Question about Catch A Call Catch-A-Call Internet/Phone Switchboard
My catch a call rings and rings after I connect to the internet
I answer the phone and all I get is a noise like connecting to the internet and when I hang up it ring and rings again. I finally had to disconnect it
  • 2 more comments
  • dnm4446 Jan 26, 2009
    What is an ip phone? This I tink is a normal phone and I have used it like this for months with no problems! All of a sudden it just started acting up!
  • dnm4446 Jan 27, 2009
    No we have dial up
    We only have 1 phone line!
  • dnm4446 Feb 03, 2009
    We fixed it by disconnecting the power cord and reconnecting it again!!!
    Problem Solver:
  • 10 Answers
You can get and read the manual here, but seems like its too sensitive. You acctually have to dial ###3 to make it less sensitive.
Posted on Aug 18, 2009
    Problem Solver:
Mine is a dial up and did the same thing, its that it is set to sensitive. Try on oyur phone pressing ##3, you will hear a ring and its set!
Posted on Feb 03, 2009
  • 39 Answers
Is it an ip phone or is it a normal one...if its a normal phone you have to buy a filter to put between it and the wall jack...if its an ip phone post the specs here and ill get back to you
Posted on Jan 26, 2009
  • 2 more comments
  • Ryan Peterman
    Ryan Peterman Jan 26, 2009
    sry your post was under voip so i assumed thats wat it was....do you have a dsl internet connection in your home?
  • Ryan Peterman
    Ryan Peterman Jan 27, 2009
    do you have multiple phone lines?
  • Ryan Peterman
    Ryan Peterman Jan 29, 2009
    yea you definitely need to get a phone filter...it gets rid of that computer noise in the background. here is a link to google products for it
  • Ryan Peterman
    Ryan Peterman Feb 03, 2009
    really? well im sorry my suggestions didn't help
I want to know how many rings should i set my answering machine on 2, 4,6....
Based on, how long it takes you to get to the phone. I would say 4, just because if it rings more the that, my guess would be that you do not have a answer machine. Also, with clear, we like to the voicemail set to 4 rings. But it is up to you on how many rings, but for most common, 4 rings. Hope this helps
Sep 30, 2010 | Catch A Call Catch-A-Call Internet/Phone...
When the phone rings and I answer it, and I'm on
Hi, the problem is unlikely to be related to your wireless router and more likely your internet modem.
If sounds like you are most likely on a DSL internet connection.
If you have a DSL modem, you need to have a filter on your phones in the house to prevent internet disconnecting. Usually you get one with your adsl modem, but if you need more or if you did not get one you can purchase them from any computer store and possibly an electronics or even supermarket. They are very cheap.
Apr 06, 2010 | D-Link DI 514 Wireless Router (DI-514)
IT WILL RING BUT GOES TO ANSWERING MACHINE DOES NOT RECEIVE FAX
>first run fax test, press set up go to tools menu then select run fax test,all entries should be pass
>then check your connections, do you have one line or number for your fax and phone?or a separate line or another number for fax and another number for phone?
>let me assume you only have one number for fax and phone..
>check connections, this should be downstream connection, the fax machine using the black phone cord provided by hp should be connected directly to the phone jack using line 1 at the back of the fax and the answering machine or the telephone should be connected to ext 2 or line 2 at the back of the fax...there should be no other devices phone or answering machine connected directly to the phone jack.
>next set rings to answer on the fax machine higher than the answering machine...if your rings to answer on answering machine is 4 rings, set the fax to 6 rings...if it is a voice call the answering machine will pick it up at 4 rings then if it detects that it it a fax tone then it will transfer the call to fax.
>also check if auto answer is on in your fax
>you can check auto answer and rings to answer by pressing set up or menu button on your machine look for it in basic fax settings or advance settings
>also check if your voice prompt for your answering machine is not too short there should be like at least 5 seconds after cutting your message to allow the machine to transfer the call to the fax if it is a fax tone.
Sep 14, 2009 | HP 1040 Plain Paper Inkjet Fax
I hooked up a phone in the office on an extended line from another area and all of the memory buttons automatically worked, but the phone doesn't ring even after using feature *6 selecting a ring, and...
The easiest thing to do is use Direct Pickup Feature.
When the phone is ringing dial Feature 76
Dial internal number of a phone that is ringing (also refered as extension number)
You just answered a ringing phone at your desk.
If you have login information for Feature **config, I can help you set up your phone to be ringing as well.
Cheers
Jun 24, 2009 | NorStar M7310 Corded Phone
Catach-a-call not receiving inbound calls/not notifying me of the
did u try making the catch-a-call more sensitive to the signal? you can do that by dailing ###1 and it should ring in response.
May 26, 2009 | Catch A Call Catch-A-Call Internet/Phone...
Fax-like noise when answering catch a call!
If you have a catch a call max, this happens because the catch a call is too sensitive to the phone company's signal, you can lower the sensitivty of the catch a call by dialing ###3. You can get the catch a call max manual here
Feb 18, 2009 | Catch A Call Catch-A-Call Internet/Phone...
Getting kicked off the internet
have u got a modem to your laptop or pc so it will stop the phine interferring with the internet connection. if u dont have a modem and your laptops a dial up connection the phone WILL make u *** offline. i would buy a router or ask a computer man to fix a modem to your internet wires so the phone wont take u offline.
Dec 27, 2008 | Sony Playstation 3 (PS3) Console
My phone does not ring when a call is received
I've found this to be a problem with regular phone lines (POTS) and Uniden phones. Uniden phones do not seem to support 90v @ 20hz ringing voltage / frequency. They work fine in every aspect except for ringing. These phones do work well with voip, where you aren't connected to the telephone company and have calls routed over the internet. The boxes that handle the voip calls generally produce less than 90v and work well w/ Uniden phones.
Dec 18, 2008 | Uniden TRU8885 Digital Answering Machine
Ring Tone Won't Stop
I had this problem with my old phone, it was a Samsung Sch-950 I recently upgraded my phone and new phone doesn't do it so I don't have an answer other than to get a new phone.
Oct 26, 2007 | Motorola Mobility H350 Wireless Headset
Catch A Call Catch-A-Call Internet/Phone Switchboard Logo
217 people viewed this question
Top Catch A Call Computers & Internet Experts
David Payne
David Payne
Are you a Catch A Call Computer and Internet Expert? Answer questions, earn points and help others
