Question about Samsung Digimax 530 Digital Camera
No display on lcd no picture
Hi, I have digimax 530 the problem is that it can display maenue it opens lens every thing is fine just the main thing that it dose not display image in lcd neither it stores image into memory, flash is working menue is working button is working click sound is there but no image I also used external memory card that also turns out to be blank. I sent it to the local Samsun authorised service vendor they suggest me that parts are not avialable and you better buy a new one. Are you agree with the service man, or there is any solution. Tank you Shams
  • 3 more comments
  • Shams Haque
    Shams Haque Jul 12, 2007
    hello guru,
    I am also a semi professional electronic mechanic and I am sure if you could guid me in dismantling the camera then I can fix it. Thank you for your suggestion buying a new one the same I was suggested by the authorized service personal here in Kuwait. Which I cant effort at the moment.
  • Shams Haque
    One thing I dont understand according to you it is the shutter ok, if it is shutter then why the image is not coming in lcd screen. the screen is on menu is there but no image displays.
  • Shams Haque
    Shams Haque Jul 13, 2007
    ok what about the image can not be seen in the screen it is also because of the shutter
  • Shams Haque
    If I could have access to the technical diagram then I think I can fix it up.
  • Shams Haque
    Shams Haque Jul 16, 2007
    I did not get another solution or guaranteed solution, So can I get my money back as promissed.
    Thank you
    Champion:
  • 206 Answers
Insert a memory card that you know has properly stored images on it and that works fine on another camera. If you can play these images back on your camera and they appear fine in play back mode , then your problem is a CCD sensor fault and it has to be replaced. It may not be economical to repair though.
Posted on Sep 06, 2007
    Novelist:
  • 107 Answers
The shutter is jammed closed. This blocks the light from reaching the image sensor. This problem can generally be fixed without parts, price will be $100-150 for labor from a professional. Depending on the purchase price of the camera, you may be better off getting a new camera.
Posted on Jul 12, 2007
  • 1 more comment
  • David Millier
    David Millier Jul 12, 2007
    The operation to free the shutter is more of a mechanical process then an electronic. The camera body will have to be opened. The electronics generally have to be removed, and the lens assembly removed from the camera. You can then open the lens assembly and disassemble the moving elements inside. At this point you should have access to the shutter element which moves in the middle of the lens, you can re-set the movement of these delicate blades and re-assemble the camera. I do not have specific information on this model, so I cannot offer specific instructions on these operations only a general process of how it is done.
  • David Millier
    David Millier Jul 13, 2007
    The shutter is jammed closed. Normally it is open and only closes when you take a picture. This closing allows the image sensor to record the image in darkness.
    Because the shutter is stuck closed, light never reaches the sensor and everything appears dark.
  • David Millier
    I do not have that information. My apologies.
Samsung Digimax Cyber 530 does not show image on screen
Check the memory cards on your PC for the quality of the images that were shot now. if there is no fault seen the fault is in the display section. It can be a fault of the LCD or the failure of the flexible strip to the LCD.
May 06, 2011 | Samsung Digimax S500 Digital Camera
The screen is black. And pictures turn out black.
Hi there your lcd screen is fine but the Chances or damaged are lens or sensor of lens or circuitbord disconnect from the lens sensor. All cases you need to visit service center. Thanks.
Apr 04, 2010 | Samsung Digimax D53 Digital Camera
Samsung digimax s500/cyber530 won't start with new batteries
I have a samsung digital camera digimax cyber 530 - just replaced batteries and camera wont start, i get 3 flashes from the green light screen nw comes on then goes off & the lens wont retrack back in the camera
Oct 20, 2009 | Cameras
Dark Screen
Your lens can not open the shutter, or CCD is dead. If you kept your camera in your pocket, most likely fine dust got in the lens and ultimetly between the shutter blades and now due to friction they can't open. But if you kept your camera clean, then it is dead CCD. You can have it fixed by replacing the CCD or the entire lens, but in particular this SD1000 camera the main board components can go wrong too. You can sell it "as is" on ebay for $50-70 and buy a working one for 80-90, the difference would be $20-30.
Jul 23, 2009 | Canon PowerShot SD1000 Digital Camera
Auto focus quit working
Did it get dropped when the camera was open? If so it could have made the lens pop out more on one side. I'm not sure how to really explain it. When you open the camera, the thing that comes out might be off track I guess you could say. What setting are you using it on?
Dec 21, 2008 | Samsung Digimax S730 Digital Camera
Cracked lens
Its very expensive to repair something like that. Usually it is more money than the camera is worth.
Jun 14, 2008 | Samsung Digimax 530 Digital Camera
Camera will not take a picture
an idea passed over my head just now
several ideas
was the camera droped
was the camera exposed to heat
was the camera exposed to static electricity
was the camera exposed to water or liquids
ect.
if these or other things happened to camera
the shutter inside camera has malfunctioned due to the reasons
May 10, 2008 | Samsung Digimax S500 Digital Camera
Samsung Digimax 530 - Zoom Error
I had to send the camera to NJ for repairs. It cost $58 for parts, labor, and shipping.
Apr 29, 2008 | Samsung Digimax 530 Digital Camera
About picture size
I think you need to Reset the camera. On the menu select reset.
Apr 13, 2008 | Vivitar DVR 530 Flash Media Camcorder
Samsung Digimax 530 Digital Camera Logo
96 people viewed this question
Top Samsung Cameras Experts
Jerry Z
Terry Leonard
Terry Leonard
Are you a Samsung Camera Expert? Answer questions, earn points and help others
