Question about GE SpaceMaker Microwave Ovens
Model jvm1540dm5bb fan doesnt pull steam from the stove top unit is new and fan was turned to blow in room any suggestions
It does pull a little air it will hold a paper towel on the screens , it seems to blow alot of air out the top of unit but doesnt pull much steam from cook top most of steam goes up front of microwave.
MicrowaveSvc
  • 9098 Answers
SOURCE: Fan stopped working in JVM1533BD microwave
I assume you're talking about the hood fan which ventilates the cook top and blows air through the grille across the top. If so, it's okay to use the microwave with that not working, but if you boil something on the stove, an external fan is definitely needed to keep mositure from going up into the microwave controls. If the cooling fan INSIDE the microwave (behind the keypad) is not working, then you do NOT want to run it unit it is fixed. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383
Posted on Apr 10, 2007
  • 17 Answers
SOURCE: Microwave turns on, but no heat or turntable movement
The problem is that the magnatron is not getting power. Chance is that if could be a bolwn fuse inside the unit. If the fuse don't fix it then that leaves the charging diode, capacitor or the magnatron, or high voltage xformer of which without technical epertize I would not recomend attempting to replace. good luck
Posted on May 14, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: the fan starts up and runs on its own and we are cooking
That is a normal safety feature.
That's only covered in a very subtle note in the hood fan section of your owner's manual:
NOTE:If the temperature gets too hot around the
microwave oven, the fan in the vent hood will
automatically turn on at the HIGH setting to cool the
oven. It may stay on up to an hour. When this
occurs, the fan can not be turned off.
If for some reason you don't have your owner's manual, you can download it here.
Enter your model number as MV1610ST with no spaces.
You will need the free DJVU viewer to view or print your manual.
Posted on Dec 15, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave Oven Does Not Start Cooking
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If yours is not shown at the parts site or manual site linked above, Please reply back with your brand and model number so we can help you.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on Dec 25, 2008
SOURCE: Frigidaire Microwave Fan won't shut off plmv169dcd
Had the same issue, leave Microwave unplugged for 30 minutes and then plug back in. My fax stopped blowing and now fucntions 100% normal again HI/LO / OFF
Best of Luck!!! :)
Posted on Jun 30, 2011
My frigidaire microwave fan turned on by it self. Won't turn off. Blowing air above Microwave
Try unplugging it for a few seconds or turning off the circut breaker to it. This usually resets the unit.
Jan 03, 2015 | Microwave Ovens
When turning Fan on (any speed), top vent grille blowing lots of air, but not pulling air underneath
some microwaves vent to the exterior. check outside for a vent. If it is a recirculating model, perhaps the filters are plugged, the vent pathway is blocked (packaging material) or a loose panel at the back so that the exhaust fan air is leaking out somewhere else. I don't know what else it could be unless the fan is loose on the motor shaft and the fan motor is running but the fan blades are not moving air.
Nov 15, 2014 | Microwave Ovens
My fan for the stove reduces power once the microwave is turned on
you must understand that any manufacturer has the proper design engineering from to save electricity, etc. And they using the new concept of reingeenering.
If the microwaves do not HEAT and working, do not worry.
Mar 06, 2013 | Microwave Ovens
For the Jenn-Air Model JMV8208AA The microwave was dealer installed and is room vented. The vent does not pull vapors from the cook top of the oven. Regardless of the venting level used, the pull...
Sorry to read about your problem, I hope this helps you out.
Well first of all I would take a piece of paper or newspaper, and put it up by the vents, the paper should be sucked on by the vent.. If it does that you have suction. if it does not hold the paper, you should get a warranty repair, i am assuming this new.
If the unit is install to far above the stove you may have a issue.
But long story short, the room vented units, do not really pull much smoke, they pull better on outside venting. you are just putting smoke/steam back into the room, just a little cleaner.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Dec 30, 2010 | Jenn-Air JMV8208AAS Microwave Oven
My cooling fan will not engage when I turn on the microwave. I am manually turning on the fan at High to make sure the temperature doesn't overheat the appliance. Sometimes after I'm done cooking if I...
There are typically 2 fans in these units. The fan that cools the magnetron and then the vent fan that intakes from the top of your stove then vents the air out or away from the unit. Are the lights that shine on the top of the stove working?? Sometimes if a bulb blows violently it can blow a trace off of the back of the main circuit board and that trace may also supply power to the fan
Oct 21, 2017 | Magic Chef CMV1000B Microwave Oven
Microwave popped and now does not heat
Okay, first we need to separate the situations. You were boiling water on the stove and had the range hood fan running to **** up the steam. Then you put something in the microwave to heat and you heard a pop and then zip-o.
The water on the stove has nothing to do with the situation, the fan you turn on is not part of the microwave, so it has nothing to do with the microwave.
The pop you heard and then the humming suggests the magnetron failed. You said you found a blow fuse and replaced it and still nothing, right? The magnetron is the most likely culprit...I would think it is safe to say that the magnetron shorted and drew enough current to blow the fuse.
Replace the magnetron and if that doesn't work, let me know here. Good Luck!
Sep 14, 2009 | Sharp R-1480 Microwave Oven
Recirculation fan does not pull in air/steam/smoke
The issue is that the fan on that unit is a reconfigurable fan. If there is a vent, you install the fan one way, if there is no vent pipe to the outside, you install the fan another way. https://www.manualslib.com/manual/294916/Maytag-Mmv4205.html?page=9#manual
Sep 04, 2017 | Maytag MMV5165 Microwave Oven
Exhaust fan draws poorly
put a bomb on it and tic tic tic boooooooooooooommmmmmmmmm
and buy a new one!
May 23, 2008 | KitchenAid KHMS147 Microwave Oven
I HAVE A OVER THE STOVE MICROWAVE MODEL JVM1443BK02 WHEN SOME THING IS IN THE STOVE OR ON TOP AND I GET STEAM , IGET A F3 ON THE PANEL I KNOW IT,S THE SMART BOARD BUT I UNPLUG THE MICROWAVE FOR 10 MINUTES...
First of all, be sure the microwave's hood vent exhaust fan is on whenever you cook on the stove top! That's essential to protecting the controls of the microwave.
If this still happens even though you use the fan, then your keypad or controller is likely failing, and we can help you with our $39.95 nationwide repair service.
Please reply back and let us know how it goes.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
May 21, 2008 | GE Microwave Ovens
Apr 06, 2007 | GE JVM1542 Microwave Oven
Microwave Ovens Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
