Question about Refrigerators
Fridge part not working on Whirlpool Arc 7050 Fridge Freezer
Hi
As the title says, the frigde part on my arc7050 fridge freezer is not cold enough, it also from time to time will make a clicking sound. The control panel buttons on the top are pretty useless, as they don't even work when I try to press them, they just flicker.
The freezer is working fine, no problems with that.
Can anybody help
    Novelist:
  • 161 Answers
If this is correct:
1. No ice build up on back of freezer wall.
2. Fan in freezer is working.
3. Items in freezer are frozen, ice cream is a good test.
Then:
Why is the cold air in the freezer not getting over to the Ref. side?
1. There is a channel (tunnel) from the freezer to the Ref, side and there is a door which regulates how much cold air from the freezer goes through to the Ref. side.
2. The control panel may have it labeled as "Freezer" setting, from cold to coldest. The coldest setting means the door is almost closed and will keep most of the cold air in the freezer.
3. Since your control panel is not working then this door must be almost closed keeping all or most of the cold air in the freezer.
Any service tech should be able to check the control panel and find the problem.
Posted on Jan 25, 2009
Whirlpool fridge/freezer ARC 7050
see if you can remove panel inside freezer to see if its full of ice all over condenser .Even if you already defrosted for 1 day..If its full of ice ..Then the DEFROSTER COIL is not working and not melting the ice on condenser and then stoping the cycle therefore compressor will stop running..Also there should be a a couple of thermal switches on the condenser(two wires) if this is bad then there is no cycle..goodluck
Dec 06, 2007 | Refrigerators
Tip
Whirlpool Fridge
I am having trouble with my Whirlpool Fridge single door fridge. The top freezer is getting too cold and freezing the food too much and the bottom of the fridge is not cold enough, changing the settings on the fridge only makes it worse.
I have just recently chenged the fan, so what could be the proplem and how can I fix it.
on Feb 11, 2008 | Whirlpool ER6AHKXPQ Top Freezer...
The freezer is not cold enough but i don't see a temperature control inside. Does the one in the fridge also control the freezer?
Correct. The fridge works 100% off the freezer anyways. So they installed the sensor right between the freezer and fridge if you look inside you can see it.
Whirlpool refrigerator repair orange county, ca
Feb 06, 2010 | Whirlpool ER6AHKXPQ Top Freezer...
How do I defrost my whirlpool ARC 5070 fridge/freezer? (I lost the guide when I moved) Thanks to anyone who can help me
My whirlpool Fridge/freezer powers up but both fridge and freezer notworking,have defrosted the freezer but noluck,have turned on foran hourand then back again,as per user guide still no luck.
Jul 27, 2009 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
Freezer not freezing food and fridge not staying cold enough
Check the compressor with a volt meter, if the compressor is getting proper voltage then check the relay. But this sounds like a problem with the compressor
Feb 12, 2009 | Whirlpool GB9SHKXL Bottom Freezer...
Frigde not cooling bottom freezer all frozen up on back plate
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 26, 2008 | Fisher and Paykel E522BLX Bottom Freezer...
Whirlpool 20RB D4 Fridge Freezer clicking
Hi the reason for your noise coming from the fridge freezer is the plastic that is used in the design of your product is of a low quailty which reacts to the temp change and then as they get cold again they start to crack inside the frigde! Nothing to worrry about........
Hope this helps.....
Dec 23, 2008 | Freezers
Freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerators Logo
662 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
