Question about Bushnell Tour V2 Pinseeker Laser Rangefinder
How do I change Meters to Yards
I can not seem to change the M (Meters) to yards
  • Anonymous Mar 23, 2014
    keeps changing from Meters to yards for no reason.
  • 4 Answers
With unit on- hold mode button down for five seconds
Posted on Jan 27, 2009
Yard to meters
1 yard = .9144 meters
I am guessing that is not the answer you want but more like how to change the reading from yards to meters on your compact 800 measuring unit
read the user manual to find the mode button and select distance or yards and change to meters
no manual , download one from the web site for the manufacturer
Jan 24, 2017 | Heating & Cooling
How do change from meters to yards
From the manual (http://bushnell.com/getmedia/7ac0e774-ed2c-4ee2-9497-dade435e7df3/20-2206-6LIM.pdf?ext=.pdf):
To select between yards and meters, the unit should be off. While looking through the eyepiece, press and hold the POWER button down for approximately 5 seconds. During this time all liquid crystal segments and icons will be displayed. As you continue to depress the power button, the display will toggle back and forth between Yards and Meters. Once the unit of measure desired is displayed, simply release the power button.
Jul 31, 2015 | Miscellaneous
V3 change meters to yards
MODE and UNIT OF MEASURE OPTIONS
The TOUR V3 can be used to measure distances in yards or meters. The unit of measure indicators are located in the lower
right portion of the LCD. To select between yards and meters, press and hold the POWER/FIRE button. The display will
begin to cycle through the setup options: Yards w/JOLT, Yards, Meters w/JOLT, Meters (for details on the JOLT feature,
see "About JOLT"). When the units and JOLT mode you want to use are displayed, release the POWER/FIRE button to
select it. If you are changing from yards to meters, a change in unit of measure will be indicated by the illumination of the
M for meter indicator while the Y for Yard indicator is turned off. If you are changing from meters to yards, the opposite
will occur. The TOUR V3 will return to the last unit of measure setting used each time the unit is turned on.
Aug 03, 2014 | Bushnell Tour v3 Rangefinder With Slope
V3 not jolting
The TOUR V3 can be used to measure distances in yards or meters. The unit of measure indicators are located in the lower right portion of the LCD. To select between yards and meters, press and hold the POWER/FIRE button. The display will begin to cycle through the setup options: Yards w/JOLT, Yards, Meters w/JOLT, Meters (for details on the JOLT feature, see "About JOLT"). When the units and JOLT mode you want to use are displayed, release the POWER/FIRE button to select it. If you are changing from yards to meters, a change in unit of measure will be indicated by the illumination of the M for meter indicator while the Y for Yard indicator is turned off. If you are changing from meters to yards, the opposite will occur. The TOUR V3 will return to the last unit of measure setting used each time the unit is turned on.
Feb 12, 2014 | Optics
Golfbuddy is set calculate in meters how can I change it to yards???
Depends on the model. However if we are talking about the Voice or Voice+ you can press and hold the "+" button on the side of the unit to change from meters to yards.
Oct 04, 2013 | Golf
How can i change yards into meters
1 yard = .9144 meters yards * .9144 = meters
Jul 08, 2012 | Cabela's CLR 1200 Laser Rangefinder
How do you make it go back to yards? somehow it got on meters
Step 1: Determine the model of your Bushness rangefinder.
Step 2: Repost your query, being sure to include the information from Step 1.
Feb 21, 2012 | Bushnell Optics
I would like to convert yards to metres example 2390yards how many metres and 144 yards how many metres
  • 1 Understand the formula. Converting units of measurements always requires a specific formula. The procedure from yards to meters is X (yards) multiplied by "0.9144" meters.
  • 2 Write your formula with the number of yards. Multiply by "0.9144." For example, 100 yards * 0.9144 =?.
  • 3 Use a calculator. In the example above, 100 yards * 0.9144 =?, the answer is 91.44 meters.
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Thanks for using Fixya.
Jul 04, 2011 | American Standard Water Heaters
Can my bushnell yardage pro rangefinder be calibrated. It is 4 yards off at 30 yards and 7 yards off at 40 yards. So on and so forth
I would send this unit in for repair to have it inspected you can reach their customer service at 800-423-3537 option 1.
Oct 04, 2009 | Bushnell Yardage Pro Tour Rangefinder
Hold down the button on the side for at least 5 seconds. The "Y" will appear in the display....Now its set back to yards.
mtg
May 26, 2009 | Bushnell Tour V2 Pinseeker Laser...
Bushnell Tour V2 Pinseeker Laser Rangefinder Logo
779 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
