Question about Windham Accent Cabinet Bookcase
Windham cabinet instructions - Windham Accent Cabinet Bookcase
Can you provide under cabinet mounting instructions for GE Microwave part WX4-A19?
To mount it under a cabinet, you have to have the under cabinet install kit; you'll find that here: Under Cabinet Mounting Kit WX4 A019 GE Appliances the kit does include instructions. You can't mount it without the kit.
Dec 12, 2015 | GE Microwave Ovens
Temperature control
If you go to this website they can assist you with getting technical assistance on diagnosing your issue and getting a remote for you. Hope this helps. http://www.rick-horwath.com/Whalen_Windham_Combination_Electric_Fireplace_Heater_Manual.pdf
Dec 26, 2013 | Whalen Furniture Windham Fireplace TV...
I need a new flapper, where can I buy one?
any local home improvement store or this website:
http://www.sterlingplumbing.com/why-sterling/toilets
Mar 06, 2011 | Sterling 402315-96 Biscuit Windham...
Leaking collar, is this easy to repair?
not always. you will need flange repair kit, wax ring, wood screws, replacement bolts, caulk and shims
Nov 29, 2010 | Sterling 402315-0 White Windham Two-Piece...
I need instructions on how to build a room essentials bathroom wall cabinet made by Target.
I need instructions on the Home Essentials wall cabinet. My hubby threw away the hardware and the instructions to it.
Nov 06, 2010 | Home
We just installed this toliet yesterday and there was nothing in the instructions about how to set the water level, there is not enough water in the tank to flush the toliet properly
Depending on the type of water regulator/flush valve you have it varies. Usually there is a screw that regulates how much travel there is on the arm with the float on the end, or the float that moves up and down on the column. If you restrict this movement the water fills less and vice versa.
Oct 08, 2010 | Sterling 402315-0 White Windham Two-Piece...
Standard looking ballcock, but doesn't seem to use re-fill tubing. could this be siphon type of ballcock? Is there such a thing?
Yes that is a siphon type ballcock. And yes they do still make.
Good luck and please rate 4 thumbs for the free answer
Feb 28, 2010 | Sterling 402315-0 White Windham Two-Piece...
Every couple of minutes our toilet make a ''whooshing'' sound. Do you have any idea what this is.
its all down to water presher trying to fill the header tank,,,change the washer in the ball **** may help shut it up
Oct 24, 2009 | Sterling 402315-0 White Windham Two-Piece...
How do i change dryer vent direction(from back to bottom)
typically cabinets are screwed together and into the wall. Get a flash light and look for screws in the cabinet, under the cabinet and in the adjacent cabinets
Jun 13, 2009 | Maytag PYE2300AY Electric Dryer
Windham Accent Cabinet Bookcase Logo
151 people viewed this question
Top Windham Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Windham Furniture Expert? Answer questions, earn points and help others
