Whirlpool Washer leaves lint & white smears on the cleaned cloth
I have an older Whirlpool washing machine Stylemaster # 907675. It has began to leave lint galore and white smears on the finished clothing. Is there a filter that may need cleaning???
  • 15,935 Answers
If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
Why won't my Whirlpool Washer Stylemaster #907675 fully drain?
The pump may be failing. That's where the leak is coming from.
Jul 28, 2014 | Whirlpool Washing Machines
Washer leaves white lint like spots all over dark clothes.
This happens to me as well but only when I overload my washer or when my washer needs to be ran thru its cleaning cycle.
Mar 10, 2014 | Whirlpool Cabrio Washing Machines
Hey I'm an expert on this! You have a bad Drain Pump. It happens very frequently because of the amount of work it does. Replace it and your machine will return to Glory!
Jan 16, 2014 | Washing Machines
Whirlpool stylemaster 4217141 rev
Try cleaning the lint filter on the bottom of the inner opening. Lift up and clean filter.
Oct 15, 2013 | Washing Machines
Water is trinkling down the bello and filling drum after wash is complete
Theres an electric water valve. You have to find out if its the hot or cold thats leaking and replace it.
Jan 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool stylemaster 907675 Washer wont spin.. The lid switch is fine.. Washes fine and all other cycles work.. just wont spin.
Hi, stylemaster washing machine won't spin on the top half. The bottom part spins perfect. the top doesn't seem connected. What
should I do ?
TIA
RJ
Jan 08, 2010 | Washing Machines
Kenmore elite calypso washer leaves clumps of lint on clothes
sorry to hear you got one of these. they stopped making that model because of multiple problems. I have seen the lint issue come up with these over and over w/o a solution. I can say if you are not using a dryer to dry getting one will help.
Feb 16, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
I have an older Whirlpool washing machine (Stylemaster # 907675.) It leaves behind lint galore and white smudges that are almost impossible to clean off. Do you think it has a filter that might need...
WHIRLPOO STOP USING FILTER IT MAY BE COMING FROM THE TUB. TRY RUNFIN A WASER CLEANER LIKE C.L.R. CAUSIM LIME AND RUST REMOVER. AND TAKE THE SOFTER OUT BY PULING THE BLUE RIND UP AND PULL THE SOFERNER UP AND PUT IN WASHER TO GET CLEAN IN HOT WAER LOW CYCLE.
Jan 25, 2009 | Washing Machines
Washing Machines Logo
256 people viewed this question
Top Washing Machines Experts
