Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
I need a manual for a DECT 2888-3 Uniden 6.0 phone, also, when I try to call out, I get this message "your call cannot be completed using this call restricted phone," which just started happening
  • 3 Answers
SOURCE: cant register/install a new dect 6.0 uniden 2060 phone
I had a similar problem which I finally fixed. You did not say if any of your phones registered.
First try the following recommended by Uniden Support:
Your phone(s) should be fully charged before putting them on the main base.
Unplug the battery from the phone by removing the battery cover and removing the connector. Then, push the # and * key together and hold while you plug the battery back in (requires some dexterity). Continue to hold the two keys until you hear a confirmation tone. This will force the phone to reregister. Put the phone on the main base (if you are sure it has a fully charged battery) and see if it will reregister it to solve the problem.
That did not work for me. So, I followed the instructions to de-register the handset (even though it hadn't really registered). But, I also pretended like the Base was not available (because using the base in this step also failed).
1) Press and hold the hang up and # keys for at least 5 seconds.
2) Move the cursor to select Base Unavailable and then press Select.
3) Select the base you want to deregister from, press Select and then move the cursor to Yes and select.
This causes the phone to delete any of its base information.
At this point, again insure that your phone shows the battery is fully charged and if it is not, put it on the stand alone charger base (not the main base). With the battery fully charged, place it on the base and try registering again by placing it in the main base.
If neither of these approaches help, contact support at Uniden.com.
However, my problems were cleared when I cleared the handset with the second set of instructions.
Posted on Apr 26, 2009
SOURCE: Will Uniden 2085 DECT phone work in india
Caller ID standards are different in India,so caller id won't display ; need to buy a converter which converts from DTMF to BellFSK standard
Posted on Aug 24, 2009
  • 569 Answers
SOURCE: I need an Uniden phone DECT2080 owner's manual.
You can find the manual here:
http://www.uniden.com/pdf/DECT2080om.pdf
Posted on Dec 16, 2009
consultel1
  • 860 Answers
SOURCE: my cordless phone says
With the phone in standby, press MENU/SELECT on the base.
Move the cursor to select the Register Handset menu, and then press MENU/SELECT. Handset Registering will appear.
On the handset, press and hold # until the handset beeps and displays Handset Registering.
When the handset has registered to the base, the LCD will display Registration Complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
Note: If a handset has ever been registered to a base, reset the handset before you register it to a new base
Posted on Dec 21, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: UNIDEN DECT 6.0
DECT 6.0 is not a model number, it's the generic name for the cordless phone technology in use. So I can't give you a more specific link than this one, which takes you to Uniden's download page for manuals. Pick your model from the list, and the manual will explain the steps you'll need to follow. Your phone's model number is on a sticker normally found on the rear or bottom of the base unit.
Posted on Mar 27, 2010
Testimonial: "thank you very mucy "
How do I reset the message on my Uniden DECT 6.0 cordless phone?
Hello Miriam Taylor,
Listening to the message should be sufficient.
Mine wasn't a real message... I fat fingered the
base trying to INTERCOM to my wife's remote.
As I never intended to use my system as an answering
machine... I deleted it too...
If you look really closely at the 1,2,4 & 5 key on the touch pad of each wireless remote the (play) right arrow seen on the base
is adjacent to the 2 key... Press it...
Delete will be an OPTION above the SOFT keys associated with the menu words on your display... (off & message gone).
Then made sure MY ANSWER FEATURE was "OFF".
You will have to read the manual... (RTM, below).
Message access can be accomplished three ways...
at the Base, at any cordless station... and (off premises)
remotely from anywhere in the telephone network.
Hope this helps...
ELSE RTM.
My favorite site for FREE manuals
is manualslib (MUST provide actual model numbers)
No exact matches found Try these results
Uniden DECT 6015 Owner Manual
Amazon com Uniden DECT 6 0 cordless phone Office Products
Carnac the Magnificent
Jun 17, 2017 | Uniden Lands Phones
HOW DO YOU RESET ANSWERING MACHINE ON 6.0 UNIDEN PHONE
Answering Machine - Uniden Support
unidensupport.com/AnsweringMachine
Get support for your Uniden Answering Machine. ... For models that have an */envelope key on the handset: ... How To Change The Record Time & Ring Time.
Customer Support
mycusthelp.net/UNIDEN/_cs/AnswerDetail.aspx?sSessionID=&aid=270585 How Do I Set The Greeting On My DECT 6.0 Cordless Phone Answering System? Question: Answer: To record your greeting on the DECT Single-Line Models, please do the following: 1. ... features your model may have can also be found in your owner's manual. ... http://www.uniden.com/index/manuals_results.cfm?cat=1
I have a Uniden phone/answering machine, DECT 6.0, number ...
www.justanswer.com > Electronics Question > Phone Problems I have a Uniden phone/answering machine, DECT 6.0, number BK20033715. I purchased it about a year ago. I need to change the message on the answering ...
[PDF]owner's manual - Uniden Australia
https://www.uniden.com.au/RESOURCES_MAIN/pdfs/DSS7955_1_OM.pdf Terminology used in this Manual . ... Answering Machine Features . ..... change global settings at a time, and you have to make sure the phone is not currently ...
Owner's Manuals - Uniden
https://www.uniden.com/product-information/owners-manuals Owner's Manual. Search for an Owner's Manual. The product name/model number is on the product's ID label on the back, bottom or in the battery compartment ..
RESET ANSWERING MACHINE ON 6 0 UNIDEN PHONE Google Search
Apr 20, 2017 | Uniden Lands Phones
How do I find messages/mute?
To hear your messages, press PLAY on the base.
To mute, press CLEAR on the base.
See pages 22 and 6 of the manual: Owners Manual User Guide for Uniden Dect2188 3 Dect 6 0 Cord cordless...
Feb 22, 2015 | Uniden Dect2188-3 Dect 6.0 Cord/cordless...
Out going message for uniden dect 6.o phone
Select the model of your Uniden DECT 6.0 system from the list beginning at http://www.uniden.com/scat/dectphones_mnl to download a copy of the manual.
Dec 20, 2013 | Vtech DECT 6.0 Cordless Phone with Digital...
UNIDEN DECT 6.0 don't have manual need to
Select the model of your Uniden DECT 6.0 phone from the list beginning at
http://www.uniden.com/owners-manuals/dect-phones/scat/dectphones_mnl/
to get the manual.
Sep 01, 2011 | Uniden DECT 6.0 Cordless Telephone...
I have a Unidend Digital Dect 6-0 phone with one extension How do I delete the messages after I hear them? I lost my manual.
Since you didn't tell us the model of your phone, select it from the list beginning at
Jul 19, 2011 | Uniden DECT 6.0 Cordless Phone ID
I have lost my manual and i dont know how to record a personal message on my answering machine and how to enter the code to retrieve my messages from another phone.
From your handset, you just have to press the mute button, your phone should start telling you the time, date, ect. press the #5 key and then the #8 key and start recording your message. When finished press the # 8 key again. Hope this helps
Mar 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
How do I change the message greeting on my uniden dect. 6
Since you declined to specify the model of your Uniden DECT 6.0 system I can only suggest that you select it from the list beginning here to download a copy of the manual.
Mar 11, 2010 | Uniden DECT 6.0 Cordless Phone ID
Uniden dect 6.o
What model Uniden DECT 6.0 phone/answering machine?
Mar 11, 2010 | Uniden DECT 6.0 Cordless Telephone...
Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
201 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
