Question about Kenmore Microwave Ovens
Latch problem on model 721.8506 - Kenmore Microwave Ovens
The door latch broke
Slightly different model, but this will help you fix it.
https://m.youtube.com/watch?v=JqeeGBhRwFw
Feb 06, 2016 | Samsung SMH2117S
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
Door Spring
Door Latch
Door Hook
Button Spring
Button
Handle Actuator
Apr 02, 2013 | Microwave Ovens
Stopped working. Light on. Door will not latch shut. Latches on door move up and down easy.
A model number would help us help you pretty specifically, but without it, here's a generic answer.
The service manual would help you get the part numbers and help with disassembly, but without the model number, I cannot give you a link to the manual.
The problem is that your door latch spring has come loose, either from the inner door panel or the latch assembly.
You can find links to helpful exploded view diagrams and order parts here.
I'd recommend that your bookmark this link to your favorites.
We're
happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Oct 18, 2012 | Samsung Microwave Ovens
My Kitchenaid khms155lss-2 has a problem latching completely. Once finally latched the microwave would start and then stop during the cooking time because the door became unlatched. I have to stand by the...
Ok.Agreed,latch is not cracked or worn out.But check the grip of latch.Open the door.The hold the latch in your hand and see,if its loose or tight.It should be tight.Press the latch towards down and move it left/right slowly --- slowly.And inspect the latch.It will move,there will be a moment but the position of the latch in the door frame should be tight.If you feel that latch is got very loose,then the door frame needs to be disassembled and latch assembly has to be repositioned and fitted.In most of the cases this latch breaks/cracks and it needs replacement.But in your case,its different,you mentioned that if you keep your oven door pressed then latch remains closed..So if latch is broken/cracked it will not get closed properly.So as per that i think,you will have to check the opposite side of the door frame,where this latch gets into.On that side,there is a interlock type part.Which holds this latch.That part is operated by spring.If in-case that interlock type part or the spring,any of this is got loose then latch will get released after few minutes.--------------- But first as regular troubleshooting,you inspect the latch.Do you feel its loose or getting very easily moved,then open the door frame and check the latch.----------- For that you will required door disassembly diagram:--- Click the link,see part number 3 is door latch.-------- http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/W0505176-00002.png -------------- If the latch is properly positioned and intact then ,you will need to disassemble the opposite side cabinet to check the internal part,which hold the latch.For that you will require complete disassembly:---Click this link for complete disassembly:-- http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Microwave-Parts/Model-KHMS155LSS2/0593/0123370?pathTaken=&prst=0&shdMod=KHMS155LSS2 -------------- The door latch itself or other parts holding the door latch,none of the part is costly then $10.The cost of part is under $10.---------It just require you to figure out,either is cracked /broken part or just loose misaligned part.-------- This will help.Thanks.Helpmech.
Feb 10, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
I opened the door on my sharp microwave and now it wont latch. it sounded like something snapped off where the door latches to the microwave, not the door itself . Even if the door is held shut the light...
It may be the latch head spring or the door open lever or button.
DOOR SPRING LATCH HEAD HOOK
If you gently push up on the door latch heads (hook-like devices sticking out of the door) there should be spring tension. If they just flop right up, the spring is off inside.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
you have to separate the door panels (as shown in the attached photo) and then you'll see how it goes together.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
DOOR OPENING BUTTON LEVER
What usually breaks is the door open lever, but it may also be that the rear side of the door open button has worn down too far to work.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, only the control panel needs to be removed.
Please unplug the oven first.
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
You can usually find exploded views and part numbers for Sharp models by entering your model number at the Sears parts site.
If not, let me know. We have many Sharp manuals and if we have yours, we can link you to it at no charge.
The best place to order Sharp parts is
Encompass (formerly Tritronics).
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Oct 10, 2009 | Sharp R-1480 Microwave Oven
Model # 721.80823500
f-5 code on kenmore microwave oven means a problem with the door lock switch. Could be a bent latch or latch assembly that’s not actuating the latch switch correctly or that the latch switch itself is bad. Check the door switch, too.
plse do not forget to accept the solution.
May 02, 2009 | Kenmore 63792 Microwave Oven
Broken latch microwave door - won't open
I have a semmins microwave working in great condition, last night the latch mechanism inside the microwave don't allow the door latch to close.Only the top portion, bottom portion is ok.
Sep 14, 2008 | Sharp R-1870 Convection/Microwave Oven
The door will not latch
The latch head (with hooklike projections) have a spring to keep it pulled down. If the latch head can be easily pushed up and falls back freely, then the monting tab on the back of the latch head is broken and it will have to be glued or replaced. The new part is better. To get to the door screws inside, you have to remove the choke cover, as shown in the photo. You can order parts for Sharp models from Tritronics at http://www.wehaveparts.com.
Aug 31, 2007 | Sharp R-1480 Microwave Oven
Microwave Ovens Logo
23 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
