Question about Behringer Xenyx X2442USB / Harbinger APS15 PA Package
Harbinger AP15 Amplifier Repair
Line level inputs dead
The Fender Champion 100 has a Pre Out input. Can that be use to go to a PA system?
The Pre Out and PWR In for a method to insert an effects loop. The output signal from the Pre Out should be line level so you would not connect this to our microphone input on the PA, but preferably to a Line Level input otherwise you would overdrive the PA's input. When you connect the Pre Out, the 1/4" jack may interrupt the signal so you may lose output to the Champion's amplifier/speaker. If this happens, you need to have a return line with the same line level signal plugged into the AMP In to get your sound back on the amplifier itself.
Nov 03, 2017 | Fender Music
No sound coming out of my mackie
Whether you are experienced in electronics repair?
if not, try this simply way:
1: Test whether the power amplifier is still working. See figure 1.
Power OFF,adjust the EQ settings as shown in the picture.
Minimize LEVEL.Switch ON Power. Touch pin 3 at the INPUT socket by using a small screwdriver or piece of wire / cable.
Slowly raise the LEVEL,a little bit only (as the clock showed 7-8) until
sound is heard in speaker. If not heard, slowly raise again LEVEL.
If audio input signal is heard,it can simply be taken to mean
that the amplifier is working.
If LEVEL at 9 o'clock position,and the audio is not heard,
the possibility of the amplifier is damaged.
Switch OFF the power. Take it to a repair place.
2: When the Power LED is lit, but no sound,
There are many possible causes, one of which is:
I have been getting 3 times similar cases, and all are caused by
two Rectifier-Diode (either or both.) damage on the power-supply-unit.
Remove/desolder,measure, if damaged replace it with a new one.
See figure 2-3.
Hope it helps. Regards.
May 13, 2014 | Mackie TH-15A Active DJ Powered THUMP...
Can I hook up a monitor to a Harbinger HA120 Portable PA System
Yes you can,you will need 2 run ,1\4 in 2 jack 1\4 in imput too the mic\line imput your chaing your signal so you will need too preset vol levels on the 120 too your desired max peak out put buy first putting you output slide too max on your mixer (running a signal from a cd player or other divice into mixer)then turn vol up 2 disered max loudness you want to run sound at then lower the vol using out put from main power slide on your mixer. Its called chaining your componets .better way of hooking up a band on a small system.ywc Rev bob dj 25yrs exp
Sep 06, 2012 | Harbinger HA120 Portable PA System
Harbinger APS 15 has a broken horn
Where can I buy a horn for my speaker?
Jun 19, 2012 | Harbinger APS 15 Powered PA Speaker
HOW TO WIRE GEMINI GRAPHIC EQ 3000 TO behringer djx750 proffessional MIXER
Line level output of the mixer would go into the line level inputs of the EQ, and the EQ line level outpputs to the line level inputs of the amplifier. If you are faced with a mix of unbalanced inputs or outputs, to balanced inputs or outputs it gets a little complicated because you need to matrix the balanced signal to unbalanced load and vice versa. There is no single answer to doing this either.
RCA jacks are unbalanced, 2 conductor 1/4 inch connections are unbalanced most of the time. XLR and 3 conductor 1/4 inch jacks and plugs can be either balanced or unbalanced.If either are wired so left and right are a single ring or tip on the 3 conductor 1/4 inch jack, it is unbalanced and they would share a common ground lead. XLR wired with one pin common with shield and right and left have a single conductor on the plug or jack, that is unbalanced.
Apr 26, 2012 | Behringer Pro Mixer Djx750 Professional 5...
Hooking up the speaker to an amp, using the rca line out of the amp i have no volume control from the amp knobs, can i hook the speakers up to the amp from the speaker out ?
You should NOT under any circumstances connect an audio input lead to a speaker output jack!
The RCA jacks you are trying to take output from ore "pre fader" which would be solid "line level" and not controlled by volume controls. Tap off the INPUT to the amp... you should be using balanced lines for the interconnects. RCA jacks are unbalanced lines. You can drive several inputs from a line level output of a mixer for example using a splitter cable.
Aug 23, 2011 | Harbinger APS12 12 Powered PA Speaker
Im trying to connect a peavey kb300 with a mackie micro series 1402-VLZ 14 channel mic/line mixer
The mixer is stereo and the amp is mono. The line level out of the mixer MAY overwhelm the KB2 regular inputs so try running the mixer into the PA input jack.
Apr 27, 2011 | Peavey Kb 2 Keyboard Amplifier
Ran too much power through the speakers and I think I fried the crossovers. Can the crossover be replaced?
This makes little sense... these are bi-amped speakers meaning the crossover is an electronic LOW LEVEL filter network. You can send LINE LEVEL signals to these (never the output of a power amplifier) and not damage the crossover electronics. You would normally connect the balanced line-level output of a mixer into these.
If you have connected a power amp into this by mistake, you likely blew the input circuit. You will have to have the circuitry replaced.
Very important is to connect ALL interconnected equipment to the same power source or receptacle. Powering speakers from one end of a venue and the mixer from the other end wall receptacles is a good way to blow circuitry due to ground bounce in buildings.
Give us more information of how you connected this AND also the symptoms... unless you are into electronics, self diagnosis of the problem may lead you astray as well as the technicians who fix it.
Mar 26, 2011 | Harbinger HP215 Powered Loudspeaker
Hi have been given a Marshall MBB15 amp to find out why it doesnt produce sound through the input jack, have checked inside, looks like the resistors connected directly to the input jack are dead. Could...
Dead resistors? The evidence would be if the resistors are cracked OR if their is evidence of smoke/fire around them.
In either case, there would LIKELY be damage at least one or two layers deep beyond those resistors if in fact they are fried. If they are cracked physically, teh circuit board also may be cracked due to physical bending. Tripping over an inpout cable can do this.
Causes of this would be shorting the input to power line voltage or the output of a high powered amplifier.
I question that the resistors are "dead".
THE USUAL cause of failures of these small amplifiers is frying of the output power chip which is often in the TDA family of 5/7 terminal amplifier chips in modified TO220 packages.
Another less common problem is failure of the rectifier and filter capacitor combination.
Nov 03, 2009 | Marshall 15 Watt Guitar Amp
Behringer  Xenyx X2442USB / Harbinger APS15 PA Package Logo
35 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
