Question about OneRoof CyberCafePro Client
Unrecognized database format - OneRoof CyberCafePro Client
I need to perform access database repair
The repair method attempts to recover only the tables, indexes and queries in the database. Do not attempt to repair damaged forms, reports, macros and modules. Before executing the Compact and Repair tool, please ensure the following condition:
1. Do not Open Access database must closed
2. Sufficient storage space available - minimum double in size of your Access database on that Disk.
3. Close the .mdb file related to .ldb file before you delete the .ldb file.
4. Then Run the Compact and Repair tool
Read more about Access Repair Toolbox
On:- http://www.access.repairtoolbox.com/
I tried lots of the suggestions and eventually found that this page was the most helpful http://www.filerepairforum.com/forum/microsoft/microsoft-aa/access/1385-%E2%80%8Bhardly-corrupted-access-2007-database
Feb 28, 2015 | Microsoft Office Access 2007 for PC
Unrecognized file format
So what is it that you were trying to do to get this unrecognized file format?
Apr 14, 2012 | Acer Aspire 4520-5141 Notebook
Mac says Jpeg files are "unrecognized format"
The memory card may have corrupted. You may need to try using recovery software to download your photos. Try the mac links provided in this article. Once you've recovered your photos, and backed them up on your computer, format your memory card in your camera, using your camera's format feature (look for it in the menus).
Oct 01, 2011 | Kodak EasyShare Z650 Digital Camera
Hello I use verifone PCCharge, when I turn it on , an error message pops : "Password backup update failed.Shutting down PCCharge payment server"
PCCharge uses Access database, which is stored in .mdb file. Locate this file. Mine was in C:\Program Files\PCCW\PCCW.mdb.
- Back up this file.
- In the same folder where you found the database, there should be a program called VISDATA.exe. Double click on it to start it.
- Go to File > Repair Database, and point it to your database file (pccw.mdb).
- It will ask you if you want to open db, say no.
- Go to File > Compact Database, and point it to your database file.
- It will ask you if you want to compact to 2.0 or 7.0. I was told to use 2.0.
- It will ask you if you want to replace database, say yes.
- For encrypt, choose No.
- For open, say No.
- Close VISDATA.exe
- Try running PC Charge now.
- If it still gives you trouble, and if you don't mind losing all your history, move the pccw.mdb file out of PC Charge folder (C:\Program Files\PCCW\). Keep it somewhere else for backup, just get it out of PC Charge folder. Now, start PC Charge again. A new database will be created.
Mar 16, 2011 | Computers & Internet
How can i repair a damaged access database
There are some reasons which may damage your MS access database such as virus infection, software crash, accidental shutdown of system, unrecognized format of database, corruption of storage media etc. These issues are easy to overcome by using third party software of access database repair.you can try Kernel Access Database Recovery Software one of the best software in Data Recovery
For information you can visit here ...http://www.accessrecoverytool.net
Aug 23, 2010 | Microsoft Computers & Internet
Run-time error '-2147467259 (80004005)': Unrecognized database format 'C:Windowssystem32wints.dat'.
To fix this program, you need to rename a folder containing a previous version of the installer. Open My Computer and navigate to C:Program FilesCommon Files. Right-click the Installshield folder and select Rename. You can rename the folder anything, but, as Google suggests, something like Installshield-old will give you a hint about the folder’s previous name. Close My Computer and try running the installer again. If that doesn't work tell me and I will see what I can do.
Aug 19, 2009 | Microsoft Windows Vista Home Basic Edition...
Error 3343 when I start PC Charge, how can I fix this?
error 3343 is a database error. Unfortunately, PCCharge is still in the stone-ages of computer technology and they think VB6.0 and MS Access 2.0 are stable and secure ... At any rate. 3343 is simply an unrecognizable database, in this case due to corruption. There is a program in the PCCharge directory called VisData. This will allow you to run a repair and compact the database. To use:
First make a backup of your PCCW.MDB database in your PCCharge directory (C:\Program Files\Active-Charge (PaymentServer); C:\Program
Files\PCCW (PRO)).
Execute VISDATA.exe.
File -> Repair MDB.
Select the PCCW.MDB database from your PCCharge directory.
Select 'No" to open Repaired Database.
File -> Compact MDB ... 2.0 MDB
Again, Select the PCCW.MDB
It will then prompt for what you want the database to be named. Simply select PCCW.MDB again, select 'YES' to replace existing database.
Select 'NO' to encrypt database.
Select 'NO' to Open Compacted database
Exit Visdata and start PCCharge.
It would also be a good idea to go ahead and update to the latest available Scripting Runtime library. This can be found by going to microsoft.com and searching for the phrase 'windows script'. (To my knowledge, 5.7 is the latest version).
Jul 16, 2009 | Go Software Inc. PCCharge Pro...
Honestly, try transferring the images to your computer without using the Easyshare software. This software has been causing some problems for some users. After you have the images on your computer...open them up and then save them as JPEGs. This should help fix the problem with the transferring.
Oct 11, 2007 | Cameras
"Unrecognized File Format"
This error message indicates that the camera cannot read the picture format. Transfer the unreadable picture to the computer, or delete the picture.
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Computers & Internet Logo
194 people viewed this question
Top OneRoof Computers & Internet Experts
David Payne
David Payne
Are you an OneRoof Computer and Internet Expert? Answer questions, earn points and help others
