Question about Dyson DC39 Animal Canister Vacuum
Dc39 triggerhead is not working
The brush is not spinning
The roller stops as soon as machine turns on, then air leaks with poor suction. How do I fix it?
Hi there, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your DC39 Multi Floor, but from what you've described it sounds like your machine may have a blockage in the floor tool, wand, hose or inlet duct. This is simple to resolve by following each of the steps shown in our video guide:
If you continue to have issues with the suction performance or the brush bar in the Triggerhead floor tool after checking for and removing any obstructions, our experts are on hand to help you further. You can reach the Dyson Customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Apr 11, 2015 | Dyson DC39 Multi floor canister vacuum...
Tip
Dyson DC39 / DC37 with Triggerhead floor tool - Getting started (Official Dyson...
<br>How to assemble and use your new Dyson DC37 or DC39 vacuum cleaner. This applies to machines equipped with the Triggerhead floor tool.
on Aug 19, 2013 | Dyson DC39 Animal Canister Vacuum
Brush bar doesn't spin on dyson on dc39
DC39's Trigger head floor tool is powered by a turbine, driven by your vacuum's suction. Following these simple checks should help you resolve any issues which could be preventing the brush bar from rotating as normal: http://www.dyson.co.uk/support/dc39/dc39-animal/machine-is-not-working/trigger-head-not-working/dc39-check-the-brushbar/dc39-check-triggerhead-tool
If you'd like further help from our experts after giving this a try, please get in touch with us directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). If a replacement part is needed, we can also confirm if this is covered under your Dyson parts and labour guarantee.
Feb 24, 2015 | Dyson DC39 Animal Canister Vacuum
Get the brush bar to spin again on my dc39 vac
The rotating brush bar inside DC39's Triggerhead floor tool should rotate when the vacuum is running, unless you turn it off using the button on the wand handle. If it's not rotating, our Support guide will walk you through the checks needed to resolve this: http://www.dyson.co.uk/support/dc39/dc39-animal/machine-is-not-working/trigger-head-not-working/dc39-check-the-brushbar
In the unusual event that these checks don't resolve the issue, please contact our experts directly so we can help you further. You can reach the Dyson Customer Helpline by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Feb 13, 2015 | Dyson Vacuums
The turbine head of my DC39 stopped working. The suction is super, took the brush out and disconnected the hose and looked into it, no blockage is visible looking. ideas?
hi russ, it's jack at dyson.
i'm sorry to hear you're having difficulty with your dc39's triggerhead floor tool. i appreciate you've already checked for a blockage, but you may want to follow the steps shown in our online support guide just to make sure there's nothing you've missed: http://www.dyson.co.uk/support/dc39/dc39-animal/machine-is-not-working/dc39-check-extension-tube
if you find there's no improvement after running through these checks we're happy to help further - and if a replacement is needed, we can confirm if this is covered under your dyson warranty. you can reach our experts directly by calling on 0800 298 0298 (uk), 1-866-693-9766 (us), 1-877-397-6622 (ca) or 1800 239 766 (au).
Jan 20, 2015 | Dyson DC39 Animal Canister Vacuum
Why does my Dyson Dc-39 vacuum have good suction, but the beater bar barley turns?
The beater bar may be clogged with pet hair and other debris. You may have to do some disassembly to get everything working again.
Dec 18, 2014 | Dyson DC39 Animal Canister Vacuum
Brush no longer spins
Apply some Oil or crease in it to lubricate it! it will surely work
Mar 09, 2014 | Dyson DC39 Multi Floor Ball Canister...
WHEN EVER I PLACE THE SPINNER ON THE VACUUM IT STOPS SPINNING
Hi Linda,
I am sorry to hear you are having difficulty with your DC39 brush bar. The brush bar on your machine is air driven. Generally, if the brush bar stops rotating it is due to an obstruction that is preventing air flow. Please visit the appropriate link below for step by step instructions on locating and removing a blockage from your machine.
US:
http://www.dyson.com/support/dc39/dc39-animal/diagnosis-root-menu/performance-flo-extension-tube-suction-check-dc39
UK:
http://www.dyson.co.uk/support/dc39/dc39-multi-floor/machine-is-not-working/dc39-check-extension-tube
We also recommend inspecting the brush bar to ensure it is free of any debris and washing your filters. If for any reason the recommended trouble shooting does not fully resolve the problem please contact our Helpline to speak with an expert.
US - 1-866-693-9766 or UK - 0800 298 0298
Best wishes,
Jessica
Dec 15, 2013 | Dyson DC39 Animal Vacuum
Lock hard floor setting
Hi Lissie, it's Jack at Dyson.
I'm glad to hear you've found the answer to your question, and that your new machine is working well for you.
DC39 Animal includes the Triggerhead floor tool, and the switch on the wand handle allows you to the brush bar on for carpets, and off for hard floors. You might like to take a look at our Getting Started video attached for further guidance.
If there's anything else you'd like advice on, don't forget we're on hand to help. You can also find advice and support at www.dyson.com
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Dec 03, 2013 | Dyson DC39 Animal Vacuum
Turbo head on DC39 animal will not spin. I have removed any hair etc caught around the brush but still no spinning..
I have the same problem with my DC39 Animal's brush bar. Im on my 3rd one in 9 months of ownership. The DC39 brush bar is driven pneumatically (there is no electric motor in the brush head) and switched on and off via a suction activated pneumatic ratchet within the brush head. The moving components are actuated by bellows. Ive found that the glue holding the bellows fails stopping the ratchet working intermittently at first and then completely as the bellows comes away completely. At first you can help the ratchet by tapping the brush head - the red ratchet ring can be seen to click round. This, in my opinion, is an inherent weakness of the DC39 design and cannot be easily repaired. The only solution is a new brush head. Luckily Ive got a 5 year warranty and at the current rate I will have got through about 20 brush heads !
Mar 31, 2013 | Dyson DC39 Animal Canister Vacuum
Dyson DC39 Animal Canister Vacuum Logo
400 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
