Question about Olevia LT32HVM 32 in. LCD Television
Not getting signal to Tv from PC did all that I wa suppose to do hooked up both cables and get in to the Tv into the computer mode
  • 3 Answers
Have you plugged the vga cable from the back of the computer to the tv, then change source to vga?
Posted on Feb 03, 2009
Can't get surround sound sound through tv mode, have sound only when cable box mode is on. I've tried hooking optical cable straight from receiver to tv and I've also tried AV jacks. Not sure.
The audio signal that your tv is producing is a stereo signal only - not surround. You should be able to manually put your receiver into a surround mode when using the tv input and get surround sound that way.
Sep 23, 2016 | Audio Players & Recorders
Hooked up my HP pavilion dv7-1240us (Vista) to our HDMI cable, then into the TV, as usual. Slept he computer, then disconnected the HDMI cable. Since then, I cannot get any screen at all. Have tried...
restart pc in safe mode, change video back to standard VGA of HD VGA video. PC has to be in HDMI mode and your TV has to be PC mode. Use a DIV to HDMI connector or better yet HDMI to VideoPort if your TV supports it, HDMI almost never gives you the screen output you really want anyway.
Jan 17, 2014 | HP Pavilion dv7-1240us Notebook
How do I get the HDMI connection on my HP Pavilion dv9000 to work. I have a HDMI connection on my Pioneer HD TV but I don't know how to get the connection on my computer to work. It there some trick I...
Normally the computer will detect that you have hooked in the HDMI cable and will automatically send an signal to the HDMI cable. It sounds like the "automagic" didn't work.
What you need to do is press fn+f4 to cycle the display mode to send a signal through the HDMI port. This works in a multi-mode way. You hold down fn and press f4 one time. Don't let go of fn and you should see a mode indicator on the laptop display. Each time you press f4 it will cycle to another mode. Depending on your specific configuration you might need to cycle through VGA first to get to HDMI.
Jan 09, 2010 | HP Pavilion dv9000z Notebook
S-video not working
Thanks for that clarification; yes that does make a difference because unless the video on your laptop supports it (which most don't) that won't work. It has to go into an s-video input or a device that can convert the signal. As it is now, you're hooking up a cable that would work if your video on your laptop could convert the signal but it can't so you're not getting any signal. If you had a TV that had an S-video input then it would work like a charm.
Jun 14, 2009 | HP Compaq Presario C769US Notebook
Hooking up to the tv, aspire one acer notebook???
hi there, try a 15 pin male vga to vga cable ...select vga mode on monitor
May 17, 2009 | Acer Aspire One PC Notebook
Im trying to get my sattelite signal to come thru my computer. I have the tv card installed with the vista drivers. I had no problem getting cable thru on this. But now I have sattleite tv and now Im...
There is no real way to get satellite signals into your PC. There are many companies on the net that are selling software that supposedly does this and they are all a scam. Getting cable is easy because your cable connects to the TV tuner card you installed and then converts this into the various channels. Satellite tuners work completely different.
Apr 14, 2009 | Microsoft Windows Vista Home Basic for PC
I want to hook laptop up to tv
after you hook the cable up to the tv, go into the tv's menu to make sure the input mode is set to s-video. then go into the control panel on your laptop and find the settings for your video card and set the output to "TV" or "Clone"
Let me know :)
Dec 24, 2008 | Toshiba Satellite A35-S159 Notebook
Partial Cable
The TV is set to antenna mode or over the air mode rather than the cable mode. You should be able to navigate through the menus to change it to cable mode. That should resolve it.
Dan
Jun 05, 2008 | Televison & Video
NO SIGNAL -
Try the user manual for possible solutions, usually in the troubleshooting section, there is a quick start guide and user manual at the Westinghouse website here:
http://www.westinghousedigital.com/manuals.aspx
Apr 11, 2008 | Westinghouse LTV-19w6 Television
Olevia LT32HVM 32 in. LCD Television Logo
283 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
