Question about Toshiba 42H81 42" Rear Projection Television
Power light on no picture and a thumping sound
I turned off my tv came bake about a hour later and turned it back on and i hear a thumping sound and dont have a picture. do you know what i need to fix it? it is a av-65wp74 jvc
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Almost always, your described problem indicates a hardware fault and that the unit has kicked into auto-protect mode. Pls determine if there are any flashing lights. If yes do note the sequence/number of flashes/blinks. You may want to try and unplug for an extended period to revert unit back to factory default. If that would not be corrective, then the unit has to be opened for diagnosis and voltage measurements. Familiarity with electronic components & circuitry, use of a DVM and a soldering iron as well as access to a service manual and/or a schematic diagram would be required. Should you feel uncomfortable working with high voltage and performing a DIY (do-it-yourself), perhaps your best bet would be to seek the services of a qualified professional.
Should you venture DIY, pls post back the chassis number. Good luck and thank you for using FixYa.
Posted on Jan 25, 2009
Hello, I have a L.G. 55LW5300 3D Hello, Hello, I have a L.G. 55LW5300 3D LCD T.V. and it will not turn on?
You need to contact your insurance because that surge destroyed the TV circuit boards.
Sep 28, 2016 | Televison & Video
Pioneer Plasma TV-PDP-4270HD won't turn on. TV
Try this! There should be a power button on the bottom of the panel that has to be depressed for the television to power on. It is the main power supply button and without it there is no power going into the TV.
Mar 16, 2010 | Pioneer PDP-4270HD 42 in. Plasma...
My TV does not power up when the power button is pressed.
It's sounds like your lamp or backlight has went out, I suggest reading your manual for service info and look online for a local repair shop.
May 16, 2009 | Televison & Video
Tv would not come on..sound then came on.. 1 hr later picture
That sounds like a faulty inverter board.
The inverter board is the high voltage board that supplies power to the back light lamps.
The inverter must be tested and eventually replaced.
Mar 09, 2009 | Astar LTV-3201 32 in. LCD Television
New Blue CRT installed now TV won't stay on
sounds like the HV lead isnt sealed properly either at the CRT or the Splitter I would have him come back and recheck his connections
Jun 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Power button Flashes
For the first one, please list the model number and count the blinks. Also, can you please post each problem separately. It will get too confusing trying to address 3 sets with different but similar problems.
Thanks,
Dan
Mar 18, 2008 | Televison & Video
No picture, but power light is on
THE POWER SUPPLY OF YOUR TV WAS THE PROBLEM,YOU COLD SOLDER THE MAINBOARD OF YOUR TV,AND THE CRT SOCKET CONNECT TO THE TUBE IS ALSO COLDSOLDER,.
Mar 13, 2008 | RCA 27F530T 27" TV
Sound but no picture
Basic repair for skilled TV repairman = solder connections on
vertical output IC.........Can be done in home.....T.
Nov 28, 2007 | Sony KV-35S42 35" TV
Toshiba 42H81 42" Rear Projection Television Logo
22 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
