here: http://whirlpool.com/custserv/index.jsp
Dec 26, 2007 | Whirlpool MH1160XS Convection/Microwave...
Magic Chef CMV1000B Microwave Oven Logo
101 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
