Question about Bernina Activa 130
I have a problem changing the needle in my activa 130 bernina
I am not sure how to remove and replace it.
  • 202 Answers
You will find a screw on the side near the top of your needle. Just loosen it and the needle will come out. Then put in a new one, pushing it all the way up with the flat side toward the back and tighten the screw. Finger tight is usually good enough.
Hope this helped.
Rick
Posted on Mar 22, 2009
Also you will want to put a piece of paper over the stitch plate so that if you accidently don't have a good grip on the needle it won't fall in the hole that the needle goes into when you are sewing.
You don't want any further problems & sometimes it's hard to get a piece of the needle out from under the stitch plate
Posted on Jun 06, 2010
Needle will not tighten in my Bernina activa 130. Do I need a new needle tightening screw?
Hm, could be. Or the needle clamp could be defective. Replacements can be purchased for a very low price.
http://www.sew4less.com/category/64/Needle_Clamp_and_Needle_Screws
Jun 27, 2017 | Bernina Sewing Machines
My bernina activa 130 is suddenly making very fine, tight stitches. How do I solve that?
Remove the needle plate (by pushing on right rear corner of plate) and clean out any lint build up from the feed dogs and replace plate.
Sep 22, 2016 | Bernina Activa 130
Can Bernina walking foot with soles and seam guided used on Activa 210 be used on 16 yr old Bernina Activa 230????
Please be advised that the newer machines (Classic models) such as the 130-180 and up, have a totally different geometry. This is to say that the older machines have a shorter distance from the center of the presser bar to the needle center. The newer machine design was increased to provide space for needle threaders etc. Older machines will use an older Walking foot model (still available).
Feb 27, 2014 | Bernina Activa 130
How do I keep my results from puckering when I double needle stitch with my Bernina Activa 130?
try adjusting the top thread tension
also rethread the top & bobbin,, to make sure the thread is not
caught anywhere
also try changing the needle
Oct 03, 2012 | Bernina Sewing Machines
I have a bernina activa 130 and when you turn the wheel to insert the needle into the fabric the needle breaks. I am not sure what to check.
Check that your needle is centred when straight-stitch is selected and / or that you have the correct stitch-plate fitted. Is the needle breaking because it is hitting the stitch-plate or is it breaking when the needle goes down through the slot/hole in the stitch-plate. If you are sewing zig/zag or patterns, you must have a slotted stitch-plate fitted. If it's breaking when the needle passes below the stitch-plate, then take the bobbin /bobbin case out and the hook/shuttle and see if it still happens. If it does, the timing on your machine may be out and need professional adjustment. If it doesn'y happen after removing just the bobbin case, make sure the bobbin case is being correctly fitted.
Sep 19, 2011 | Bernina Activa 130
What needle do i i need for a bernina patchwork 140 ?
The 130/705H needle system is standard across most domestic sewing machines so should be what your Bernina takes too.
Aug 31, 2011 | Bernina Activa 140
How do you oil a Bernina Activa 130? The manual doesn't say anything about it.
Remove needle, needleplate, presser foot and bobbin case. Now take a lint brush and clean under the feed dogs and hook area. take the bernina oiler(must be bernina oil only) now place a drop just below where the bobbin case clip on and one small drop under the feed dog area. replace items, sew out a test sample and away you go.
Apr 27, 2010 | Bernina Activa 130
Needle always stops in up position
I have the Activa 131 and while the needle is made to stop in the up position, all you have to do is push the bottom of the peddle quickly with your heel and the needle goes into the material and stays until you start sewing again. Hope this is helpful.
May 25, 2008 | Bernina Activa 130
Sewing Machines Logo
69 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
