Question about ViewSonic 27 in. LCD TV
Tv has no reception.
No picture. screen is bright blue.
  • 362 Answers
Make sure you have a signal to the tv, dvd player, cable or game console.
Press the input button on the remote or the control panel on the tv.
You may have to press it several times until you get a signal. Let me know if this helps and please rate this solution.  Lone99star
Posted on Jan 25, 2009
Hisense TV - right half is blue
change your tcon board and you will be fine
Oct 06, 2017 | Televison & Video
I have the mitsubishi diamond screen tv, and the picture keeps cutting out and turning blue. After I turn off the unit and re start it, it works for a bit, then does the same thing again ?
Usually this is due to bad reception. If you are using a satellite dish it can be due to bad weather. Usually the picture will pixelize then turn to blue.
May 28, 2011 | Televison & Video
Picture has too much blue, and picture is dark
Go to your TV MENU (you can find the button on the remote or on the TV itself)
Go to PICTURE SETTINGS- here you will find color settings and brightness settings
Go to COLOR SETTINGS and just adjust the bars until the picture on the screen is the right color.
Go back and click on BRIGHTNESS- here you can adjust the bar to make it brighter and easier to see your picture.
Save your settings and exit the tv menu.
May 23, 2011 | Televison & Video
I have a sanyo DS35580 and there is a blue line across the middle of the screen
You haven't stated whether there is screen or picture. If you see only a blue line across the screen with high brightness, vertical output Ic of your TV has burned out. Don't switch on the set further or increase its brightness, till the fault is retified. Otherwise there will a phosphur burn occur where the blue line is now, and it is internal, whcih cannot be retified anymore.
Oct 16, 2010 | Sanyo DS31520 31" TV
Panasonic TH-42PX75U Blue Screen
This could be a reception problem of the cable transmission or the cable box if used. Are you using cable or SAT box. Tv goes to blue screen if signal is weak automatically.
Dec 03, 2009 | Panasonic TH-42PX75U 42 in. Plasma...
No picture but has sound
My LG TV
switch on no picture but short period of sound then nothing
Jan 20, 2008 | Sony KP-51HW40 51" Rear Projection...
Apex 32" TV - Blue Screen & Channels keeping running/changing
blue screen indicares that there is a problem in blue cathode circuit. please check 1 blue video output supply. 2 blue video ckt defective 3 signal from chroma ic to blue cathode missing. 4 loose connector 5 crt base loose. 6 chroma ic defective. I think sound will be ok .
Sep 22, 2007 | Apex Digital PF3230 32" TV
No picture
a bright thin line in centre is called horizontal line. first of all do not keep tv on unless it is rectified. BUT If you want to put on tv keep brightness minimum to protect your screen for any demage. now solution your problem is in vertical section. 1 check vertical supply. 2 check parts in vertical section or loose contact. 3 yoke connrctor loose 4 ic defective It is not serious problem can be rectified easily
Sep 19, 2007 | Toshiba 32DF46 32" TV
Tv showing blue screen with flyback lines sound ok
Flyback lines? Is the picture all white with no brightness control with faint horizontal faint lines? If this is what you are saying, the screen voltage could be bad, and if thats the case, the picture tube or the flyback itself could be bad. You could also have a bad connection on the crt socket
Dec 27, 2006 | Philips Magnavox 20MT133S 20" TV
ViewSonic 27 in. LCD TV Logo
124 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
