Question about Sony Playstation 3 (PS3) Console
Ps3 wont read my hdmi cable
Just bought a ps3 and when i hook the hdmi up nothing happens says no connection, please someone help dont what im doing wrong
  • 27 Answers
First hook up the av cable then do your set up then powerdown then hook up your hdmi if not problem message back
Posted on Jan 25, 2009
I have a 50 in LCD and am trying to hook up my PS3 to it. All I get is picture, no sound. I have tried holding PS3 button down for 4 seconds and nothing happens, I connected my HDMI cord to PS3 from Tv and...
Ok you should get picture and sound with normal a/v cables. Correct? If so you need to go under settings and switch audio video to hdmi. Another way is if you didnt hold the power button down long enough hold the power button down until you hear it beep twice release and it should pop up menus. Let me know if this doesnt help it could be begining signs of ylod but doesnt sound like it.
Dec 26, 2010 | Sony Playstation 3 (PS3) Console
Ive had my PS3 hooked up using HDMI for years now but i bought a component cable because i have just bought a PVR and it can only record using component and not HDMI. The problem im getting is that when i...
Hook it up with the component cable and then hold the power button on the console until something comes up on screen. Make sure you have selected the component input on your tv or else you wont get anything anyway.
What holding the power button does is it resets the video settings to the lowest common denominator and then you can reconfigure it for the optimal picture quality of the component cables.
If that doesn't work double check the component connections on the back of the TV and just make sure they are where they should be and that no accidents were made while hooking it up.
Please post the results from these steps here so that I know what happened.
Jun 09, 2009 | Sony Playstation 3 (PS3) Console
Cascading white craziness
First thing you should try is using the regular old AV cables. That way we know if it's an hdmi problem or a video problem with the PS3. Hook them up, do the manual video reset ( hold down the power button until you hear a second beep, quickly release) and then post back here with the results.
May 11, 2009 | Sony Playstation 3 (PS3) Console
Connecting ps3 to hd tv
ok here's what you do. Hook up your ps3 to your hd via hdmi cable then turn the tv on first. Then turn the power on to your ps3 and switch tv to hdmi. wait a while then a screen should come up and you should see and screen where it says an hdmi device is connected do u want to accept theses settings say yes. sometimes the "handshake" doesn't happen properly. If u already know this or have tried this it could be that your tv needs a firmware update, happened to me.
Jan 12, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 Does not display on TV using HDMI or regular video cable. senerio: My son hook it up using HDMI Cable to my bedroom sony flat screen tv to watch a blue ray movie and play some games. which...
I posted to your problem with a similar one. I was able to get my PS3 to work by:
1.) Powering down both the PS3 and ViewSonic LCD
2.) Unplugging the power cables to both PS3 and LCD
3.) Waiting at least 10 or more seconds
4.) Plugging in the power cables to both PS3 and LCD
5.) Turning on the ViewSonic LCD
6.) Turning on the PS3 and holding down the power button until the beep
After this sequence I heard the bootup audio and the menu appeared on the screen- which detected the HDMI connection to my LCD.
Very odd.. I've had my PS3 in the same place for months and just today this happened.
I wanted to post my success. Best of luck!
Seth
Dec 26, 2008 | Sony Playstation 3 (PS3) Console
PS3 PROBLEM
Maybe it isn't a problem with your ps3, but with the tv. Try resetting it, or asking help in the store you bought it.
Resetting a tv is mostly done by cutting of power for 15 - 30 minutes. Be sure to read the manual.
Sep 06, 2008 | Sony Playstation 3 (PS3) Console
HDMI causes red lines (static?) on screen
im having the same problem to fix it i unhook my cable box (the video cables and the hdmi inputs to the tv) this stops the lines--try just the ps3 hooked to the tv and no other devices this should solve the problem--must be getting interference from some device
Dec 29, 2007 | Sony Playstation 3 (PS3) Console
Hdmi
I can't be exactly sure without more information, but it sounds like you ps3 is outputting from another port. My ps3 originally was outputting from the component/composite cable port so in order to use the hdmi output I had to do a soft reset. That makes the ps3 sense what cable is plugged into it and automatically output through that port instead of using whatever is the saved setting.
With your ps3 turned on hold down the power button for a few second until it beeps and flashes 3 times (should be about 5 seconds). You might have to try it a few times to get it to work, but you should get picture and be able to adjust the settings on the ps3.
Dec 08, 2007 | Sony Playstation 3 (PS3) Console
PS3 hdmi Audio problem Crackling Sounds
Go to audio options, and manually DE-select Digital 5.1. That should fix it. It did for me.
Aug 28, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
164 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
