Question about HP Compaq Presario CQ57-229WM Notebook PC
How to replace cpu fan
I need instructions on how to replace my cpu cooling fan with a new one
  • scott hawley Jan 17, 2013
    i needed for a laptop not a desktop thanks though
  • 826 Answers
Just follow the given video and you can try it..
http://www.ehow.com/video_4774327_replace-computer-processor-fan.html
Posted on Jan 17, 2013
2 Suggested Answers
will-raven
  • 83 Answers
SOURCE: HP DV2910us -where to order cpu cooling fan for
Best place to look is ebay. Look it up as a DV2000, as far as I know all the dv2000 series use the same cpu cooling fan. Otherwise, if you have the laptop apart, use the serial number or m/n on the part to look it up on ebay. I do this daily at my computer repair store and have lots of luck with hp laptop fans.
Posted on Apr 30, 2010
Testimonial: "Good suggestion! I found the exact part number on e-Bay. Only thing is most appear to be used. I wonder if they are any better than the one I have"
Cooling fan is ok by cpu so cool
Still could be bad power supply even though the cooling fan is working. Recommend replacing the ps first since they are fairly cheap. If that does not work then the CPU is bad and needs to be replaced
Jul 04, 2016 | Gigabyte GA-G41M-ES2L Motherboard
How do I remove and replace a CPU cooling fan on my Dell Dimension 2400
Make sure u can open the casing well to expose the interior parts without causing any damage. Then by close look at the processor area , that is where the heat sink is located. Normally the dell dimension 2400 has a green channel shaped structure that acts as a passage for the air that enters in and out for cooling the heat sink. It has a locking parts that slides into the casing back by slight pressing to the back of the casing just behind the processor area, be so observant to notice the locking parts. then the fan is just fixed behind that green " channel like" and its fixed on the rear side of the casing, 25275582-o0cuhlgwrl13okm3u3q5444d-5-0.jpg
Nov 08, 2014 | Dell Dimension 2400 PC Desktop
The Cooling fan of my HP/Compaq Presario CQ60 sounds like a jet fighter! 2 questions 1) Replacement CPU cooling fan? 2) Can anybody give me pointers on how to get in to the laptop? I have tried blowing...
Presario CQ60 Repair Manual
From the above link from HP Official Support you can download the service/repair manual for instructions and photos for dis-assembly. Refer to "Fan/heat sink assembly" on page 4-41.
At page 4-7 onwards, you would find the instructions about opening the laptop.
INSTRUCTIONS & PHOTOS
Follow the instructions carefully and remove the Fan/ Heat Sink and Clean it using a tooth Brush.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 09, 2011 | HP Compaq Presario CQ60Z Notebook
Can you instruct me on how to remove this fan as I am replacing processor
you shouldn't remove the fan. your better off, removing the old proc from the heatsink and use new thermal paste on the new one when installing this heatsink back on. just be sure to clean the surface well before pasting it.
don't fear of useing a razor bade to pry the old proc off, it's not glued on. somtimes the old paste gets real tough to remove and sticks pretty good.
Jun 18, 2010 | Intel Pentium 4 Socket 478-Pin Cooling Fan...
My vaio vgn-cs320j makes a loud spinning noise that comes and goes every few seconds or minutes. Is it the fan not working properly or some other issue, or is that just what the fan sounds like? if it is...
Usually Sound from Notebook are from CPU cooling fan and from Hard drive.
But It's hardly occur in the case of Hard drive.we called it Hard drive failure and the only solution for this is new replacement.
Your problem could be CPU cooling fan not working properly. Open the Notebook ( it will be easy if you refer to manual on how to open) and start the system now, you will be able to pinpoint what causes the sound.
Clean the CPU cooling fan with an air blower and re-check if the problem still persists.
If OK,then close the Notebook otherwise replace the CPU Cooling fan with a new one.
Jan 13, 2010 | Sony VAIO VGN-CS320J Notebook
Compaq presario cpu cooling fan will not start spinning unless "helped" with tip of pen to spin over.If I dont start it manually,I get No cpu fan message,and shut down.I just replaced fan,as old had broken...
If the CPU fan speed is too slow or not working at all, the computer will shut itself off automatically to prevent damage to CPU from overheating. You may end up having to throw more money at the problem and get a new fan. I went to Compaq's web site, looked up your particualr computer, found out what type of fan you needed, and I did some research. I recommend getting the fan in the following link. It's very cheap, and has good reviews. The other fans on the site all have bad reviews. Hope this helps.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835114011
Jan 12, 2010 | Compaq Presario Cooling Fan CPU Heatsink &...
Noisy fan
You need to replace the fan. Measure the fan you have now and buy one the same diameter. Then remove the old fan and put in the new fan.
May 28, 2009 | Intel (8W501B1M3G) CPU Fan, CPU Cooling...
HP Compaq Presario CQ57-229WM Notebook PC Logo
82 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
