Question about GE Microwave Ovens
GE model JNM1731DM1BB Just quit no power no disp. house breaker is fine and out let has 120 volts
The microwave just stopped after opening the door the display whent blank and nothing works. I have power to the outlet. Looking at the manual I see no fuse info. any ideas?
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Profile Advantium 120 Microwave (Model SCA1000DBB03)
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille, on the floor of the oven behind the control panel, between the door switches, or on the filter board near where the cord comes into the unit.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
So don't let that fool you.
If the cavity thermostat needs to be checked or replaced you'll need to pull the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 25, 2008
jmgldsmth
  • 2005 Answers
SOURCE: Kenmore over the range microwave 721.63684300 - nothing works
you must remove the MW take off the cover then look for a large metal can (capacitor) and a white (ceramic) fuse...look and, smell and, you should find the cause
Posted on Apr 22, 2009
SOURCE: LG Microwave LMVM2055ST Just stopped working!
It has probably had an overhesat problem and the repair is quite simple. First you must remove the cover. This will require the removal of alot of scres on top, bottom and rear of machine. Once done, looking down at the top of the microwave all the way to the left about half way from the front to the rear you will see a round senso with two black wires going to it. This issimilar to a fuse and when you remove it, you can test it with a continuity testor. Electric should flow through it with no resitance. If it does not, it must nbe replaced. It's about ten bucks.
Posted on Nov 20, 2009
SOURCE: GE Spacemaker microwave JVM140G just stopped
NO internal fuse. It is most likely, the magnetron, and or High power diode. As related In all likelihood the mangnetron has failed, or perhaps even the Power Supply. or a fault that is shutting the system down for safety reasons You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Posted on May 10, 2010
jsrock516
  • 5911 Answers
SOURCE: microwave is dead as a door nail
There is usually a 125V, 20 AMP line fuse inside the microwave. Its usually mounted at the point where the power cord enters the back of the unit. Unfortunately, you will need to uninstall the oven (if this is an over the range model), UNPLUG it and remove the exterior case to access. The case comes off in various ways depending on manufacture and model. I found this illustration at pcappliancerepair.com based on the model number you listed this question under:
http://pcappliancerepair.com/model-display.php
There is a line filter assembly listed as item 1420 in the drawing. This is where the line fuse is usually mounted. Keep in mind, there are different vairations on the model number you provided. You need to look at the model number you have and include all the numbers. I reviewed most of these models and they appear to all have the same parts. You can usually purchase a box of fuses at a hardware store for just a little more than what the manufacturer charges for a single fuse. 125V, 20AMP Ceramic Slow Blow fuses are recommended. If you wish to order on line, use the part numbers to search by comparison as the model number you listed this question under may not be available at all the websites I have provided. The parts, however, ARE listed.
If you have any questions, or need additional assistance troubleshooting, please post back and let me know. I hope you find this information helpful.
NOTE: Make sure you take any resistance readings with the microwave UNPLUGGED and the component under test isolated (removed) from the circuit. These ovens can blow a fuse by simply sitting idle. This can occur from any power fluctuations, brown outs, voltage spikes, etc. Or, it could be the symptom of a component that may have failed. If you find the internal fuse blown and replace it, only to have it blow again, you have a more significant problem than a simple blown fuse.
Posted on May 20, 2010
GE microwave (Model JE2160SF03) trips breaker when door opened
Remove the control panel, take pictures of the door switch wiring while they are still connected to the door switches, then remove the door switch assembly. Have someone at the appliance store check each switch and repair the ones that are defective.
I purchased a switch for $7, reinstalled the door switch assembly and the microwave is working fine now.
Jul 02, 2012 | GE Microwave Ovens
How to halogen light bulbson my microwave JVM3670Sk03 I have changed one I know there is another one how do i change it please advice thanks anna
That's covered on pages 35 & 36 of your owner's manual.
If for some reason you don't have yours, you can download it here.
Cooktop Light/Night Light
On models JVM1850, JNM1851, DVM1850 and
EMO4000, replace the burned-out bulb with a 120 volt,
40-watt incandescent bulb (WB36X10003), available
from your GE supplier.
On models JVM1870, JVM1871, JVM2050 and
JVM3670, replace the burned-out bulb with a 120 volt,
20-watt halogen bulb (WB36X10213), available from
your GE supplier.
To replace the bulb(s), first disconnect the
power at the main fuse or circuit breaker panel
or pull the plug.
Remove the screw at the left edge of the light
cover and push on the right edge of the cover
to open.
Be sure the bulb(s) to be replaced are cool
before removing. After breaking the adhesive
seal, remove the bulb by either gently turning
(for models JVM1850, JNM1851, DVM1850 and
EMO4000) or pulling straight out (for models
JVM1870, JVM1871, JVM2050 and JVM3670).
Replace with the same size and type bulb.
Raise the light shield and replace the screw.
Connect electrical power to the oven.
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt
halogen bulb (WB36X10213), available from your GE supplier.
To replace the oven light, first disconnect the
or pull the plug.
Remove the top grille by taking out the screws
on top of the grille that hold it in place and
sliding the grille to the left (opening the door
makes grille removal easier).
Next, remove the light cover.
On some models, the light cover is located
in the center of the top opening. Remove the
screw that secures the light cover and lift the
cover off.
On some models, the light cover is located at the
left of the top opening. Lift the cover off.
Pinch the clips that hold the light socket in
place and lift the socket out.
Remove the bulb from the light socket by
pulling straight out. Replace with the same size
and type bulb, then replace the light socket and
cover.
Replace the grille and screws. Connect electrical
power to the oven.
Jun 08, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
G e microwave model JNM1731DM1BB apparently working, but seems not to go off when time is up,tho' bell chimes. Will not go off unless door is left open. Light also stays on.
you have a micro switch stuck open which is causing unit not to shut off, until open, it will be probably the monitor switch located at top switch or the bottom
Feb 23, 2011 | GE Microwave Ovens
GE Spacemaker Microwave JVM1441 BH04 tripping circuit breaker
your power transformer for the magnetron could have a shorted primary power winding,the door safety interlock switch could be mis-adjusted,this normally blows the internal unit fuse,a shorted high voltage capacitor,or diode,a bare wire inside the unit,more than the microwave on that circuit or a weak circuit breaker in the house power panel
Jun 19, 2010 | GE JVM1441 Microwave Oven
How do i change the bulbs on a jvm1870sk03 microwave
That's covered on pages 35 & 36 of the owner's manual here.
your GE supplier.
or pull the plug. *
to open.
Oven Light
GE supplier.
or pull the plug.
cover off.
cover.
power to the oven.
* If your control board was damaged (lights won't come on, won't go off, fan or turntable not working right) after a cooktop light bulb blew or was inserted or removed while power was on, see here.
Apr 25, 2010 | GE JVM1870 Microwave Oven
How can i convert our 220 volts wall outlet to 110 volts for a microwave oven.
Find the breaker for it (a double for 220) and substitue a single breaker (for 110). This will leave one wire unused from the breaker box to the outlet. You'll have to change the outlet of course to accommodate a normal 110 plug. You can also skip the breaker part and just change the outlet and cap off 1 of the hot wires. Just make sure to kill the power and be safe!
Mar 11, 2010 | GE JVM1650 1000 Watts Microwave Oven
Model jvm131h002 Stopped working. no power or
yes, at the back of the microwave there are 4 or 6 screws, take them out and then pull the cover follow the cable( the one you connect to the outlet) going to the inside of the microwave inside you will see the fuse change it with the same size, it is a slow burn fuse
Aug 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Have an installed GE Microwave jvm1870 with a burned out oven bulb. Have replacement bulb but can not see how to get to the old bulb to replace it.
From the owner's manual:
On models JVM1850, JNM1851, DVM1850 and EMO4000, replace the burned-out bulb with a 120 volt, 40-watt incandescent bulb (WB36X10003), available from your GE supplier.
On models JVM1870, JVM1871, JVM2050 and JVM3670, replace the burned-out bulb with a 120 volt,
20-watt halogen bulb (WB36X10213), available from your GE supplier.
To replace the bulb(s), first disconnect the power at the main fuse or circuit breaker panel or pull the plug.
Remove the screw at the left edge of the light cover and push on the right edge of the cover to open.
Be sure the bulb(s) to be replaced are cool before removing.
After breaking the adhesive seal, remove the bulb by either gently turning (for models JVM1850, JNM1851, DVM1850 and EMO4000) or pulling straight out (for models JVM1870, JVM1871, JVM2050 and JVM3670).
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt halogen bulb (WB36X10213), available from your
GE supplier.
To replace the oven light, first disconnect the power at the main fuse or circuit breaker panel or pull the plug.
Remove the top grille by taking out the screws on top of the grille that hold it in place and sliding the grille to the left (opening the door makes grille removal easier).
On some models, the light cover is located in the center of the top opening.
Remove the screw that secures the light cover and lift the cover off.
On some models, the light cover is located at the left of the top opening.
Lift the cover off.
Pinch the clips that hold the light socket in place and lift the socket out.
Remove the bulb from the light socket by pulling straight out.
Replace with the same size and type bulb, then replace the light socket and cover.
Jun 26, 2009 | GE Microwave Ovens
No power
The problem is most likely in the door latch circuitry. This is an expensive repair. Consider replacing the unit. If the door latch is not repaired correctly, very dangerous microwave energy can be released. This is not a do-it-yourself project. New ovens are very reasonable.
Ray
Dec 17, 2008 | GE JVM1650 1000 Watts Microwave Oven
Microwave Ovens Logo
114 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
