Question about Hunter 28096 Westminster 52" Ceiling Fan with Light
Hunter Fan # 20723 The Westminster - lights delayed when turn on
I recently installed the above fan. There is around 2 second delay when you turn the light switch on. I went and purchased another exact fan and it's doing the same thing? Any possible solutions?
  • 1 more comment
  • bryansieg Jan 29, 2009
    I'm experiencing the same problem: 2 second delay before incandescent light comes on. Doesn't occur with my other three fans. Very strange!
  • Anonymous Mar 22, 2009
    I have the same problem, but with a different model of Hunter ceiling fan. I'm pretty sure I wired it correctly. Maybe its something with their new fans.
  • someguyh70 Apr 07, 2009
    I have the same issue, bought 3 of the same model Hunter fan and all 3 are doing the delay. I did notice that if you use the pull chain to turn the lights on and off there is no more delay. The delay only occurs when using the light switch.
Here is the answer I received from Hunter Technical Support.
"The light fixtures are manufactured with a limiter that prevents a higher than recommended wattage bulb from working. The limiter causes the slight delay even when the correct bulbs are is in use."
Pretty annoying if you ask me.
Posted on Apr 07, 2009
  • oldhouseman Jan 18, 2011
    Same issue, same correction Installed 4 ea 60w bulbs. Instructions says unit limited to 190w total. Change to 4ea 40w (160w total) and problem went away. However of the 2 fans installed at the same time, 1 eventually "failed" and the lights would just continue to flash on and off. Should have read those dang instructions....
Remove the limiter from the circuit... Light works fine without it. Just remember to use 40 W 120V Candelabra bulbs.
Disconnect "Light Out" (red wire) from the 4 black light socket wires, Disconnect the black "Live In" wire from the limiter. Connect the black wire from switch (that went to "Live In") and connect it to the 4 black wires going to the light sockets. Cut the "Common in" wire close to the limiter, strip it, remove the "Common Out" wire (white) from the 4 white (neutrel) light socket wires. Attach the stripped "Common In" white wire to the 4 white light socket wires. Limiter should now be completely removed from circuit, and black wire coming from pull chain light switch should be hooked directly to 4 black light socket wires. The 4 white light socket wires should have a white wire labeled "Common In" hooked to them. Hope this helps.
Posted on Sep 06, 2009
  • 1 more comment
  • Mizvickey Jun 11, 2012
    be careful, I cut my wire at the wrong end, near the connector and goofed up the whole thing... Oh well, new ceiling fan time... I still blame Hunter and believe me my new one WON'T BE A HUNTER! Good Luck to everyone else!
  • Mizvickey Jul 26, 2012
    assembly! :)
  • Sebastian Case Feb 15, 2013
    I bypassed limiter and went with black to red(in) capped redundant return(white) works fine
    President:
  • 2,976 Answers
If you're using a fluorescent light, this is normal.
Posted on Jan 25, 2009
If your Fan is less than a year old it's probably still under warranty. Mine was! I called Hunter and they sent out a new light ***'y. Fixed the problem and believe me nobody touches that fan but me! Good luck everyone!
Posted on Jul 26, 2012
How long after burner is on should fan come on ?burner going out fan not coming on how to test fan or thermastat?
Your furnace has a fan delay relay that should turn the indoor fan on once the temperature gets up to about 150 degrees near the fan. The delay relay closes and energizes the fan circuit and opens once the thermostat is satisfied and the main gas valve turns the gas off. The delay relay keeps the indoor fan running for until the air temperature gets back down to around 100 degrees. If the fan delay relay stops working it will need to be replaced. Temporarily you can turn the fan to on on the thermostat and the heat should operate normally until the relay can be changed. The indoor fan will just run continuously. At least you will have heat.
Hope this helps
Feb 12, 2015 | Heating & Cooling
My bryant furnace fan will not turn on. Everything is sequencing, the induction fan starts and the flame lights, but the fan will not turn on. The capacitor reads 4.86 uf. Any suggestions?
Your fan delay relay is not functioning. On most furnace fan controls, there is a fan delay relay that delay the fan from turning on until it senses the temperature increase, typically around 130 degrees. once the relay senses the temperature increase it closes a contact inside the sensor and turns the blower on. It is the same device that keeps the fan running once the furnace turns off. Just take the Model number and serial number to your local dealer and get a fan delay relay and replace it.
Dec 07, 2014 | Bryant Heating & Cooling
Does the exhaunst fan turn on automatically when we cook or warm food items in our Samsung Microwave -- SMH 9187W?
Some interesting reading on page 8 of the owner's manual:
"Boilovers cause smoking and greasy spillovers that may ignite and spread if the vent fan is operating.To minimize automatic fan operation, use adequate sized cookware and use high heat on surface units only when necessary."
And on page 20:
"If the temperature becomes too hot around the microwave oven, the fan in the vent hood will automatically turn on at the LEVEL 2 setting to cool the oven. The fan will automatically turn off when the oven has cooled down sufficiently. This is an automated process and cannot be turned off. The fan may stay on for 30 minutes or more after the cooktop and microwave controls are turned off. The Vent Fan will only operate in 1~4 levels modes while the microwave is working."
"Using the Vent delay off button
1. Press the Delay Off button once to turn the fan off after 1 minute.
2. Press the Delay Off button twice to turn the fan off after 3 minutes.
3. Press the Delay Off button three times to turn the fan off after 5 minutes.
4. Press the Delay Off button fiour times to turn the fan off after 10 minutes.
5. Press the Delay Off button five times to turn the fan off after 30 minutes."
If for some reason you don't have your owner's manual, you can still download it free here.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
Jan 01, 2011 | Samsung Microwave Ovens
How do I take my Hunter Model 20723 model fan down to put a different rod on?
there are a couple of bolts that hold the housing on, after removing the blades you should see more mounting bolts that attach to the ceiling....fyi disconnect power First!
Nov 06, 2009 | Hunter 28096 Westminster 52" Ceiling Fan...
Short delay in ceiling fan light turning on
I also ran into this "problem". Installed five of the same fan last week and four of them have the light switched, one of them is on a 3-way switch. All the switched lights delay when turning them on while the "always on" light operated by pull string is just fine.
Could find no explanation in the user manual other than, as previous post mentions, new federal regulations that limit the wattage. One can assume that there is some sort of regulator inside the light fixture that needs to power up and/or run some sort of check to see how much power is being pulled by the lights.
The delay is super annoying, but I suppose all light kits are going to have this now. Thank you FEDERAL GOVERNMENT!
Aug 01, 2009 | Hunter Ceiling Fan Control Switch
Vent axia SOLO PLUS SELV T fan has a delay timer fault
There is usually two pre sets; one for time delay before turning on and one for how long it runs for. Have a look
Sep 14, 2017 | Dryers
We purchased a hunter grand visita and when we turn the light on a the breaker box or the switch plate there is a delayed reaction before the light comes on whats going on?
Here is what hunter technical support says about this.
Mar 01, 2009 | Hunter 28096 Westminster 52" Ceiling Fan...
Installed new hunter westminster and the lights work but no fan. and how do i get my hunter remote to work with fan?
begin by unscrewing one wire nut at a time to be sure that the wires are tightly twisted together before the wire nut is reinstlled. Once you have the fan working manually, the remote will also work.
Jan 07, 2009 | Hunter 27187 Remote Control
My Fan makes a kncking sound when it runs on high speed
The bolts might be loosely fitted. So try to fit them tight
Jan 23, 2008 | Hunter 28096 Westminster 52" Ceiling Fan...
Hunter 28096 Westminster 52" Ceiling Fan with Light Logo
4,316 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
