Question about Bernina Artista 180
Bernina 180E Embroidery module not recognized
When module is plugged in the sewing machine does not change screens to the embroidery, does not recognize it!
Any ideas???
  • mjbcrafts Feb 01, 2009
    My machine is doing the same thing. It will look to the module, but will not recognize either the preprogrammed designs or the card inserted.
  • Anonymous Feb 27, 2009
    When the embroidery module is plugged into the machine, I get a message in the emb. software that says "embroidery module is not attached." Also, the screen on the machine does not change to the pictures of the module and the teddy bear. If a board needs to be replaced, could you give me the approximate cost?Thanks.
  • 202 Answers
Anytime there is a communication issue between machine and module attach the module to a different machine and check it. Possibly at a dealership. This will tell you whether its the machine or module. If its the machine then the soldering points on the embroidery module plug to the A-print (on the side of the machine) circuitboard need to be checked. Then most likely replace the A-print circuitboard.
There are other tests that need to be done in the service program that will help pinpoint and troubleshoot issues with the embroidery unit. Such sensors or stepping motors, etc. Should be left to a tech.
Hope I helped.
Posted on Feb 11, 2009
My Bernini 830 would not recognize the embroidery attachment. I re-attached many times, but it doesn't work.
I assume you mean a Bernina 830. If you have removed the slide-on table, I have two possible solutions. I've seen this with a couple of Viking embroidery attachment units. (I am also assuming it's not a hoop issue.)
You could have corrosion on the pins that send the signals between the embroidery attachment and the sewing machine. Remove the embroidery attachment and turn off the sewing machine. Unplug the sewing machine. Spray the pins with an electronic contact cleaner; one example is here: http://www.homedepot.com/p/CRC-QD-11-oz-Contact-Cleaner-02130-6/202262505 . Push the embroidery attachment into the sewing machine by lifting up the far side and then sliding it into the port. Remove the embroidery attachment. Repeat this a few times. (The friction of the insertion and removal will remove any dirt or corrosion.) Plug in the sewing machine and turn it on. Try connecting the embroidery attachment. If it works, remember to clean the contacts the next time the embroidery attachment isn't recognized.
Once I helped someone with two sewing/embroidery machines with an unrecognized embroidery attachment. In that case, the person swapped which embroidery unit went with which machine. The contacts were not the same and didn't mate. Once the correct machine and embroidery unit were paired, the embroidery unit was recognized instantly.
I hope this helps. If it doesn't, you may need to talk to your Bernina repair technician at your local shop.
Aug 19, 2017 | Sewing Machines
Can I use Bernina Embroidery Cards with my Janome MC9500
Getting That Embroidery Design To Your Janome ...
https://tv-sewingcenter.com/janome/getting-that-embroidery-design-to-y...
Aug 21, 2010 - The designs will then be recognized by your embroidery machine, and you will spend more .... you can use either jef or jef+ for your 11000se .... like to know what brand,size and card reader to purchase for my Janome MC 9500. ...... Bernina · Elna · Embroidery · General · Janome · Necchi · Quilting · Sewing ...
Janome MC9500 100 Stitch Sewing 5.5x8" Embroidery ...
www.allbrands.com/products/8905
Janome MC9500 5.5x7.8" Embroidery .jef Format Replaces Memory Craft MC9000 ... to creative quilting and clothing construction, your sewing projects will go ... designcards) or Compact Flash Memory Cards (as used in digital cameras). ... My set screen controls for contrast, In./Cm. designation, and other customization
Which format does my machine use? - Embroidery.com
https://www.embroidery.com/help.ec?docID=225
Dec 26, 2015 | Janome Sewing Machines
I have a Bernina Artista 180 with embroidery module. I put in the plug in the wrong direction once and now it will not connect the module to the sewing machine. Can this be fixed?
It is very likely that when you attempted to connect the embroidery unit with the plug out of alignment that you would have bent some of the pins on the male side of the plug. It is possible, though not advisable, to straighten the pins in this pug. However, if not done perfectly, this could cause further damage to both the male and female sides of the plug. I would recommend taking it in to a local BERNINA dealer and repair center to have that cable replaced just to be safe.
You can find a nearby dealer at: http://www.bernina.com/en-US/Where-to-Buy-US/Store-Locator
Sep 22, 2015 | Bernina Artista 180
Bernina Artista 180 firmware question: I sold a Bernina Artista 180 sewing/embroidery machine. This machine was from 1999 and never had any firmware updated. The embroidery module was damaged in sh
I'm not exactly sure what you need but I'll give you a web site where I believe you will have good results:
http://www.ebay.com/bhp/bernina-software
Dec 15, 2014 | Bernina Artista 180
I have a 180E which I have had from new about 6 yars....The embroidery unit keep switching itself off. I took it to my dealer about 6 weeks ago. He says he thinks he knows what it isbut is waiting for...
The fault is coming from the side board where you plug your embroidery unit, it is called a com port part 004 531 7000. Bernina had issued a update bullitin to this part. check with a good bernina and they may still cover it under warranty . all the best
Apr 11, 2010 | Bernina Artista 180
180E Hoop problem
Joan, there are 3 micrositches on your embroidery unit arm. these switches are depressed when you attach the hoops, it appears from your comments that one switch is not functioning. This could be simple, it is out of alignment or more complex it is broken. Either way you need to take it to a professional for repair.
Dec 21, 2007 | Bernina Artista 180
Sewing Machines Logo
810 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
