Question about Flotec 3.4 Hp Floodmate Submersible Sump Pump
Motor replacment for fpos 6000a
Need to remove motor from housing to replace motor
How do I replace thermostat in a 2010 ford escape xlt
On the top of your radiator is a big hose. Follow that house to the top of the motor. Where that house attaches to the motor, is the thermostat housing. Housing is usually held on with 2 bolts, remove housing and you'll find the thermostat.
Mar 03, 2015 | 2010 Ford Escape XLT
How can I get the front axles on my 97 Jeep Grand Cherokee to disengage and into neutral?
  1. Raise and support the vehicle safely. Position a drain pan under the shift motor.
  2. Disconnect the vacuum harness. Remove the housing attaching bolts. Remove the housing, motor and shift fork as a unit. Mark the shift fork for installation reference.
  3. Rotate the shift motor and remove the shift fork and motor retaining snaprings. Remove the shift motor from the housing.
Fig. Fig. 1: Shift motor and housing removal
  1. Remove the O-ring seal and discard.
To install:
  1. Add 5 oz. of gear lubricant to the axle through the shift motor housing opening.
  2. Install a replacement O-ring seal on the shift motor. Install the motor in the housing with the retaining snaprings and slide the shift fork onto the shaft with the reference marks aligned.
  3. Engage the shift fork with the shift collar and install the attaching bolts. Tighten to 101 inch lbs. (137 Nm).
  4. Connect the vacuum harness, lower the vehicle and road test.
  5. It could be damaged extreme 4x4 replaced one with a heavy duty unit
Nov 03, 2011 | 1997 Jeep Grand Cherokee
I trying to purchase an item but it states we do not delivered to P.O. Box, APOs, or FPOs. What is APOs and FPOs means
APO and FPO are U.S. military addresses overseas. If you aren't military overseas it will not matter to you.
Jun 04, 2011 | supermediastore.com
Intermediate gear and armature gear stripped on Milwaukee 6082. Is the armature gear replaceable? How do I remove both gears? How do I remove armature from motor housing?
No the armature gear is made as part of it. the intermediate gear is replaceable but you need a press. to remove the armature first unplug tool and remove brushes, then remove the 4 screws that hold the gear housing to the motor housing and pull out. the intermediate gear is pressed onto the shaft.. Let me know if you need more assistance before voting and thank you
Feb 20, 2011 | Milwaukee Saws
Blower motor replacement
Very easy!!!
Here ya go!!!
Removal & Installation
  1. Remove the right side sound insulator in the passenger compartment.
  2. Disconnect the electrical connector from the blower motor.
  3. Disconnect the blower ventilation tube from the module.
  4. Remove the blower motor screws.
  5. Remove the blower motor from the housing.
  6. Install the blower motor into the housing.
To install:
  1. Install the blower motor screws and tighten to 15 inch lbs. (1.5 Nm).
  2. Install the blower ventilation tube to the module.
  3. Connect the blower motor electrical connector.
  4. Install the right side sound insulator.
Jun 03, 2010 | 2004 Buick LeSabre
Starter solinoid replacement enstruction
SOLENOID REPLACEMENT
(see Figures 5, 6 and 7)
Prior to removing the solenoid from the starter motor unit, matchmark the solenoid-to-starter motor housing position, as shown in the accompanying illustration.
  1. Remove the starter motor from the vehicle.
  2. Detach the solenoid-to-starter motor wire from the solenoid terminal.
Do not disassemble the solenoid; if the solenoid is defective, replace the entire unit with a new one.
  1. Remove the two attaching screws, then slide the solenoid out of the starter motor housing flange.
Fig. 5: Before removing the starter motor solenoid, matchmark the solenoid-to-starter motor housing relationship
Fig. 6: Disconnect the field coil lead from the solenoid by loosening the retaining nut ...
Fig. 7: ... then remove the two attaching screws and separate the solenoid from the motor housing
To install:
  1. Inspect the solenoid plunger joint for wear or other damage. Replace it, if damage is evident.
  2. Apply Suzuki Super Grease A (99000-25010) or equivalent, to the solenoid plunger and to the tip of the lever arm (inside the starter motor-to-solenoid housing hole).
  3. Insert the solenoid into the starter motor housing, ensuring that the matchmarks made during removal are aligned.
  4. Install and tighten the two attaching screws securely.
  5. Attach the starter motor-to-solenoid wire to the solenoid terminal.
  6. While the starter motor is removed form the vehicle, perform the testing procedure to ensure that the new solenoid functions properly.
  7. Install the starter motor.
Hope this help (remember rated and comment this).
Mar 23, 2010 | 1994 Geo Tracker
I need to replace a heater blower motor on a 2004 chrysler pacifica and picture schematics etc;
  1. Disconnect and isolate the negative battery cable.
  2. Remove the passenger side cowl trim panel. See: Body and Frame\Interior Moulding / Trim\Trim Panel\Service and Repair\Cowl Trim
  3. Pull back the carpet to access the front upper screw that secures the air inlet housing.
  4. Remove the recirculation door actuator.
  5. Remove the recirculation door actuator wire lead from the routing clip located on the lower air inlet housing and position the wire lead aside.
  6. Disconnect the blower motor wire lead connector from the blower motor resistor or power module, depending on application.
118348823 Lower Air Inlet Housing
  1. Remove the one screw (from the top) that secures the lower air inlet housing to the upper air inlet housing.
  2. Remove the four screws (from the bottom) that secure the lower air inlet housing to the upper air inlet housing and remove the lower HVAC housing.
118348824 Blower Motor Wire Lead Grommet
  1. Push the rubber blower motor wire lead grommet through the opening in the lower air inlet housing.
  2. Feed the blower motor wire lead through the opening in the lower air inlet housing and remove the lower air inlet housing from the vehicle.
  3. Position the recirculation-air door as necessary to access and remove the three screws that secure the blower motor to the lower half of the HVAC housing.
  4. Gently flex the recirculation air door far down enough to remove the blower motor and wheel from the HVAC housing.
118348825 Blower Motor Mounting Tabs
  1. Remove the blower motor and wheel from the HVAC housing. Note the position of the blower motor mounting tabs.
INSTALLATION
  1. Position the blower motor and wheel to the lower half of the HVAC housing. Align the blower motor mounting tabs to the correct location on the HVAC housing.
  2. Gently flex the recirculation-air door far down enough to install the blower motor and
Dec 02, 2009 | 2004 Chrysler Pacifica
Crosely CDE 6000A electric dryer..Clothers take 1.5 hrs to dry
You need to clean your lint trap by taking the front off. There are 2 screws holding it on on the inside. If this isn't kept clean you will blow your thermal fuse. I just replaced my fuse due to the lint bulid up.
Mar 14, 2009 | Crosley CDE6000 Electric Dryer
Dryer not turning. belt is good
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Dec 17, 2008 | Whirlpool Dryers
Flotec 3.4 Hp Floodmate Submersible Sump Pump Logo
Top Flotec Garden Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
jasbo
jasbo
Are you a Flotec Garden Expert? Answer questions, earn points and help others
