Question about Lenovo Computers & Internet
Keyboard not working on lenovo ideapad N580
DigitalQueen
  • 6 Answers
SOURCE: Where is the cpu located in the Lenovo Ideapad Y510?
here is the user manual which includes photos etc
http://dl.okglb.com/consumerdl.lenovo.com.cn/UserFiles/UserGuide/en/User's%20guides%20and%20manuals/Y510/Y510%20User's%20Guide.pdf
you will need adobe and want to read pages 12 and 13 in adobe (actual manual pages are pages 7and8)
as far as i can tell you do not have to access this from under the keyboard, you only need to remove the bottom larger center panel.
<a href="http://s66.photobucket.com/albums/h258/am8r0s1a/myspace/?action=view&current=manual.jpg" target="_blank"><img src="http://i66.photobucket.com/albums/h258/am8r0s1a/myspace/manual.jpg" border="0" alt="Photobucket"></a>
Posted on Jan 05, 2009
florin_decad
  • 203 Answers
SOURCE: My web camera isn't working.
Check the driver if is still at hes place , if is not there go to manufactor website and dowload the driver
Posted on Jan 16, 2009
KingDWS
  • 1606 Answers
SOURCE: Lenovo S series ideapad will find my dlink router no network addr
Generally if you can see the D-Link then everything is trying to talk. Would have to know if the d-link is new out of the box or is part of an existing setup. If the d-link has been part of the network I would suggest that you don't have the security settings correct. If you right click on the network icon and look at the send received numbers. If received is zero then your problem is you don't have the security key (WEP or other type)) setup. If you are getting recieved numbers you may not have the DHCP setup in the d-link. DHCP assigns the numbers to the computer but the d-link has to have this turned on in some models others it is by default.
If both your laptop and dlink are not new and specifically about a year old then I would also suspect that the dlink has died or is dieing on you. If you have had periods of disconnects or slow jerky network acess then these are signs of the dlink having problems. The wireless part tends to go after a year or so while the wired portion probably still works. When they go they are annoying as they work then they won't and so on.
That is you next step to try is to plug in your laptop direct to the wired connection on the dlink to test if the problem is the wifi portion of the dlink. If it connects your problem is the wifi and you probably will have to replace the unit. Next plug it into the cable modem and see if the problem was in the dlink itself.
Posted on Jul 09, 2009
rubydu
  • 102 Answers
SOURCE: keyboard is not working
show it to the service centre it is in warrenty it is the problem of motherboard
Posted on Jul 21, 2009
SOURCE: replace keyboard on Y510
OK, Here is the official Lenovo Service Manual for every component on the Y510.
http://consumerdl.lenovo.com.cn/UserFiles/UserGuide/en/User%27s%20guides%20and%20manuals/Y450/Lenovo%20IdeaPad%20Y450%20Hardware%20Maintenance%20Manual%20v2.0.pdf
However, removing the panel above the keyboard is not as simple as just removing the 4 screws located in the battery compartment and the three along the back edge on the bottom. Yes there are some "L" brackets on either end that are a pain to get to let go, but I found that by removing the DVD drive and removing the screw in the bay edge closest to the top panel, it helped loosen things to remove the top bezel. You may have to use a small flat blade screwdriver to pry the front edge up by the PF keys. Be careful removing the top bezel though, there are two small electrical ribbons attached to it for the volume and other controls. Once you have the top bezel ose, you simply have to lift the top edge of the keyboard and release the connector ribbon by flipping up the front edge of the connector. the manual illustrates this. Then it's just a matter of reversing the order. Reassembly is must easier and faster than disassembley.
Posted on Aug 27, 2010
I can not boot from the cd drive
check if the cd drive can read nd write. otherwise check if its connected properly
Feb 13, 2014 | Lenovo/IBM IdeaPad N580 Series Laptop...
Why the The backlight of my keyboard on my Lenovo ideapad y480 isn't functional?
Many of the newer models (if you purchased during the Week/1TB sale Lenovo did) they do no include back-lit keys.
I received mine around 9/19/12 and it did not come with back-lit keys.
Unless you have physically inspected the underside of the keys and you see the diodes, then you should contact Lenovo.
Aug 28, 2012 | Lenovo Ideapad Y480 2.70-3.70ghz I7-3820qm...
My laptop lenovo ideapad Z570 doesnt have the printcsreen key on its keyboard so what do i do?
If you have Windows 7 running on your laptop, click the Windows icon in the lower left corner of the screen and type "On-Screen Keyboard" this keyboard has a button labeled "PrtScn".
Jun 19, 2012 | Lenovo IdeaPad Z570 Notebook
All my keyboard only showed 0123456789
This is a problem particular to Lenovo Ideapads. I just found the answer in the Lenovo forums. The fix is simple & quick:
http://forums.lenovo.com/t5/IdeaPad-Y-U-B-V-and-Z-series/Game-keyboard-problem/m-p/298246/highlight/true
http://forum.lenovo.com/t5/IdeaPad-Y-and-U-series-Laptops/Typed-letters-appearing-as-increasing-numbers-0-1-2-3-4-5/ta-p/301034
Nov 05, 2010 | Lenovo ThinkPad T42 Notebook
Troubleshooting
try to turn off the pc, remove cables & battery, then push the power button for 5 secs. Re-insert cables and battery, turn on pc. If keyboard did not work, call our tech support line 1-877-4-536686 for possible keyboard repair...
Mar 04, 2010 | Lenovo IdeaPad S10 - 42312BU Notebook
I have the keyboard for my Lenovo Y510, how do I install it?
basically, there is a pre-installed driver for keyboard in Y510. Check the keyboard if it work. If it is not, then turn off the pc, remove cables and battery.
Press and hold the power button for 5 seconds, reinsert the battery and keyboard then turn on the pc.
Then check if the keyboard works...
Dec 13, 2009 | Lenovo IdeaPad Y510 Notebook
Neither of the shift work correctly therefore
Your keyboard is shorted. Your computer needs a new keyboard.
Oct 05, 2009 | Lenovo IdeaPad Y510 Notebook
Keyboard is not working
Jul 14, 2009 | Lenovo IdeaPad S10 - 42312BU Notebook
Computers & Internet Logo
196 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
rey francis basa
rey francis basa
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
