Question about Lexmark X5150 All-In-One InkJet Printer
How to open and install ink cartridge on lexmark x5150
How to open and install black ink cartridge on lexmark x5150
    Genius:
  • 2,035 Answers
Please click on this link:
http://www.lexmark.com/publications/eng/x5150/index.html
And get all the information from the manual ...
Good luck...
Posted on Jan 25, 2009
I replaced black ink cartridge and am getting error that says remove tape i already did that it is a lexmark 5495
Is it a truly genuine Lexmark cartridge? Many printers are *very* finicky now on cart. type. If not, try a real one and see if you get that msg.
Good luck.
GuruTim
Jan 05, 2010 | Lexmark X5150 All-In-One InkJet Printer
Cartridge Error message on our Lexmark X5150
The Lexmark machines are designed to kick out anything it suspects may be refilled. If your old cartridge has bad print nozzles this may be tripping the error. Printers are typically for sensitive with their color cartridges anyway because the manufacturers make more money on the color ones. You can try looking around the settings on the machine and in the printer preferences to see if you can tell it to ignore the ink levels and see if you can continue to print.
Dec 19, 2009 | Lexmark X5150 All-In-One InkJet Printer
Color cartridge missing
You may want to remove the power brick at the back of your printer, wait a few seconds and reinsert back. Then try the steps listed in the user guide to install new carts, page 42.
http://www.lexmark.com/publications/pdfs/x5150/eng/ug.pdf
Jun 01, 2009 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X5150 yellow and black ink not printing
Take a piece of kitchen tissue (not cloth) dampen it and wipe over the print heads. If you don't see any ink on the tissue do it again until you do, Then let them air dry and try again.
May 02, 2009 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X5150 black ink cartridges won't print
The original Lexmark-branded 81 and 82 cartridges shouldn't cause a problem - regardless of the country of origin. I can't speak to any reman or refills, because quality varies widely. Have you contacted Lexmark's technical support - accessible via www.lexmark.com? There should be a solution for the Lexmark-branded cartridges. If that doesn't work, put one of the "bad" Lexmark cartridges in their recycling bag and include a note about your problem, including your email address.
Mar 17, 2009 | Lexmark X5150 All-In-One InkJet Printer
Hardware error o504
It shows color cartridge is missing because either the cartridge is not well placed or it is not there.
When you try to run the Clean option from the Ink Cartridge menu, the following message may appear: Hardware Error 0504.
To resolve this issue:
  1. Take both cartridges out of the printer.
  2. Switch off the printer using the power button.
  3. Disconnect the power cable from the back of the Lexmark X5150.
  4. Leave the power cable disconnected for 30 seconds.
  5. Reconnect the power cable and switch the printer on again.
  6. Reinstall the cartridges. (Follow the instructions on the LCD screen or refer to the following document: How to Install the Cartridges in the Lexmark X5150)
Jan 11, 2009 | Lexmark X5150 All-In-One InkJet Printer
All in one printer fault
Pull the cartridge check to make sure you removed the seal. Take a damp cloth gently wipe across the ink openings. If you get ink reinstall. Go to printer settings and make sure you are not set on documents black and white but on colour printing. Go to maintainance run test page several times. hope this works for you.
Sep 11, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark x5150
Your ink cartridges have dried out. Replace the black to confirm this prognostication and, if black works, replace color also. If you are into refilling ink cartridges youself try soaking the black one in 91% rubbing alcohol in a small ziploc type bag for several days. when the alcohol becomes ink colored, remove the cartridge from the baggie, dry it with tissue paper, reinstall it in the printer and up to 3 times run a clean the nozzles page until it prints a solid black line. Repeat with the color cartridge. Good luck.
qwester1
Apr 02, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X5150 All-In-One InkJet Printer Logo
107 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
